Question about Pantech Ease P2020 AT&T
Disconnects call during a call sometimes disconnects
How to reset air bag warning light
I some cars, you have to check the wire under the seat.
Sometimes, it disconnects when the seat is moved ...
Hope this helps.
DD
Dec 12, 2017 | Cars & Trucks
Was hooked on a hotspot with tablet-had to charge now can't get back on it. Can you help?
Reboot. ISP providers change signal strength during the course of the day and sometimes if you get disconnected you need to reset the connection. Easiest way to do it is reboot.
Aug 20, 2015 | Tablets & eReaders
My galaxy mega sometimes wont ring during outgoing calls..then after a few seconds it disconnects
sounds like a network issue, do a factory restore from the settings just to make sure
Nov 01, 2014 | Samsung Galaxy Cell Phones
I can not install my bcd2000 to windows 7. the hardware and softwere
Four things to check:
Sometimes you must leave the device disconnected while installing.
You must turn OFF ALL anti-virus, spyware, anti-adware, popup blockers during install.
Sometimes you have to do the install in SAFE MODE.
Make sure the driver you have is Win 7 compatible.
Aug 10, 2011 | Behringer Control DJ Mixer BCD3000
I changed the belt on the car now radio want come on at all 1995 bmw 525i
Is it possible that you disconnected your battery during the process of replacing the belt? If so maybe that could be a reason that is why your radio does not work. Is it asking you for a code? Sometimes cars will ask you for a code if you disconnect them from power. Let me know, Jeff from fixya
Jun 15, 2011 | Car Audio & Video
Hi need disarming cobra g193 alarm,have keyfobs.almost everytime i disarm alarm door locks start to play up(sounds like them trying open and close open and close) sometimes its even start doing during the...
I would recommend disconnecting the alarm and having it checked out by a qualified installer. It sounds like there may be a problem with the brain of the alarm itself. Disconnecting it will prevent the motors from burning out.
Feb 04, 2011 | Vehicle Parts & Accessories
Disconnecting unexpectedly!
Hello! My recommendation would be to check if the Drive is over heating. Excessive heat could cause the disconnection either for drive protection or because solder points lose strenght. Turn it on, use it a while, right when it disconnects check if its hot. Or try to dissipate better the heat and see if it lasts longer
Mar 22, 2017 | Buffalo Technology DriveStation Combo 4 1...
Error code
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$#%RW
Apr 05, 2010 | Whirlpool RF364 Electric Kitchen Range
Hi i have a 1998 nissan b14 its pulling very lazy and sometimes during accelaration there is a flat spot.. can you help me
if you have a MAF sensor in the air intake system, clean the wires gently with carb cleaner spary and a toothbrush. Disconnect battery for 2 hours. Reconnect and drive for 10 miles till computer relearns clean sensor. may drive rough during this drive.
Jul 09, 2009 | 1997 Nissan Quest
Pantech Ease P2020 AT&T Logo
122 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
