Question about Euro-Pro Shark 9110 Sewing Machine
Bobbin case replacement - Euro-Pro Shark 9110 Sewing Machine
Replace bobbin case
Bobbin case should be standard on that machine if it is a side or front loading bobbin case with a finger
Jul 30, 2013 | Toyota Sewing Machines
Issue with the bobbin case
replace the entire bobbin case
Jan 24, 2013 | Sewing Machines
Bobbin bunching on elna 3230
try changing the needle
rethread the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and that the bobbin case is inserted correctly in the machine
it's also possible that the bobbin case needs to be replaced
also check the bobbin it could be warped
it's also possible that the timing needs to be checked on the
machine
Nov 22, 2012 | Sewing Machines
Bobbin case problems
Oh wow. That's definitely not good. Well you'll need to replace the bobbin case, and needle plate. Even the slightest burr can cause havoc. you could try smoothing down burrs with some fine sand paper but you'll need to replace the case eventually if you can't get this problem identified and fixed.
Next look for a build up or stray threads under and around the needle plate/bobbin area. Make absolutely certain you have the right needles for your machine.
Sep 06, 2012 | Janome Sewing Machines
Singer 7430 bobbin case clicking sound
it's possible that the bobbin case did not get inserted correctly
or it's also possible that the bobbin case needs to be replaced, I've had to replace the bobbin case on one machine.
May 30, 2012 | Singer 7430 Sewing Machine
I can not get the thread from the bobbin to grab the thread
Things to check: 1) is the needle bent? Replace needle. 2) Do you have any lint/dirt in the bobbin case or the race (where the thread catches)? Clean the bobbin case. 3) Make sure that you are using the correct bobbin for your machine and that it is installed correctly. 4) Check that the bobbin case tension is correctly set. (For some machines this is easy. If the bobbin case can be easily removed, hold onto the bobbin thread and dangle the bobbin and bobbin case assembly. Additional thread should not pull through.)
The bobbin case or race may be damaged. Depending on the brand and model, you may find a replacement at your sewing machine dealer or online. If you add a comment with the your machine brand and model, I may be able to provide additional assistance.
(make sure you hold onto the top thread and have the presser foot down.)
Oct 06, 2011 | Sewing Machines
Bobbin Case cannot be replaced properly
Make sure there is no thread wrapped around the bobbin case retaining pin in the locking groove. This pin is part of the shuttle hook. I am assuming this is an oscillating machine and the bobbin case is removed to install the bobbin.
Jan 24, 2010 | Sewing Machines
Bobbin Casing Replacement
slide de bottom windor under the foot and remove the bobbin casing, the bobbin shoud be inside. repace,it with a full one make sore that cotton runs oposit of the litell cut on the bobbin caing, if is a casing in same machins is only the bobbin. Good luck
Nov 25, 2009 | Rex RX-1804
I have Brother LX-3125. I am using it for the first time. How can I take the bobbin out of the bobbin case. The case has an empty bobbin snapped in.
the lx 3125 has a front loading bobbin case which must be removed by pulling the latch on the bobbin case and thereby pulling the bobbin case from the shuttle.
once you have the bobbin case in your hand, let go of the latch and the bobbin will drop out of the case. you can now wind the bobbin or replace it with a wound bobbin - make sure that the bobbin thread is threaded down the slot in the case and behind the tension spring, also the bobbin should turn clockwise when you pull the bobbin thread when loking at the bobbin in the case.
scott
Jul 26, 2009 | Brother Sewing Machines
Want pick up my bobbin
re-thread the top thread
when putting in the bobbin, make sure you put it in right,
hold the bobbin between you thumb and first finger of your right hand when you pull the thread with left hand it should rotate the bobbin counter clockwise.
If you run your machine all day you need to clean under the bobbin case,
Take the cover plate off, take out the bobbin case and clean under, i take a q-tip with machine oil and rub around the inside of the metal case and around the bobbin case,
replace the plastic bobbin case making sure it's in right, turn the hand wheel by hand, the case should stay still and the inside will move, the needle should not hit anything
put all back together and try again
if the bobbin turns clockwise you are going to have problems
if this helps please rate it
thanks,
good luck
moni
May 09, 2009 | White Sewing White 4400 Computerized...
Euro-Pro Shark 9110 Sewing Machine Logo
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
