Question about Sharp LC-46D64U 46 in. LCD HDTV
After replacing power supply is there a reset
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
Will not start
smor4u,
There is no reset or fuse to reset. You may need to get replacement power supply. If the computer is plugged into a power strip or surge protector you can bypass it and plug the system directly into a wall outlet and power up.
Power Supply Light-on the back of the computer.
The light is a Green Light by the power supply.
Power Supply light is lit by a signal in the power supply called Power_Good (PG).
If the Power Supply Light Led is not light up, the power supply is defective.
If you need to replace the power supply you can contact the Dell Spare Parts Department at 1-877-717-3355bsat4ube4gblqiaaaaasuvork5cyii= or click the link below.
Dell Spare Parts
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 15, 2013 | Dell Vostro 420 Desktop Computer
Vizio hdtv went POP then black while watching a program. Reset did not help.
sounds like a power supply failure open the unit and inspect the power supply for any damage type bad capacitor into google and look for any bad caps on ur power supply
replace them
if all else fails replace the power supply
please make sure to disconnect your tv from the mains and wait at least half an hour before doing any kind of work to it as it may still hold a charge that could harm you
May 15, 2012 | Vizio L37hdtv10a L37 37" 720p Lcd Flat...
C6400
C6400 Zero-crossing signal problem
• The engine PWB does not detect the
zero-crossing signal for the time
specified below.
At power-on: 3 s
Others: 5 s
Causes: Poor contact in the connector terminals.
Remarks: Check the connection of connectors YC7
on the engine PWB and YC2 on the power
supply PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
Causes: Defective power supply PWB.
Remarks: Check if the zero-crossing signal is output
from YC2-11 on the power supply PWB. If
not, replace the power supply PWB.
Causes: Defective engine PWB.
Remarks: Replace the engine PWB if C6400 is detected
while YC2-11 on the power supply
PWB outputs the zero-crossing signal.
Feb 04, 2011 | Kyocera Copystar CS-1820 Black and White...
I too have a similar problem. The LED on the motherboard is on when power is applied. I think I've isolated it to the front chassis power and reset switch combination. The reset switch crumbled when I...
Both the reset and power switches are normally-open, momentary contact to operate. If you twist the reset leads together, it's the same as permanently holding the motherboard reset button pressed. You don't need the reset button in any case, so you don't have to worry about replacing the switch.
The LED on the motherboard indicates the presence of standby voltage, so the power supply is working to at least that degree. The power switch is only a signal to the motherboard to turn on the power supply and start the rest of the system operating. So if the system doesn't come on when you press the power switch, either the power supply is bad or something is preventing the motherboard from starting properly.
A quick test of the power supply is to ground the PS_ON pin in the output connector:
Unplug the connector from the motherboard and use a piece of wire or a bent paperclip to short the pin marked PS_ON to the ground pin on either side in the same row (not across to the other row, which is the standby 5-volt pin!). If the power supply is working, it will turn on and its fan will start running. This doesn't mean the supply is 100% good, but if it doesn't start with this test you certainly need to replace it.
If the supply starts this way but not when it's connected to the motherboard and you press the power switch, then you'll need to figure out why the motherboard's not starting. There may be something wrong with the board itself, or something connected to it is preventing it from starting. Removing parts and parts substitution will help you find the culprit.
As far as getting a replacement switch assembly, you might try Gateway support to find the assembly part number and see if they offer it for sale, or check eBay. Or you can try replacing the switch by itself. On some assemblies the switch is just held into the bracket by tabs, and companies like Digi-Key and MCM sell suitable replacements.
Jan 18, 2011 | Gateway 510 X (10272197) PC Desktop
How do i reset the power supply on my poweredge 2600?
Resetting the power supplies isn't necessary. Once one of the ptwo power supplies fails, the second power supply automatically takes over. Also, there isn't a need to power down the system to change the supplies as long as you change them one at a time.
Oct 12, 2010 | Dell PowerEdge 2600 Server
Tower won't turn on. There is a green light on the back near the power cord that's flashing green.
Pull the power cord out and allow it to reset. If you still have issues you may need to replace your power supply.
Aug 05, 2010 | HP Compaq Presario Media Center SR1750NX...
Computer will not come on when you press the power button after a lightening storm
First check the outlet, power strip, UPS etc. that the computer is plugged into. Many devices have a circuit breaker that will need to be reset after a power surge. Once you establish that you're getting power to the computer, check the power supply on the back of your computer - next to the power cord connector. Many power supplies have a fuse or circuit breaker. If there is no reset function or fuse then you will need to replace the power supply. These are inexpensive, simple to replace, and easy to find on sources such as eBay and Amazon.
I hope this helps.
Bill B
Aug 04, 2010 | Dell Dimension 4550 PC Desktop
DESKTOP WON'T POWER UP
it is your power supply it needs to be replaced
Jan 07, 2009 | Gateway Bestec ATX-300-12EB3 305w Power...
Open Questions:
See all Sharp LC-46D64U 46 in. LCD HDTV Questions
Sharp LC-46D64U 46 in. LCD HDTV Logo
26 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
