Question about Conair HC100RCS Hair Trimmer
Trimmer won't turn on seems to have no power
The trimmer is plugged in but won't power on when switch is in on position.
Check spark?
Benjamin, remove spark plug, attach plug wire onto plug, hold end of plug against cylinder head or a metal fastener that you know is going into engine for good ground. Make sure engine switch is in the on position, now pull engine over, observing the gap in plug for spark. If no spark get a new plug and try.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to check for Spark Plug Fire in any engine
How to Check the Spark Plug of Trimmer or Edger
Homelite String Trimmer Won Start No Spark
Jun 17, 2016 | Garden
I have a troy built trimmer model # tb65ss
check the kill switch position and wiring, if good, check magneto wire
Jun 30, 2014 | Troy Bilt Tb70ss Gas Trimmer
Switch won't turn trimmer off.disconnectd spark plug
It sounds like it has lost its ground. Check the wires coming out of the switch. One should go to a ground, this kills the ignition and stops the unit. If the ground wire is good, the switch is bad.
May 15, 2014 | Poulan Pro Pp2822 Gas-powered 22" Dual...
My 2003 Husqvarna 326HD60 hedge trimmer was starting ok, but today it failed to start. They is fuel and the plug is wet, but it appears not to have any spark. The switch is set in the off position, but how...
Put switch in 'on' position, remove the spark plug and connect it to the HT lead and earth out the side of the spark plug, pull over the engine to see if you are getting a spark. Check the timing gap between the ignition module and the flywheel. 0.25 filler guage
Oct 23, 2011 | Husqvarna 28cc Gas Line Trimmer
No spark - coil ???
Could very well be the magnito (coil). You may also want to check the kill switch. If the switch failed in the off position... = no spark. Plug failure could also be the cause, although not likley. Good luck!
Sep 25, 2011 | Homelite Factory Reconditioned 26cc...
Hp pavilion a705w - blue power light flashing, won't turn on
On the back of the power supply there is a 120/220 V AC selector switch.
It's possible that switch got knock on the wrong voltage position.
Pull the power cable. Move the switch back and forth between the two position.
Make sure you leave the switch in the correct selection. 120v = USA
If you have time,open the case and inspect the RAM module(s) and card(s). They can be un-sitted.
plug in power cord and power on the pc.
Jul 29, 2011 | HP Pavilion a705w PC Desktop
YARD MAN 42 '' RIDEING MOWER WON'T START PROBABLY SAFETY PROBLEM
safety switches that all riding mowers seem to have include a seat/brake safety which means that you have to be sitting in the seat or the brake must be engaged for it to start. also there is the blade engaged safety, which means the mower will not start normally with the blades engaged.
if you meet those conditions check the switches themselves
non safety related, do you hear a click or a clunk when you turn the key to the start position, this is the starting coil pulling in to send power from the battery to the engine starter, all safety switches will interupt power from the key switch to the starting coil
if you hear the coil energize and the engine does not start you have low battery voltage or loose connection or some other mechanical problem
Jul 03, 2011 | Craftsman 25cc Gas Line Trimmer
I have a Husq. 326 L trimmer; my pull cord seems to tug and becomes almost unpullable and it wont start; I have a new spark plug-what could be causing this?
Pull your plug back out and see if your cylinder is full of fuel, if this is the case your needle/seat is leaking fuel into cylinder causing hydrolocking (gas won't compress) good luck
May 02, 2011 | Husqvarna 28cc Gas Line Trimmer
I have a Power Glide Cordless String trimmer that will not run. I feel it might be the electrical switch in the handle. It wa only used a couple of times & suddenly quit working. It was opened and the...
O.k. first ... Are you using an exterior plug?? Check and make sure you are getting power to the plug on the trimmer. If so, I would guess that it would be cheaper to replace the trimmer than to go to the manufacturer or a repair shop. If you like to tinker, go to Radio Shack and get a 20 amp rated switch and hardwire the darn thing. If you do something like this, ALWAYS SWITCH THE HOT (BLACK) WIRE!!! Never the white one.
Jun 05, 2009 | Ace Hardware Power Glide Cordless String...
Loss power Trimmer HomeLite UT20002A
Check the muffler for obstructions. Remove the muffler and check the exhaust port sometimes they are near plugged. If so remove all the crud with the cylinder in up position to prevent getting carbon in cylinder. Trimm to adjust Turn both L and H set screws clockwise until they bottom the back each one out 1 and 1/4 turn. This should allow you to start the trimmer. Then rev to max rpm and adj. the H screw to max rpm. Then set the idle with the L screw with good idle without string head turning. Then when throttled it should do so without hesitation. Once this is set you may have to fine trim the H screw for max rpm again.
Mar 12, 2008 | Washing Machines
Conair HC100RCS Hair Trimmer Logo
51 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
