Question about Honeywell Programmable Thermostat Heater
How to change honeywell thermostat to fahrenheit from celious
Older model 97-4730 wired
SOURCE: changing a room thermostat a potterton to honeywell t6360
I think I've done it - but don't take this as absolute truth.
For the Honeywell T6360B the original Potterton wiring should be rewired as follows:
Brown [Live] goes to terminal 1; Blue [neutral] goes to Terminal 2 and the yellow/green [which is not an earth but a switched live - i.e. gives live to the heating system when the thermostat clicks in] goes to terminal 3.
Obviously all done with the power isolated and when it was switched back on we had heating again :o)
It's been on over two hours now and all seems fine.
Posted on Feb 16, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
SOURCE: honeywell thermostat
I had the same problem and decided to take a chance and call honeywell customer support. I am shocked, they solved my problem! At least in my situation we found that the blue wire ran the compressor. Instead of hooking up to "blue" on the thermostat, we hooked it up to "white." It works wonderfully now.
Posted on Apr 25, 2009
  • 4 Answers
SOURCE: Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Posted on May 05, 2009
heatman101
  • 43501 Answers
SOURCE: How do I switch the
Hi, The procedure is fairly simple.... the easiest way is for you to look up the manual and have the proper steps right in front of you...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Posted on Nov 07, 2010
Testimonial: "thanx"
Need to change thermostat from Celsius to Fahrenheit
The first link is operators manual.
The second is installation and contains the procedure to set many functions including the display temperature.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2577ES.pdf
See page 15 function set 14. This sets F or C temperature
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2578ES.pdf
hope this helps?
Jun 23, 2017 | Honeywell Heating & Cooling
We just moved into this home which was build in November 2012 with a Honeywell Thermostat. There is a sticker on it with the following:
Those numbers don't work on Honeywell's website. Open the cover and get the numbers off the label inside the T/stat. You can get the information from Honeywell once you get the correct model #.
Oct 22, 2016 | Heating & Cooling
How do I change Honeywell RTH6350D thermostat from Celcius to farenheit?
yourhome.honeywell.com/home/Products/.../RTH6350D.ht
Operating manual.
May 27, 2014 | Honeywell RTH6350D1000 5/2Day Prog...
How to change Celsius to Fahrenheit on a pzs
You can do this during the setup of the thermostat.
1-800-honeywell
www.honeywell.com,
Dec 13, 2013 | Honeywell Programmable Thermostat Heater
Honeywell pro 2000 series thermostat to change from centigrade to fahrenheit
Hi there..how do i change from F to C on my honeywell pro 2000 thermostat? Please help :(
Jan 08, 2012 | Honeywell Programmable Thermostat Heater
How do I change my Honeywell FocusPRO6000 TH6110D1005 thermostat to from Fahrenheit to Celsius?
Press and hold the up arrow and fan buttons until the display changes. Then press Next until you see 14 in the display. Change this value to 1 (with the up and down arrows) to get Celsius. (O is Fahrenheit.) Press Done to exit and save the setting.
The manual is available here: http://customer.honeywell.com/Honeywell/ProductInfo.aspx/TH6110D1005 . Scroll to the bottom and choose a manual then press Download. This particular section is in the Installer's Guide.
I hope this helps.
Jan 30, 2011 | Honeywell Programmable Thermostat Heater
How do I change Honeywell pro 6000 to degrees instead of fahrenheit and I got stuck with the wiring - I have a red and white wire, got the heater going, but it wouldn't turn off - where do each of the...
google honeywell & see what you fined . maybe( honeywell 6000) there should be a number for you to call... alot of thermostats have numbers with it just incase of your problem , should be on the back of it or inside the box the stat came in...
Aug 17, 2010 | Honeywell Programmable Thermostat Heater
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Switching thermostat from farenheit to celsius
My thermostat was set on celsius and couldn't get it to change back to fahrenheit. My son suggested pressing both up and down arrow buttons at the same time and it worked. It changed back to fahrenheit.
Feb 16, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
55 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
