Question about Whirlpool WFW94HEAW Duet Energy Star Qualified Front Load Washer With
What seems to be drain water is backing up into tub. Machine installed about 14 months ago, and this has just started to occur, usually when some time passes between loads.
SOURCE: Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Posted on Jan 09, 2008
SOURCE: LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
Posted on Jan 30, 2009
SOURCE: F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?
Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Posted on Feb 08, 2009
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Posted on Jul 04, 2009
SOURCE: Getting HF error, on Whirlpool Front load washer
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Posted on Mar 22, 2010
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Apr 12, 2011 | Estate TAWX700JQ Top Load Washer
Mar 21, 2011 | Washing Machines
Jan 24, 2011 | Washing Machines
Dec 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Jan 28, 2010 | Whirlpool GHW9300 Duet Washer
Mar 14, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Mar 14, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Jun 23, 2008 | Whirlpool 24 in. DU1055XTP Built-in...
Dec 21, 2007 | Admiral AW22 Top Load Washer
Apr 20, 2018 | Whirlpool Washing Machines
88 people viewed this question
