Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Fuse blows after about 50-60 seconds
Please help
  • 372 Answers
Hi.
If the motor is not smelling of burning or making strange noises I would think you have a problem with mains lead having an internal short circuit. Replacing mains lead should sort this.
If motor is smelling or not sounding correct then you need a new motor.
http://dysonmanuals.inc.io/
Posted on Oct 28, 2007
DYSON DC19 Lost half power at the source. No blockage, clean filters, turbo head clear which has stopped spinning. Barely used. Can the motor half blow? It is still drawing 1400 W on a power meter in...
Hi Peter, it's Jack at Dyson.
I'm sorry to hear your DC19 isn't picking up as well as it should be. Have you washed the filter recently? We recommend washing it at least once every 3-6 months using cold water without detergent. Make sure the filter is completely dry before replacing it, which could take at least 24 hours:
If the filter has been washed, it's likely that there is a blockage somewhere in the floor tool, wand or hose that you may have missed. I appreciate you've already checked for this, but our support guide will walk you through the steps needed to locate and remove any obstructions: http://www.dyson.co.uk/support/dc19t2/dc19t2/my-machine-is-not-working/check-extension-tube
If you've followed all of these steps and have not resolved the problem, please contact our experts directly so we can help. You can reach the Dyson Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 04, 2015 | Dyson Vacuums
I have a Sebo Automatic X1. It had been working well for years. Suddenly last week it blew the 5A plug fuse. I replaced it and that also blew. Do you have any clues?
You are correct!
The smaller PCB is a voltage regulator!
Is actually one of the condensers who shorted out but will be very hard for you to actually find and replace it !
You can find it the "old fashion way"!! by puling the fuse out and using a screwdriver (make sure it have an insulated handle!) short out the ends of the fuse holder for 1-3 seconds. The part who is shorted out will start to smoke out . You replace that part or preferably the entire board .
Dec 07, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Why is my VAX 121 blowing my fusebox ?
"Blowing" FusesWhen a fuse blows, replace it with an identical [same Amperage rating] new fuse.
IF the replacement fuse also blows, then that is an indication that there is either a short circuit condition in that circuit, OR you have an overload condition due to too many electricity using devices connected to that circuit, or one that draws too much electrical current [current is measured in Amperes (Amps), or milliamps (thousandths of an Amp)].
The fix" for repeatedly blowing fuses is to troubleshoot the circuit involved, find and identify the fault, properly repair it, and then install another good fuse
Jun 25, 2014 | VAX Appliances Vacuums
I have 2 cotton candy machines. One says 25 amps and the other says 30 amps on it. I would like to take either one of them to parties at people's houses, but am afraid of blowing fuses. Is there...
Hi marieu2005..
The only way to avoid blowing breaker or fuses is to ask the person do they have an available 25/30 amp socket, and you need it to fit the plug you have on your machine.
Please take time to rate me
Sep 02, 2011 | Vacuums
Shredder does not power on
Good day!!!!
please try to check the plug if it is OK..
Then look for the fuse if busted...
If the fuse is busted look at the fuse if only disconnect the wire inside so that you can determine the cause of blowing of fuse..if the fuse is dark or have color black inside your machine have a short circuit..if not got fluctuate high current in split second (that is normal)..just replaced the fuse with the same type and ratings..
If the fuse always blows after power ON your machine need further repair it have short circuit..
Thanks for using fixya...
Aug 10, 2011 | Vacuums
I have a Husqvarna Viking Designer sewing machine. The fuse blew in the machine and I am having trouble finding a replacement fuse. It is a T3.5/250v glass fuse. Please let me know where to find one. I...
That fuse will work no problem. There is no harm in trying it.
The machine probably requires about 2 amps or less under normal operation.
Being a 3.0 amp slow blow fuse, it will withstand short bursts of extra current when your machine gets temporarily overloaded.
Just make sure the machine is properly lubricated and runs freely. The fuse will definitely blow if your machine should get jammed or something like that.
I think I know where I can score some. Cost of postage only. :)
Email me if you like.
Subject: T3.5/250v glass fuse
faxmando@yahoo.com
May 31, 2011 | Vacuums
My daughters X-Treme Scooters | X-360 - 350 Watt Electric Scooter - Pink the fuse keeps breaking or blowing in it. Do you know what could be causeing that? Please help she really loves her scooter and we...
Hi, be sure you are using the right amperage fuse in it. Check any exposed wires on it they may have got skinned up, causing a short and blowing this fuse. You say it gets hot when she gives it full power, so its blowing when its drawing the most amps under this high load. Check all of the connections at the batterys to make sure all connections are good and tight, this is very important on any thing that is electric. Good Luck,
Shastalaker7
Apr 10, 2011 | Vacuums
When you start up the microwave oven it blows the power throughout the house.
You must have a faulty magnetron or a capacitor that is short and so blows the fuse or trips the circuit.
You need to open the cabin to check the short on the capacitor, remove wire in the HT and check.
Please attempt only if you are familiar, if not take help/
Mar 02, 2011 | Vacuums
It will not turn on
first of all you need to check probable causes,make sure there is power to the electrical socket , try something you know that works, if this appliance works the next step would be to try the fuse in the plug , replace old fuse with new and to be sure to use correct amperage , too small it will blow fuse too large it could blow appliance. If this fails then its sure to be a component of which a competant electrician / service repairer should be sought.
hope this helps.
Jan 13, 2010 | Vacuums
Bissell Proheat wont spray soap with uniformity
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jhkl
Sep 10, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
226 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
