I get a beeping sound a an indication of " dE" on my washing maching....
How can I solve this problem?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Door is not well closed if it's closed check the inlet water valve
Posted on Feb 10, 2014
My LG washing machine is displaying DE when I go to start it and it beeps and blinks de
The DE error or fault code is to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly
Sep 21, 2014 | LG Washing Machines
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
AFTER STARTING THE MACHINE IT SHOWS ERROR AS "de"
There are numbers of error which washings machines shows output.The machine identifies and indicates some operational errors through a series of beeps.Beep is given below for you are reference.
Display indication what to do
DE Unhook/clean drain pipe and press the 'start/Pause' button to
continue cycle.
Jun 17, 2011 | Washing Machines
CADA VEZ QUE EMPIEZA CUALQUIER CICLO DE LAVADO,APARECE EL ERROR F1,PULSANDO CANCEL Y STAR,VUELVE A EMPEZAR EL CICLO, PERO, PARA DE INMEDIATO EL CICLO, CON EL MISMO ERROR ,F1, 3 VECES SEGUIDAS....ASI MISMO...
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&$%%
Sep 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error indicator (dE) & cant spin
DE means drain error. The water is taking too long to drain out of your machine. It is most likely a defective pump, or clogged drain line.
Nov 27, 2009 | LG WFT1071TP Top Load Washer
My maytag top loading washing maching only fills up with water
take the two screws out of back controll panel than jam somthing to hold the door closed switch forward mine did same many times and it is always that switch moved back a little to far you can check by holding open door and push in switch with a pen or somthing
Apr 01, 2009 | Washing Machines
Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Aug 12, 2008 | Washing Machines
Bosch WFL 2872 washing machine has just started beeping (3 beeps) at approx 1 minute intervals at end of program until I turn machine off. washer is 3 years old & has never done this before - does it...
A similar thing happened to mine. I think it starts when there is a power cut or something similar mid cycle. The solution (which you would never guess!) is the following:
Select any programme - say 30 Cottons
Press and hold any function button - NOT Start Signal will sound at varying levels - release button when it gets to the level that you want, off in your case. De-select programme Good luck!
Jul 24, 2008 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
