Question about RCA 27V520T 27" TV
Turns off/ on by itself model 27v412t
All of a sudden it started turning itself off/ on....only way to stop it is to unplug it.
Help, my husband needz his football
Well my tv was doing the same thing my prob was the buton bord.the ezyest way to check it was to take the back off and find the wires that come from the boton bord the plug the tv in and turn the tv on wile its on unplug the boton bord wires if the tv stays on that is probly your prob the bord dont cost much I found a site on here that has them for under $5.remember to be carefull when checking it out tv car be very dangerus.I found that if I beat on my buton bord alittel it would work for awile hope this helps
Posted on Oct 26, 2007
My RCA 27V412T TV turns the screen red
Can you see a picture at all or is it completely bright red? Is there sound?
Dec 29, 2012 | RCA 27V520T 27" TV
T.v. turns on and off by it self also will do auto search by itself
The microprocessor ic is breaking down or the pad switches behind the buttons on the front of the set, "one or two are bad" disable the front panel by unplugging from main board, if problem goes away use remote to control set.
Mar 19, 2012 | RCA Televison & Video
Model 27v412t TV turns on and off by itself repeatledy.
Sounds like you have a short somewhere in the wiring. I would first check the company's website and enter your model mane and number of your TV. Chances are that there's a factory default and a recall for your TV. If there isn't a recall I would call up the company and let them know whats going on. If you just let the problem go on it could either short circuit the TV and break it or Catch fire and burn down your house.
Feb 11, 2011 | Televison & Video
My krups 4055 that is less than 2 mos old suddenly wont brew. it brewed about 2 cups and stopped. water still in resevoir & turning it on & off & unplugging doesn't help.
Dec 13, 2010 | Krups KM4055
TV turns on and off while watching.
re solder the Electronic semiconductor , IC Specialy in power supply side. cold solder might the cause.
Jun 07, 2009 | RCA 27V520T 27" TV
Sudden channel changing,flipping off and on and channel searching
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Apr 21, 2017 | RCA F36649 36" TV
RCA 27V412T
check your tv's power cable inside the tv. make sure its not frayed. also take the batteries out the remote, it could be turning off the tv.
Dec 29, 2008 | Televison & Video
TV turning on and off
Try reset.Unplug AC cord for a few minutes, longer,if doesn't work.plug back in--try again.
Oct 09, 2007 | RCA 32V420T 32" TV
RCA 27V412T
ok! change all tact switches! your tact switch has abnormal resistance! thats why your tv is changing system!
Oct 01, 2007 | RCA F27669 TV
Televison & Video Logo
173 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
