Question about Stanley Tools Hammer Staple/Tacker - PHT150C
Directions to use a stanley 10 -480 - Stanley Tools Hammer Staple/Tacker - PHT150C
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Dec 10, 2015 | Stanley SHARPSHOOTER HEAVY-DUTY STAPLE GUN
HELLO, IS THERE ANYWHERE TO DOWNLOAD A OWNERS MANUAL FOR A STANLEY PREMIER 4100.43 GARAGE DOOR OPENER THAT YOU KNOW OF?
http://www.garagedooropenerguide.com/stanley.html
Not great info, but there are links to email the remnants of the Stanley Garage Door company (the companies using the Stanley name went bankrupt), as well as some links for parts.
There is also this link for Stanley Garage Door manuals from the page above: http://www.aaaremotes.com/stowma.html
Feb 28, 2011 | Stanley Garden
My nailer doesn't have the power it used to.
This is usually a sign that there is an air leak. Check the link below for directions to a site with both parts and diagrams. That should be helpful in replacing the O-rings. This is relatively common and a normal wear and tear condition.
Dan
Link: http://www.fixya.com/support/r5812776-bostitch_nailgun_dis_assembly_assembly
Nov 14, 2010 | Stanley Bostitch N80s Nailer -rebuild...
I cannot open the Stanley FatMax Retractable Knife. The directions do not show how the blade is installed.
Try this website and scroll down to product description...
http://www.amazon.com/Stanley-10-777-Locking-Retractable-Utility/dp/B00009OYFP
Jan 30, 2010 | Home Fencing
Directions on how to use a square to cut common rafters we have a stanley squ and no manual, on use
A standard square is used primarily for drawing 90 degree angles. Simply hold the fat side of your square firmly against the length of rafter. The skinny side of the square should be lying accross the rafter, forming a 90 degree angle with the side. Use a pencil to draw a line along the edge of the square and use this line as a guide while sawing the rafters.
Sep 27, 2009 | Carpenter Stanley 45-500 Handyman Steel 's...
Have a stanley tre550 and need to know how to use
The staples are NOT loaded on top of the pull out shaft; they are inserted directly into the slot that opens when you pull the shaft out. If the nose of the tool is not placed firmly against a surface, it will not fire. Go to Stanley’s website’s knowledge base and type in the model number, and you can get a PDF of directions. http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm Below is the graphic from their pdf. Here is a step by step: Unplug the tool. Squeeze the end of the shaft at the rear bottom of the tool and pull out the shaft. Flip the tool over on it’s back. Insert the staples, (points up) and then slide the shaft back in. Plug it in, press the on button (under the the power cord in the back). Press the nose squarely against the material and press the trigger.c901269.jpg
Mar 29, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
Dont know how to use
Here are instructions to get the manual for this sensor:
Go to:
Stanley Support
Click on the "Knowledge Base" link.
When the window opens type 77 115 in the search block and click on "Search". (NOTE: Leave a space between 77 and 115 or this will not work.)
The Instruction manual should be on top of the list that appears.
Click on the link under the "Article Name". (77-115 Intellisensor Plus Instructions)
On the next window click on the small icon under "Format". That will open up a PDF file for you. Save it to your computer for future use.
If you have any trouble, just comment back.
Thanks for using Fixya.
Mar 24, 2009 | Stanley 77 115 Intellisensor Plus Stud...
How to basically operate my stanley fatmax, TLM100. The directions that came with it were for another Stanley product. Thanks,Ralph
Press the red button - (distance) you will see a red dot on the wall you are measuring - then you will hear a beep - release the button and read the display - the measurement should be displayed and accurate within a quarter inch.
Nov 16, 2008 | Stanley 100 ft. Tape Measure, FatMax
Stanley Tools Hammer Staple/Tacker - PHT150C Logo
15 people viewed this question
Top Stanley Hand Tools Experts
Jim Thurston
Ivan
Ivan
Level 1 Expert
Don Numinen
Don Numinen
Are you a Stanley Hand Tool Expert? Answer questions, earn points and help others
