Question about Lemond Revmaster Pro Pilot/Pilot II Cadence Meter
Lemond Revmaster Pro Pilot II won't connect - Lemond Revmaster Pro Pilot/Pilot II Cadence Meter
I have an lemond g force rt error code 25? Does anyone know what that code means?
I cannot find a list of Error codes published in any of their seemingly extensive maintenance manuals. Lemond does have a rather good warranty system. I would contact the manufacturer directly. Here is a link to the manuals for your machine: force UT Tech Support
Aug 30, 2015 | Office Equipment & Supplies
Tip
How to adjust the seat on an indoor cycle
Video of How to Adjust the Seat on your Indoor Cycle
  • This video will demonstrate how to adjust the seat on your indoor cycle properly
  • Tools needed:
    • Adjustable Wrench
  • To begin loosen the nuts on each side of the seat equal turns
    • Ideally, there should be equal portions of the clamp bolt exposed on each side
  • Once you have them loose you can adjust the seat back and forth on the mounting rails as well as adjusting the angle of the set
    • The best position for the seat is level and in the center of the mounting rails adjustment
  • Once you have the seat positioned as desired finger tighten the nuts on each side of the seat equal turns and then tighten the nuts using a wrench an equal number of turns as well
    • Again, the goal is to have equal portions of the seat clamp bolt exposed on each side
  • This is all that is required to adjust the seat on your indoor cycle.
on Jun 06, 2016 | Lemond Revmaster Revolution Trainer
Tip
Tip for Easy Installation of the Bottom Bracket Spindle Shaft for a LeMond...
When installing a new bottom bracket spindle shaft onto your LeMond RevMaster Classic indoor cycle, it is important that you note which way it is to be used by looking at the spindle closely. We've learned a tip that makes for easy installation and that is a quick measurement will determine the proper orientation of the spindle.
  • The spindle has different lengths from the edge of the raised portion to the ends.
  • The measurement of roughly 1-3/4" will be on the RIGHT side and will attach to the RIGHT crank.
  • The opposite side measures roughly 1-1/2" from the end to the edge of the raised portion, it will attach to the LEFT crank arm.
Easy Install Tip for Bottom Bracket Spindle Shaft to LeMond RevMaster...
on Mar 11, 2015 | LeMond Bicycles Cycling
Life gear exercise bike
This bike looks to be of the Lemond Revmaster series.
first, dial the resistance knob back until the leather break pad is no longer touching the flywheel. Get down on the floor and postion yourself between the flywheel and pedal cranks. Slowly turn the cranks arms and listen and feel for a roughness in the bike.
This has bike has bearings and a belt. It should not make any noise.
Now with the right pedal at a 2:00 position tighten the resistance knob down all the way so the flywheel will not turn. Then get on and push very hard on the right pedal. If the belt is loose, the pedal will move. Austin Fitness Rentals Rent Commercial grade Fitness Equipment in... ">
May 16, 2014 | Exercise & Fitness
Tip
Bottom Bracket & Spindle Replacement of LeMond RevMaster
Part 1 Video Discussing the Dis-assembly & Inspection of the Bottom Bracket & Spindle for a LeMond RevMaster Bike
  • This Part 1 video will demonstrate how to inspect and adjust or remove and replace the bottom bracket and spindle on your Lemond Revmaster
  • Tools needed for this procedure:
    • 8mm Allen Wrench or Socket
    • Cotterless Crank Puller Tool
    • Lock Ring Removal Tool
    • Bottom Bracket Tool
    • Phillips Screwdriver
    • 4mm Allen Wrench
    • Bungee (optional)
    • Rubber Mallet
    • 7/8" Wrench
  • To begin remove the belt cover, there are four screws
    • You will need a 4MM Allen wrench
  • Now remove the two screws on the back from the opposite side of the bike
    • You will need a Phillips screwdriver
  • Now position the crank arm as seen in the video and remove the belt cover from the bike
  • Before removing the drive belt, tighten the brake assembly so that the flywheel is locked in place and loosen the torque on both bolts using an 8mm Allen wrench or socket
    • Do not remove them at this time only loosen them by a half a turn or so
