Question about Leviton 6215M-I Wall Switch Timer
Installation instructions how to wire the timer?
Wiring diagram sunsmart. I am replaceing a timer swithch of a differnt brand. I have a single pole installation, but the power enters the fixture and then comes to the switch. The diagram in the box...
Sounds like you have the GE sunsmart timer, and are wiring the timer for single-pole.
Following information does not apply to 3-way timer wiring.
Add a comment if you have different timer.
Start with previous timer:
The previous timer was connected to two wires: Hot wire and Load wire.
Hot wire carries power from circuit breaker.
Load wire connects to fan,light, or motor.
How to wire Sunsmart:
1) Only one wire in the electrical box is Hot. That wire is usually black. Connect black Hot wire to timer-black wire.
2) Load wire connects to timer-blue wire.
3) Timer-red wire is capped off for single-pole wiring.
4) Timer-green wire connects to bare copper wire.
5) Timer-white wire connects to Neutral wire. This will power the timer electronics. The previous timer probably had a battery to power timer electronics. Neutral wires are white wires that are twisted together and covered with wire nut and pushed to back of box.
6) If box does not have Neutral wires, then connect timer-white wire to bare copper ground wire until neutral wire can be run from any nearby outlet box.
7) Try the timer, and if timer does not work, then reverse timer-blue and timer-black.
Resources:
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 01, 2011 | Hardware & Accessories
Need wiring diagram
Open following link to identify timer:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#6230
Leviton 6200 series timer replaces single-pole switch. Will not work for 3-way or 4-way applications.
Timer has 4 wires: Blue, Black, White, Green
Timer Green to bare copper wire.
Timer Black to Hot wire from breaker.
Timer White to Neutral wire from breaker. Neutral wires are white wires that are twisted together and covered with wire nut pushed to back of box. If box does not have neutrals, connect Timer white to bare ground wire.
Timer Blue to Load wire.
If timer does not work, reverse Timer Black and Timer Blue.
Apr 10, 2011 | Leviton 1000W / 20A 1HP-120V - 6230M-A -...
My wall box only has a black & a white. Can I still use this timer?
You posted under GE 15069.
If you have different timer, then add a comment.
Yes you can use this timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#15067
Here are wiring instructions
Timer might have blue wire instead of red wire.
Some timers do not have green wire.
How to wire this timer:
1) Green wire connects to bare copper wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This will power timer electronics.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any
Jan 13, 2011 | GE 60minute Automatic ShutOff Timer Switch...
I have connected the timer to the power source etc as directed. The red light comes on, indicating there is power--my model does not have a timer "on/off" switch so I cannot begin programming,...
You have to identify timer.
Say which buttons are on timer face and what wires the timer has.
What red light comes on?
Add a comment with specific information so I can identify the timer.
Intermatic, Brinks, Aube and UPM timers wire differently than other timers.
Swylightlight, Wattstopper, Leviton, Lutron, Woods, GE, Utilitec, Hagar, Sylvania, Westek, Intermatic (no battery) are generally wired in following manner:
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect to timer-black-wire and timer-red-wire (sometimes this is blue wire). Choose either wire for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white wire to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground wire along with green wire.
5) Turn on electricity, and push ON-OFF button, or activation button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
If timer is wired correctly, and timer does not work, then timer is defective.
If you do not want free help, then take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 01, 2011 | Hardware & Accessories
Timer has 4 wires Blue, Green White and Black but wall switch only has black and white. where do I connect all the wires?
You are replacing a single-pole switch that has two wires.
You posted under UPM timer.
But UPM timers have a red wire instead of a blue wire, so you have different brand.
Some GE programmable timers and some Leviton timers have a blue wire.
Here are instructions:
-Green wire goes to bare ground wire.
-Timer black wire goes to black wire
-Timer blue wire goes to white wire.
-Located in back of electric box are white wires twisted together and covered with wire nut. These are neutral wires. Timer white wire connects to these wires. This will power electronics inside the timer.
-If your box does not have white neutral wires described above, then connect timer white wire to bare ground wire along with timer green wire.
-Turn power ON, and push on-off button. If timer works, then it is wired correctly.
- If timer doesn't work, then reverse Timer blue and Timer black wires.
- If lights blink on-and-off, then you connected white wire incorrectly, review wiring shown above.
If your box does not have neutral wires or bare ground wire as described above, then buy Walmart.s Brinks 46-1022 or Intermatic ST01C or Intermatic EJ500 or Aube T1032. These timers do not need neutral or bare ground wire.
