Question about Haier L26B1120 26 LCD TV
How to do a autoscan from the tv not the remote
Want to do a autoscan but do not have a remote
I have a ge universal remote. I've put in all the codes to my tv and none of them worked. My tv is a magnavox mod# 20ms34442/17 can you help?
What model number of the remote do you have? I also have a GE universal remote and I have used it on over 30 tv's and every single 1 worked. Do you do the autoscan or put them in manually?
Dec 30, 2012 | Philips Magnavox 27MS343S 27" TV
How do you autoscan the olevia 232 t lcd hdtv? I connected an antenna and using a uneversal remote. it just sits there displaying 'no signal'
In the remote, select the input as antenna. It might be now lying as some other input. Normally the TV itself searches for channels. If it is not, go to menu in the remote control, select install-auto and press ok.
Jul 04, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Can't autoscan air channels
It is always possible the antenna is the issue but I have a suggestion to at least try.
With the remote direct enter a known channel like 08 enter and see if it goes there. If it does not either the signal or the TV tuner may be the issue---if it does go there you can go into TV menu and should find a add a channel feature--add the ones you want/need manually.
Apr 03, 2012 | Televison & Video
Comcast remote code for sylvania lc427ssx
I had the same problem, I ended up buying an RCA Universal remote, when I had no luck with the codes I tried the autoscan feature, to my surprise it worked perfectly.
Jul 11, 2009 | Sylvania LC420SS8 LCD TV
Duraband tv code needed for a tvrcsat -rs remote
need code for swisstec flat screen 15 inch
Mar 26, 2009 | Televison & Video
AV 35750 no images only sound with cable, images & sound with DVD
Make sure the cable is on when you autoscan. If the autoscan doesn't see it,manually inputing won't get you there. Make sure you have the correct band selected when you autoscan.
Dec 13, 2008 | JVC AV-27D302 27" TV
Olevia tv erased all channels accidently
BEVERLYQC::
How do you " accidently erased all my chanels " from a tv??
Was the TV connected to a 'cable box' ?
Was the TV conected to 'air waves' or antena input.?
If the TV is attacned to a cable box, temperly remove the cable box INPUT wire, attache an antenna to the IMPUT AND AUTOSCAN WITH THE REMOTE CONTROL
If the TV cannot 'autoscan' in 'air wave' reception...goto menu and set input channel to ch.3 or see if there is a switch in the back that can change to ch.3 or ch.4
You should get all the 'air wave' chanels which will include ch.3 & ch.4
Oct 22, 2008 | Olevia LT42HVi 42 in. LCD Television
Haier L26B1120 26 LCD TV Logo
12 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