  • Using a 7/8" wrench loosen the belt idler
  • Now use a 4mm Allen wrench to loosen the tension adjustment bolt completely, but do not remove it from the frame
  • Now remove the drive belt
    • To aid in this process you can use a bungee to slide in behind the belt at the top, as shown in the video
  • Then pull away from the bike while spinning the crank arms
  • Now remove both crank bolts with a 8MM Allen wrench or socket
    • Removal of the crank bolt on the left side of the bike is the same as removal from the right side
  • Now remove the crank arms with a crank arm puller, threading the outer portion into the crank arm as shown in the video
    • Be sure to thread the outer portion in as far as possible to prevent damage to the crank arm threads or the tools threads
    • Use a 7/8" wrench to make sure the outer portion is threaded in completely
    • Now spin the handle clockwise to press the crank arm off of the bike
    • Be careful when the crank arm comes off as if you are not holding it, it can fall in the floor
    • Also use the wrench to loosen the tool before removing the crank arm from the unit
    • Now you can unthread the tool from the cranks arm by hand after removing the crank arm from the bike
  • Next inspect the bottom bracket cups for looseness, to do this use the bottom bracket tool by hand to see if you can turn either of the bearing cups
    • To further verify the adjustment of your bottom bracket use a rubber mallet to tap lightly on each side of the spindle to check for movement from side to side, if you have movement, or one or both of the bearing cups is loose, you need to re-adjust the bottom bracket. If you are only inspecting the bottom bracket and did not find any need for adjustment you would re-assemble the bike at this point
  • Once the crank arms are removed look closely at the spindle
    • It should have defined edges and be smooth
  • As you can see by the video our spindle needs to be replaced
  • Next you will need to remove the lock ring
    • The lock ring is around the bottom bracket cup on the left side of the bike
      • In the video is an example of a lock ring
    • To use the lock ring tool you slip it over the lock ring using the three notches and torque the lock ring in the proper direction
      • This one needs to be turned counter-clockwise to loosen
    • Then remove the lock ring by spinning it off the bearing cup
  • Next you will need to use the bottom bracket tool to remove the bottom bracket cups
    • Begin with the left side
      • Slip the tool into the splines of the cup and loosen
        • For stubborn bottom brackets use a 5/16"-24 x 2" bolt and some washers with a 1-1/4" wrench
          • Slip the tool into the splines and thread the bolt with the washers into the spindle
          • Get it snug but not completely tight
      • Now use the wrench to turn the cup counter-clockwise for the left side and remove it completely
    • Remove the cup from the right side now
      • Slip the bottom bracket tool into the splines of the cup and turn it clockwise to loosen
    • If you cannot get the cups loose with this method try turning the bike on its side to get better leverage as shown in the video
  • This concludes the dis-assembly and inspection procedure of the LeMond RevMaster bottom bracket & spindle
  • Click here to see Part 2, re-assembly and installation to complete the replacement procedure
Video of Bottom Bracket and Spindle Replacement Part 1 Dis assembly LeMond...
on Feb 19, 2015 | Lemond Revmaster Lemond G-Force Digital...
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Paper pro generation ii won't staple
you can open this one its ribbet.also not good idea to try it.
can be dangerous.its not worth to loose a pretty face then to by a new one.http://www.ebay.com/itm/Pro-Heavy-Duty-Tacker-Staple-Gun-Insulation-Screening-Upholstery-Stapler-/110746725341?pt=LH_DefaultDomain_0&hash=item19c904ebdd
Jul 26, 2012 | Black & Decker Tools & Hardware - Others
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
Lemond Revmaster Pro Pilot/Pilot II Cadence Meter Logo
49 people viewed this question
Top Lemond Revmaster Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Lemond Revmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