Dec 31, 2010 | UPM Programmable Wall Switch Timer
I the manual wiring doesn't match what I have in the switch box. This switch is to operate 2 outside porch lights., previously wired to a single pole switch as follows.. one black wire to one screw and 2...
I test these timers.
GE 15071 timer has internal clock that runs on electricity. That's why timer has extra wire.
Intermatic, GE, Tork, Leviton, Sylvania, Woods, Utilitec etc in-wall timers each wire the same way.
The only tiny difference is GE doesn't have green ground wire.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Here's what to do:
1) Old switch has two screws (excluding green ground screw)
One screw on old switch has 2 black wires >> these are hot wires > timer black wire connects to these hot wires. This will power the timer.
2) The other switch wire connects to timer red wire. This will send timer signal to lights.
3) Timer white wire is for the timer clock.
Timer white wire connects to other white wires that are twisted together and covered with wire nut >>> these are neutral wires, and now timer clock will operate
4) For EZ connection to other white wires, strip back another inch on timer white wire so stranded wire can wrap like a candy cane around solid copper wires. Then twist wire nut on very tight.
5) When wiring is complete, push door on timer for manual override. Lights should turn ON-OFF. If lights do not turn on, reverse timer red and timer black wires. Make sure outdoor bulbs are working.
Add a comment any time
Dec 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
GE smart digital timer was installed according to instructions. Timer was set to turn lights on at 5:30, and the lights blink on and off but will not stay on. I tried reprogramming, but same result. ...
It sounds like wiring is wrong.
If you have GE Tork Intermatic UPM Woods Brinks Hagar Pass-n-Seymour Stanley Westek in-wall timer, with red, black, white and green wires, then you probably put red and white wires together.
Add a comment any time.
See instructions along with image at following link:
Heres how to wire timer
5) Turn on electricity, and push ON-OFF button > with GE timer, door is push-button switch. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Dec 11, 2010 | UPM Programmable Wall Switch Timer
Flickering bulbs
You posted under EJ500 Intermatic battery-operated timer.
If you have different timer, add a comment.
I have tested EJ500 timer.
A) If this is new single-pole installation and lights click on-off when timer turned on, then you connected red wire where blue wire should be connected.
Manual says for single pole switch:
Timer-black-wire to Hot; Timer-blue-wire to Load (lights)
Here's how to wire timer correctly:
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-blue-wire. Choose either one for now.
3) Put wire nut on red wire.
4) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-blue and timer-black wires.
B) If you are replacing 3-way switch, view wiring diagrams shown on link below, and then add a comment saying exact color of wires. To wire this timer for 3-way can require additional wire between switches. This is because EJ500 blue wire must always go to Load (light, fan, motor)
http://waterheatertimer.org/ST01C-program.html#EJ500-wire
C) If this is older timer that stopped working, check your bulbs. Then check timer battery. Manual says if timer stops working and bulbs are good, and battery good, then reset timer and reprogram. How to reset timer. Press reset button while holding down Next/ON-OFF button.
EJ500 manual has long list of programming instructions: Add a comment if you forgot parts of programming.
EJ500 manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej500c%20-%20english.ashx
Nov 28, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Timer was connected with all wires correctly. On/Off button is lighting up red, but does not turn light on or off. Directions said try switching switch from off to timer, but unable to locate switch. ...
Woods timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Scroll down page to make sure your timer is shown.
You posted under Woods 59018-59028
GE 15086 timer has OFF-Timer switch
http://waterheatertimer.org/images/GE-15086-programmable.jpg
http://waterheatertimer.org/Programmable.html#Aube
Add a comment to identify timer, and I can help more
Double-check wiring:
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
Nov 22, 2010 | Woods InWall 7 Day Digital Programmable...
Need connection diagram Thks
The following diagram is for timers with green, black, white, and red wires:
If your timer is different, add a comment with model number.
Manual says:
Timer-black-wire to Hot; Timer-red-wire to Load (lights)
Timer-white-wire to Neutral.
Here's what to do
5) Turn on electricity, and push manual override button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 14, 2010 | Woods 59007 Decora Style 3015105 Minute...
Leviton 6215M-I Wall Switch Timer Logo
19 people viewed this question
Top Leviton Hardware & Accessories Experts
Hippy_dd
Gene Haynes
Are you a Leviton Hardware and Accessory Expert? Answer questions, earn points and help others
