Question about Vehicle Parts & Accessories
Change tag light bulb 2003 nissan marono - Vehicle Parts & Accessories
  • 3 Answers
SOURCE: both my rear license tag lights are out How do I change the light bulbs?
if you squeeze the plastic housing around the light they will pop out with little force from the outside. then you just change your bulb and replace
Posted on Sep 13, 2008
SOURCE: how to change tag lights
I had to remove the entire light bar assy by taking every bolt loose to gain access to replace the tag bulbs on my 2000 Buick Lesabre. It is necessary to replace only one bulb so I replaced all bulbs with the new longer lasting bulbs...the bulbs are not expensive just impossible to gain access to them one at a time. It seems like GM made it so you would have to take it into the GM Dealer. A deep well socket makes the task muck easier! Hope this helps!
Posted on Jan 13, 2009
CaptainHawk1
  • 345 Answers
SOURCE: Nissan Sentra reverse light not working
I would attempt to check the fuses.
Posted on Nov 28, 2009
jabbad
  • 17 Answers
SOURCE: how do i change brake
To change any of the three tail light bulbs, open rear hatchback locate the thin black strip (approx. 2"W x 21"L) between the body and the tail light assembly. Next, simply pry off black strip with a small screwdriver wrapped with a rag as to not chip the paint (strip is held on by two clips). Remove the top and bottom bolts (the 2 middle bolts don't need to be removed). Next grab the lens assembly from the top and bottom and gently pull away from the body. Once the lens is separated from the vehicle simply twist the bulb socket counterclockwise to remove the bulb from the lens assembly.
Posted on Sep 15, 2010
  • 76 Answers
SOURCE: on my 2003 hyundai accent
It's probably faulty wiring, when you get into an accident it messes with everything, they're probably disconnected and not getting any power. Try checking them or getting a mechanic to check em for you.
hope it helps
Posted on Dec 13, 2010
How do it the screw out to change tag light?
most cars , lamps are covered in the operators guide.
http://justgivemethedamnmanual.com/nissan/nissan-quest-owners-manuals/
i looked, it shows a photo of all lights, tells how to replace all lamp
and skips, license plate lamp.
Nissan mess up.
what would i do , FSM free.
iD , remove the license plate. then gander there, see more screws
remove those, bingo.
on some cars you must remove screws from inside door (hatch)
ill stop there.
case in point, my jeep the whole assmbly must come off
and acess to rear to bulb..... i start from easy and work to hard, no books.
Jul 05, 2014 | 2007 Nissan Quest 3.5 Minivan
My car 2003 altima I need change light bulb. need know how to remove head light to change the bulb.
You don't have to remove the headlight to change the bulb. The bulb can be removed from the back of the headlight, usually by turning the bezel ring that holds the bulb onto the headlight housing. Just make sure you do not touch the glass part of the bulb while replacing it or it will burn out again fast.
Jan 27, 2011 | 2003 Nissan Altima
Brake lights and tag wont come on .changed bulbs fuses and brake sensor on pedal still wont work-91maxima
Check the ground connections. I've had good bulbs that didnt work because there was a bad ground leading to the bulbs socket.
Apr 26, 2010 | 1990 Nissan Maxima
Change tag light on chevy cobalt
the bulb would be less than 5 bucks
Feb 11, 2010 | 2003 Chevrolet Malibu
How to change parking light bulbs on a 2003 nissan frontier? Do I have to take off the bumber to get to the screw that holds the light component?
2005 Nissan-Datsun Truck Pathfinder 2WD V6-4.0L (VQ40)
REMOVAL AND INSTALLATION OF FRONT TURN SIGNAL/PARKING LAMP
Removal
NOTE: Reach through engine room for bulb replacement access.
  1. Turn the bulb socket counterclockwise to unlock it.
  2. Pull the bulb to remove it from the socket.
Installation
Installation is in the reverse order of removal.
CAUTION: After installing the bulb, be sure to install the bulb socket securely for watertightness.
Dec 23, 2009 | 2005 Nissan Pathfinder
Nov 28, 2009 | 2003 Nissan Sentra
I need to change the break light on a nissan xterra 2003
I have never seen a car with a break light. Does it come on when the car breaks? See owners manual to change a stop light bulb that comes on when you step on the brakes.
Jun 05, 2009 | 2003 Nissan Xterra
Both my rear license tag lights are out How do I change the light bulbs?
Aug 30, 2008 | 1999 Chevrolet Blazer
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
