Question about RTO Bodyguard T200 Treadmill
Treadmill stopped running and says error 56 - RTO Bodyguard T200 Treadmill
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
What's the problem of error 1 on my york t520i treadmill that stopped working, I need your help please.
Error 1: Speed sensor error Turn the power switch off and on again to reset the treadmill. If the treadmill returns to normal operation, you may continue to use the treadmill. If treadmill does not return to normal operation, then call the dealer for advice.
ERROR 1 CODE This is a safety feature that can stop the treadmill from functioning. This error can occur because the computer is not receiving the correct information from the speed sensor located near the motor. As a precaution the computer stops the treadmill until it begins to receive the correct feedback. By performing a few simple checks, the error can be cleared quickly and easily, and the treadmill can be ready for use. The treadmill does not move and displays "ERROR 1" Switch off the treadmill at the mains, and then switch it on again. If "ERROR 1" still shows switch off and push the running mat round (1 cycle) using your feet. Then switch back on. If "ERROR 1" still shows, then UNPLUG from the mains and check all of the wire connections made during the assembly. (SEE BOLD PRINT) UNPLUG If the treadmill still does not move, then please contact the helpdesk. Doing this may reset the program error, and the treadmill will be ready to use. This should reset the sensor, and the treadmill will be ready to use. Once the cables have been checked, turn on the treadmill again. This should eradicate the problem. 1. 2. 3. When assembling, there are several cables that need to be connected. It is very common for these cables to look like they are connected when they are in fact not fully connected. Make sure that these cables are connected as tightly as possible. The connections may have come apart whilst assembling the treadmill. here is a link to your treadmill web site http://www.yorkfitness.com.au/uploaded/pdf_71T520i%20Treadmill_5562.pdf
Mar 02, 2015 | York Exercise & Fitness
Treadmill triumph 400t has error E1
E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
It is very unlikely the ordinary Jo Blo can fix this problem.
Apr 16, 2014 | Triumph Academy Sports 400T Treadmill
Precor 9.35 Error 5
please see the details and proceed according. God bless you
Dec 12, 2012 | Precor 9.35 Premium Series Treadmill
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Mar 15, 2011 | Matrix T3Xi Treadmill
I have the Lifecore Fitness T900HR treadmill and when my husband is running it stops. We have made sure all the connections are tight even the safety key but it still stops. When I am using the treadmill...
Their might be high friction between the belt and deck thus causing the error 1 code when your husband is on it. Try lubricating the area between belt and deck using silicone lubricant ( refer to owners manual). Then the lighter of the two "aka wife" walk on the treadmill for about 5 to 10 minutes.
This should take care of the problem if not then their is an issue with the belt and deck ( 85% of problems on treadmills are belt and deck related)
Jul 31, 2010 | RTO LifeCore Fitness LC-T900HR Treadmill
RTO Bodyguard T200 Treadmill Logo
21 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
