Question about Dryers
Bosch wtl 5500 water bottom - Dryers
4 Suggested Answers
SOURCE: Bosch Maxx WTL 6100 tumble dryer - door switch
i have wtl 6100 bosch and the mashine is not running. There is power on the machine, it can run but it can not run and heat. I can get light in al the panel, but it is like it needs to be rebouted. I can get it to show 111,222,333 etc in the window but i cant get it to work
Posted on Sep 05, 2010
marc_uhrey
  • 72 Answers
SOURCE: My Bosch WTL 5500 dryer
If the dryer blew a fuse, it sounds like the heating element has gone, and drew enough current to take out the fuse.
If this is not the case, the thermostat may have burned out, which it can do if the condensor is not regularly cleaned.
Posted on Mar 17, 2011
  • 403 Answers
SOURCE: Hi. My Bosch WTL 5500
there is a thermal reset button at the back of the unit on the heating element. to get to it you have to remove the back panel that covers the heating element. (its the panel that sticks out). Once that panel is removed you will see the red thermal reset button. press it so it clicks, then start unit. Let me know what happens.
Posted on Mar 18, 2011
E1 code. water is being pumped out dry and start dryer and 3-5 min code comes back. cleaned everything inside checked all hoses and switch. everything looks fine
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
25808741-gtkp3url2ghtdqenstp5bokb-1-0.jpg Dado
Aug 04, 2015 | Bosch Axxis WTL 5410 Electric Dryer
WTL 5410 getting E1 error message. Condenser hose seems unblocked. Pool of water behind the heat exchanger
Dado
Jul 02, 2015 | Bosch Dryers
Can I stack a Bosch WTL5400 dryer on top of a Bosch Classixx 7 washing machine?
http://www.bosch-home.co.uk/store/product/Connectionpiece/244024
Call the helpline for verification of compatibility prior to ordering.
Feb 06, 2013 | Bosch Axxis WTL 5400 Dryer
Bosch AXXIS WTL 86300 condensation dryer leaking water
It's a classical error code, you can find all the error codes together with the troubleshooter within the manual under this article:
Bosch Axxis Washer Manual
Nov 29, 2012 | Bosch Dryers
My dryer is leaking from the bottom. service man said either the tube or the pan is cracked. tube seems ok, so is the pan replaceable or glueable. could there be another reason to look for leak. dryer has...
Open the bottom front panel. Remove the heat exchanger. Take notice to see if theres any water in that compartment. Reach your hand towards the back of that opening to see if there is water pooling back there. If theres water present, then your condensation pump needs to be replaced.
also double check the connection of the drain hose from the dryer to the drain.
Jan 09, 2011 | Bosch Axxis WTL 5410 Electric Dryer
Oct 25, 2008 | Dryers
Bosch wtl 5400 elect. condensation dryer
I have a WTL 5400 electric condensation dryer (bosch). All of a sudden one day, it would not turn on. The lights are on, the filters are clean. Please Advise.
Harriet Scannon
Feb 18, 2008 | Bosch Axxis WTL 5400 Dryer
Dryers Logo
14 people viewed this question
Top Dryers Experts
