Question about Vehicle Parts & Accessories
Kawasaki mule 2012 4010 aftr running few minutes temp light will start flashing and efi light comes on then rpms just at idle
I was in it the other day a hose came off of engine lost wtr. idled for about 10 minutes repaired hose and now it starts great but you run for a little while the temp light starts flashing give it gas and efi light comes on
    Sergeant:
  • 344 Answers
The thermastat is probly stuck shut replace it with a new one if problem still persist you may have engine damage aka cracked head ect
Posted on Apr 29, 2014
3 Suggested Answers
SOURCE: rattling in engine bay
check your belts and the bolts around that area, sounds like loose bolts causing something to move and rub
Posted on Aug 05, 2013
  • 57 Answers
SOURCE: #1cylinder not firing on 2003 3010 Kawasaki mule
if its firing ok on other cylinders, unlikely to be pump or fuel filter, focus on electrics, plug, ht lead etc
Posted on Dec 08, 2013
Kawasaki mule 2500 keeps running temp
go to TRACTORBYNET.COM enter OVERHEATING MULE in the question block. there is a forum on this problem, and may as well register.
Oct 05, 2015 | kawasaki Motorcycles
2011 Kawasaki Mule: Loses power when it warms up. even in cold weather. further you push the gas pedal less power it has.
If you have a vent hose coming out of your gas cap make sure it is not kinked. A kink in the hose will cause a vacuum in the gas tank and very slow gas delivery to engine, which would become apparent at higher engine rpms including after warm-up.
Mar 17, 2014 | kawasaki 2011 Mule 610 4x4 XC
After running for a few minutes temp light will start flashing when u give it gas efi light comes on and will only idle
There are a few things that can cause this problem, though with it giving temp indicators and fuel problems I would look at things in the following order:
Fuel filters-Check the pickup screen on the pump first, then any in-line filters along the fuel line.
Oil levels-make sure your motor is properly filled with CLEAN oil. If you are running low, you will get friction which will cause heat buildup and can wear the motor out.
Injectors-Run some SeaFoam through the engine if the fuel filters are clean. With any vehicle that sits without regular usage, debris can foul the injectors.
Spark plugs-If your plugs are fouled our burnt out, you'll get improper ignition and pre-detonation or post-detonation. This is VERY bad for your motor.
Ignition timing-if the motor uses a rotary distributor for ignition, ensure the timing is proper.
Feb 08, 2014 | 2003-2007 Kawasaki Kaf620 Mule 3010 4x4...
Kawasaki mule problems
sounds like its going into limp mode. have codes read as it could be one or more of many possible problems
Feb 08, 2014 | Vehicle Parts & Accessories
22re starts good but after a minute starts to lopes
surge, lopes, hunts, all same. but does it do this hot/cold or both engine temps.?????????
Im and expert on this.... done many and is related to EFI fuel controls
big time..... (ive even programmed Megasquirts to do this)
first the rules then causes.
Rule 1, The EFI controls idle at all times. so that proves.
Macro reasons.
1: EFI lost control. (stuck ISC?)
2: Engine is missiing (too rich, too lean or never tuned up)
3: or both, usually #2 causes 1 ,
there are ways to solve this riddle
my ways are simple
i test the ISC, see if it works, (unplug it or power it with 12v power supply, ) Id clean the ISC first.
this old car 1992 , scan tools are hard to find for OBD1 cars.
so cant look to see if CLosed loop is working, I can with a scope
but you dont have a scope.
you could put in the diagnostic check jumper and hope for an error code to flash out.
you can look as spark plugs (newones work wonder) and see
if its burning fuel correctly (like old school carb days)
black?> white tips>
all engine carbs and EFI all will surge when lean,.
all, and on EFI it will in fact try to stop the surge,
if lean enough the EFI can actually make the surge worse
is it tries desperately to correct the impossible.@!
that be surge.
i learnd that loping my mule one day.. LOL
Jan 21, 2014 | 1992 Toyota Pickup
Kawasaki Mule bleeding coolant causing problems
Its probably the head gaskets. When you do the compression test its not running and the holes in the gasket could seal up. When it gets hot a hole could appear in the gasket or even a crack in the head.
Its clear from the rising coolant levels that something is putting pressure into the coolant, do the bubbles in the coolant smell of fuel?
Dec 22, 2013 | kawasaki 2005 Mule 3010 Trans 4x4
Why does my Kawasaki mule 3010 stall and then won't start for about 10 minutes
Have your fuel pump checked. The wires on mine were melting due to the regulator attached the pump being bad so when the mule would first start it would run fine until it warmed up and then no gas once the wires warmed up. Don't buy the Kawasaki replacement unless you want to pay $300 or more for the part (They are crazy over-priced on parts) and labor. Got a 3rd party pump for $50 and had it replaced for one hours labor and we are good to go. Worse case next time around I buy another $50 pump and replace it myself
Aug 14, 2012 | kawasaki Motorcycles
I have a Kawasaki Mule 3000. It is hard to keep
take the spring off the screw and use teflon tape so you can adjust the screw further
Sep 11, 2009 | kawasaki Sport & Outdoor - Others
Electrical Questions Caponord Rally Raid
which gave me the following faul codes P0353 Ign coil 3 malfunction and P1357 Ign coil 3 Short circuit to vbatt/over temp I then started up the bike and the EFI light was flashing again. On checking the sensors page of Tuneboy it showed coils 12 & 4 with a dwell reading of 2.1-- whilst idleing but coil three would sit around 2.1 but would then drop right down to 0.4 for a few seconds before coming back up to 2.1ish. So the questions are, what does short circuit to vbatt/over temp mean? I assume that the fault codes and EFI light flashing are connected with the fluctuation of the dwell reading on coil three? Does this mean that coil three is on its way out and that I should order a new one? I should add that the bike is running fine. My main concern is that in two weeks time I'm taking the bike to France for 2 weeks / 2000+ miles and don't want to have coil problems whilst away. On a different subject (although still electrical) can anyone tell me the colours of the tacho feed wire, I have studied the diagram from the Caporider site and in my handbook but still can't find them,I had two coil failures. Both of them exhibited extreme dwell variance.,,,
Nov 10, 2008 | 2004 Aprilia Caponord Rally Raid
Vehicle Parts & Accessories Logo
157 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
