Question about Tricity Bendix Dishwashers
Programme stopping on main wash
When program 2 main wash used it stops about half way, other programs work all the way.
  • 5 Answers
SOURCE: Oh No
ANTI-FLOODING CONTROL SYSTEM ALARM [A L 4] Leds [LD9] + [LD10] This control system is operative during the washing phases only, and not in the water fill phases, in which case is it connected to the safety device (see paragraph 7.4.1 ?Water Fill Time-out?).  A float-actioned mechanical sensor positioned on the bottom of the appliance trips a microswitch which is connected in series to the fill solenoid, thus disconnecting the solenoid.  Intervention of the sensor is detected by the electronic control board, which actions the drain pump for 1 minute, after which an alarm condition is generated. Possible causes: a. Water leakage from the tub/sump seal b. Water leakage from the various couplings (motor, OR on the duct to the upper spray arm, etc.) c. Floating sensor jammed mechanically/microswitch faulty
Posted on Jul 15, 2007
SOURCE: new world DW60-flashing lights
This dishwasher uses the program lights a s a fault code. Usually it is due to food jamming the impeller. If you are competent you can get at it from underneath. Mine was under warranty when this happened and the engineer was heard to say, 'this is a dishwasher not a waste disposal'. The engineer cleared it with a wire coat hanger down the drian hole inside the machine. Not happened since we really scape off plates.
Posted on Nov 01, 2007
murdozzz2
  • 75 Answers
SOURCE: IDL 700
A10 2 & 4 Heating element Open circuit heater
info from idl service manuall
Posted on Feb 29, 2008
  • 210 Answers
SOURCE: Miele turbothermic G 575 SC Electronics problem?
Check the bottom tray of the unit. If water is there and the float switch is activated the drain will run and nothing else. Get rid of the water so the float switch goes off and you should be back in business. If it happens again you may have a leak somewhere and should get it looked at.
Sgt 48
Posted on Jun 04, 2008
SOURCE: dishwasher flashes on Fast Wash
I am hoping I have just fixed mine with same problem. Couple weeks ago started stopping at start of cycle with fast button flashing. Check filters so one on top of unside machine and one on tap if you have one on there. Mine were blocked but still wouldnt work. I pulled out machine to find a kink in the water pipe. I have straightened this out and up to now its working. Fast button flashing refers to water inlet problem.
Posted on Aug 22, 2008
Gorenje washing, why does it stop with 1 left ?
Your NOT suppose to "Program anything". Machines are kinda like people. After they work, they need "some" time to rest. Your machine (And Mine) all do this. Next time leave it alone, the minute will count down and it will automatically shut off. Question? You actually stood by the machine and watched the entire cycle? Was there another problem that motivated you to do this? Like your clothes were still wet or water still in the tub?
Jul 26, 2014 | Washing Machines
Miele washing machine 6065 stuck on main wash programme , unable to clear or reset . any ideas ?
Switch off machine for some time maybe overnight. Press and hold on panel buttons to drain off voltage. when powered hold on start/stop/pause button. If the program does not reset it be fault in the memory or the processor.
Jan 23, 2013 | Washing Machines
Aquacycle 1000 will not operate the 30 minute short programme. Advice please
i think there might be some programming fault .
so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig.
to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash.
to restart the programme from the point at which it was interupteed
press the start/puase bitton again.
Jan 14, 2012 | Washing Machines
The washing machine is stopping half way through any normal cycle, seems unable to spin then stops. the spin is working on a rinse cycle
Possible that the suspect is the main program controller unit. You will need to check the voltage to the motor during the wash and spin cycle.
If there is no voltage then the controller can be faulty.
Feb 05, 2011 | Zanussi Washing Machines
Machine wont complete a cycle, it clicks once then stops
try to preceed manually to next program and if this problem repeat then the timer has problem chang it my advice donot try to select program during electricity connected to timer thank you
Jun 07, 2009 | Whirlpool AWM5145/2 Front Load Washer
Hotpoint aquarius dishwashers keeps stopping half way through wash flashing between the 40 and 60 temp light. How can I fix this please
Control panel is sensitive on this model. Mine did the same and machine would not wash to the programme, stopped half way or would not set at all. Switch off machine and unplug from the mains. Leave for 10 minutes. Plug back in and switch the machine to your required programme. You should find this solves the problem. It worked for me.
Failing that, go to the Hotpoint website, find the customer service number and ask if there is anything else you can do to solve the problem yourself. That is what I did and I followed their advice. It saved me the cost of a service call out and they were very helpful. Good luck
Apr 20, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Aspire 5610-2762 Orbicam not working
Hi uninstall the Cam application software from add/remove programs and reinstall the same .
May 06, 2008 | Acer Aspire 5050-3242 Notebook
Dishwashers Logo
16 people viewed this question
Top Tricity Bendix Dishwashers Experts
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
