Question about Cycling
Schwinn 213 resistance tension button do not work, everything else works
Does the schwinn recumbent 270 bike have a battery? It has an AC adaptor. The resistance will not increase when i press the higher resistance button.
It does not have a battery. Your resistance motor is most likely faulty. The only thing is, with schwinn, you will most likely have to replace the resistance motor, the console, and the wiring. All of this is very hard to find and will probably be more of a hassle than it's worth.
Jun 10, 2017 | Schwinn Exercise & Fitness
Owners manual for schwinn 220P recumbent bike
This link will take you to the owner's/service manual for the 220P
http://www.sportsmith.net/images/product_support%5Cschwinn%5Cservice_manuals%5C220%20electronic%20trouble%20shooting.pdf
Mar 29, 2015 | Schwinn Cycling
Resistance does not increase
please read the instruction and fix it. God bless you
Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.Test with the magnet from a refrigerator, If the magnet attract and repulse, is o.k If not replace the magnet.1_21_2013_5_29_53_pm.gif
Jan 20, 2013 | Schwinn 420 Elliptical Trainer
Epic el 2980 tension does not change
If the resistance worked before you moved it to where it is now then it's almost certainly a wiring issue. Make sure that each connection that was taken apart is perfect and that each pin is not bent. Make sure that all of the wiring moves freely and there is no pinch. If all of that is correct then it's most likely the resistance motor.
Jun 18, 2017 | Exercise & Fitness
My schwinn 460 elliptical resistance cannot be changed
see the following details. God bless you
Dec 04, 2012 | Schwinn 460 Variable Stride Elliptical...
Cannot adjust the tension on Schwinn 202. Computer is on but tension will not move up or down
I have the same problem with a schwinn 202 that someone gave to me because the resistance adjustment no longer worked. They were advised by Schwinn that the motor needed replacement, but after testing mine, the problem seems to be a lack of power from the computer to the motor. Schwinn tech support will get a call from me tomorrow.
Nov 21, 2010 | Schwinn Cycling
My Schwinn 430 Elliptical is not changing resistance when requested. I hear a noise as though it is trying to change, but it does not. The resistance level is shown as changed on the display. Is this...
I think I am experiencing the same problem and have removed the shrouds. Are you experiencing a clicking sound while the unit is plugged in? All of this seems to deal with the servo motor. Don't be fooled by suggestions to replace the rpm sensor...this is NOT the problem. I am trying to find out what the initial setting for the servo motor and the tension cable should be. I found a site where you can order the servo motor, but it tells me that it could be months to receive this part. Sigh...
Sep 12, 2010 | Schwinn 430 Elliptical Trainer
Cycling Logo
64 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
