Question about Salton Kitchen Appliances - Others
Silvercrest kitchen bread - Salton Kitchen Appliances - Others
Silvercrest bread maker
It's best to follow your manual as there are specific steps to be followed at specific times. First you add liquids (water, oil, etc.), then sugar and salt, then flour and finally yeast as the last ingredient. (Don't let the yeast come in contact with the liquids or salt).
When my wife & I make bread, we usually mix in a little additional bread yeast just to make certain everything g goes well. Make certain your water is at room temperature, not too hot, nor too cold.
Next place the baking pan into the machine, locking it in place.
Plug the bread maker in and you get a signal beep and program 1 appears in the display. You can set the browning level at this time. You can also set a delay for up to 15 hours before starting if you wish.
Press start and the machine starts to mix and then kneed the mix. It will start, stop, start again, etc. Just let it do it's thing until it beeps 10 times and the display reads 0:00.
Take it out, be careful, it will be hot.
I don't know which Silvercrest you have, but if you don't have a manual, here's one you can download. Should be near enough to yours to get you through your first loaf.
data manualslib com
Mar 10, 2014 | Kitchen Appliances - Others
Is my mdl 600-1 a 1lb or 1 lb or 1 1/2-2 lb capacity machine?
The Welbilt ABM3500 can make 1 lb. or 1.5 lb loaves. An on-line manual is available here:
http://www.scribd.com/doc/261890/Complete-Welbilt-Bread-Machine-Manuals
Is the mdl 600-1 made by Silvercrest?
Mar 11, 2011 | Welbilt ABM3500 Bread Maker
I do not know when my bread has finished mixing and i can take it out of the machine and make it into buns? model #k6725 kitchen pro bread maker
It varies for all the different types of bread but basic white bread that takes 4 hours to make can be removed and shaped, roughly about 2 hours after start.
Isn't there a Dough program on your machine that automatically stops when ready?
Dec 18, 2010 | Regal Ware K6725 Kitchen Pro Bread Maker
WE only have a Silvercrest Breadmaker a few months now and the bread sticks to the Kneading Blades and as a result the bread becomes broken when taking it out of the tin, can you please help.
This is very easily fixed. In fact in the instruction manual it suggests you stop it before baking and remove the blades. After almost a year using it, we have further refined this. As soon as 2nd kneading is done, we pause it, remove the blades, oil up hands with olive oil, and shape it into an approximately cuboid shape, before putting it back in the tin and resuming the programme.
From the 2nd time we used it we did the removing the paddles, but with trial and error have found that shaping the bread means you get a much more even loaf, and later that oiling the hands to do this makes it rise much better, as it prevents the dough sticking to the sides, inhibiting the rise.
By the way, the programmes we use most are no. 8 (mostly), in which case you remove the paddles after 70 mins, and no. 2 (occasionally), where you do it after just after an hour.
Hope this helps, it's certainly made it work much better for us!
Nov 17, 2010 | Kitchen Appliances - Others
Ineed the Bread Pan for my Regal Kitchen Pro bread
Call the company listed in your manual. They will have the part you need.
Jan 11, 2010 | Regal Ware K6746S Kitchen Pro Bread Maker
I need instuctions on my Kitchen Pro (Regal) bread machine
You can download afree copy of the manual for your Regal Ware breadmaker by following this link:
http://www.regalware.com/en_lang/breadmakers_literature.htm
Pat Seitz
Director, Communications
Regal Ware, Inc.
Nov 26, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
I need manual and guides for my Regal Bread Machine Kitchen Pro Mod K6743
The manual for Regal Bread Machine Kitchen Pro Model K6743 is available at:
http://d.scribd.com/docs/1w38m5wko9ftv6q3evj4.pdf
Easy to download and print!
I hope this helps.
Nov 14, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Kitchen Appliances - Others Logo
21 people viewed this question
Top Salton Kitchen Appliances - Others Experts
fixzum
Level 1 Expert
Robert Plante
Kolbrun...
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
