Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Prints pictures too dark
All of the ink cartridges are full with Epson ink, yet, the pictures come out way "too dark", with some colors not quite right.  I've gone through all of the setup menu items (head cleaning, nozzle check, etc.) and this has not helped.  Help!
II have had the same problem and it relates(at least to me) the type of paper yuo are using and the settings you place on the paper. With high glossy photo paper I was using the setting for that and then I switched to photo and text and set it for plain photo paper.
If that does not work then save the image to a photo soiftware such as windows fax and viewer and print it through that. You can lighten it especially for high gloss photo paper. Good luck This worked for me, The gloss photo settings made all m,y photos way too saturated on glossy photo paper.and much too dark.
Posted on Dec 23, 2007
I just replaced my ink cartridges for my Epson Workforce 600 printer and the magenta and yellow colors do not print. The status shows that both are still full of ink, but when I do the nozzle check,...
Try "Nozzle cleaning" and if the problem persist, try "Deep nozzle cleaning". Try them only once or else the ink will run out very quickly.
If the ink cartridges are not genuine Epson, remove them and buy genuine cartridges. If needed, repeat the procedure with them.
Non-original consumables very often clog the printhead.
Aug 07, 2010 | Epson WorkForce 600 All-In-One InkJet...
Muddy prints
I have the R2400 and the photo prints look muddy. I have tried the same picture on another printer and the colors are vibrant. Why the muddy pictures on such a nice printer?
Mar 23, 2010 | Epson Stylus Photo R2400 InkJet Printer
Epson Stylus Photo 1400 Prints Dark Shadows Red!
Did you use Epson Genuine Cartridges? ????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE
BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 15, 2010 | Epson Stylus Photo 1400 Printer
Hi, when printing the page is full black. After head clean, nozzle check etc still black & nozzle check prints two x dark lines. I changed ink cartridges but no improvement. Thanks, Roger
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
This is the only advice I can give you. If you find this helpful, pls rate me.
Feb 06, 2010 | Epson Stylus Photo 1290 InkJet Printer
I changed the black ink cartridge, and now it prints, but the paper is blank.
Epson Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
Jan 23, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Although the cyan prints on a test print it is not
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, Blue Brown, etc.
Jan 23, 2010 | Epson Stylus DX8400 All-In-One InkJet...
On my Epson 4800 I am getting streaks across my prints when using roll paper. They are side to side streaks of dark ink.
I dont think its the Paper.
Jan 22, 2010 | Epson Stylus Pro 4800 InkJet Printer
R1900 adds blue-green tint to my photo prints
Epson doesn't like Generic Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
Jan 22, 2010 | Epson R1900 Printer
Printing and color issues
Did you use Epson Genuine Cartridges? Brother Genuine Cartirdges????
If you find this information pls rate me.
Thanks and Good Luck.........
P.S.
use Matted Paper for printing, Glossy, does not work well for me.
10 lbs is great.
Jan 13, 2010 | Epson Stylus 880 InkJet Color Printer
Epson c62 color ink cartridge says it is empty when i just refill
I use cheap replacement cartridges about 20$ for 3 color/5 black....the printer usually doesnt recognize the cartridges ink level but it still prints......do you use actual epson replacements? If you use cheaper replacements you might have gotten some with dud chips...prob the cartridges fault, not your printer
Jan 01, 2009 | Epson Stylus C62 InkJet Printer
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
293 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
