Question about Konica Minolta DiMAGE Z3 Digital Camera
Parts battery cover - Konica Minolta DiMAGE Z3 Digital Camera
Canon power shot S2 IS battery cover is broken. I want spare part.
Look on Amazon or Google your camera make and model + replacement battery door.
Mar 01, 2015 | Canon Cameras
The battery cover as bowed i need to keep my finger pressed on the cover to take pictures if i dont keep my finger pressed on the battery cover the camera swiches off
it seems the battery box are a little loose for the battery, you can add some thing(such as small piece ) between the battery and the box to let the battery and camera connect well. Don't block the joint between battery and box is OK
Apr 25, 2011 | Praktica Cameras
I cant open the back cover of my nokia X3
To open the battery cover, you need to first slide the upper part into its designated areas, and then once in, you can then push down the lower part of the battery cover in each cover to lock into place.
Mar 07, 2011 | Nokia X3 Cell Phone
I don,t know how battery cover opens so i can install the batterys,
The battery cover is the bulged part of the plastic, on mine it's a gray color compared to the black body. with the LCD screen to the left and the gray cover to the right, gently press down on the part of the battery cover nearest the LCD screen and press to the right.
That should open it up and get you to the batteries.
Mar 05, 2011 | VuPoint PDSST410VP
How do I install the battery on a Rumor 2?
To install the battery is simple.
Remove the battery cover.
Place the part of the battery that carries the negative and positive part inside the battery space right in contact with the metallic bar that is in the battery spacing on the phone.
Let the metallic bars on the battery make contact with the bars on the phone.
Cover the battery back with the battery cover.
Take care
Jun 30, 2010 | LG Rumor 2 Cell Phone
Unable to pop battery compartnent in Health o meter EVERweigh
The whole top cover which is the part that you stand on (loading platform) comes off. Turn the scales upside down, pull the sides of the plastic cover to unclip the catches and the body can be removed from the cover. Remove the screws to the displlay and there will be a battery compartment underneath the display. Remove the cover to the battery compartment and make note of the battery orientation. Replace the battery in the correct orientation or you will destroy the scales. Repace the battery cover. Scew the display to the body. Press the cover on the body with the display showing through the window.
Jun 05, 2009 | Sunbeam Health O Meter Body Monitoring...
Sony DSC-T70 CyberShot memory/battery cover broken
Yes, why not..
Here is silver color battery compartment part number of DSC-T70
X21866081 ASSY BTH (S)
It is available in Part Store.
Please rate this and previous solution with 4 blue diamonds if you found them correct.
Dec 06, 2008 | Sony DSC-T70 Digital Camera
Battery cover broken
A repair is unlikely without parts, It also depends weather its the part that is actually broken is on the battery cover or the camera itself.
If the camera itself a new case for the camera will be required if the battery cover then a new cover will be needed.
to obtain the spares you have two routes,
a) contact the manufacturer (contact details should be in the manual or on the gtee card)
b) buy a faulty camera from somewhere like ebay and use it for parts
May 25, 2008 | DXG Technology DXG-328 Digital Camera
Dxg 506v
Casio EXZ60 battery cover and battery retainer.
Casio parts center Ph# 800-223.2001
$2.50 for the cover and .50 cents for the battery clip.
It only took 2 days on Internet, 4 trips to camera shops and numerous phone calls to finally win. My parts are on order.
Feb 24, 2008 | Cameras
Battery cover
Sony has bought-out Minolta. Parts for Minolta equipment has become scarce, but try here: http://eservice.sony.com/webrma/web/index.do
Nov 27, 2006 | Konica Minolta DiMAGE Z1 Digital Camera
Konica Minolta DiMAGE Z3 Digital Camera Logo
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
