Fan number 2 Samsung DLP HLS6188WX/XAA
Check fan number warning comes on and tv shuts itself off every time it is turned back on. I need to be sure I order the correct fan for my Samsung DLP tv (model number is listed above).
Nickstar19
  • 417 Answers
SOURCE: the tv says 'check fan
Everything you need to know is right Here
http://www.jangro.com/a/2006/09/29/samsung-dlp-how-to-replace-fan-2/
Posted on Jul 06, 2008
SOURCE: Tv shuts itself off
Look for the computer processor inside the TV. It needs to be cleaned. A can of compressed air will work. The processor is overheating and causing the tv to shut off. Look for the small fan that is supposed to keep the processor cool then remove the dust.
Posted on Jun 09, 2009
  • 2336 Answers
SOURCE: NEED THE DMD PART NUMBER FOR A SAMSUNG DLP MODEL
Here's the DMD part number: BP94-00478A
Posted on Dec 14, 2009
  • 556 Answers
SOURCE: Samsung Model Hlt6176SX/XAA has Check Fan No. @
The lamp fan needs to be replaced.
Posted on Jan 12, 2010
SOURCE: which is the #2 fan on hls6186wx/xaa samsung tv
I have a Samsung model HL-S6186 since 2006 and one month out of a 5year extended it would cut of by itself. I would turn it back on and it just progressively worse. After looking at the stories on the internet with others who had similar problems, i ordered a new lamp online for $ 56.00 with the same specs. Put the lamp back and found out that there was arching where the lamp connects to the rear. I dissembled everything cleaned the contacts and repaired the one burnt connector on the new lamp with a connector from the old lamp. Turned the tv on and now i got a check fan #1 problem. ordered an exact lamp fan from Amazon.com for $ 15.00. When it arrived i pulled everything apart and replace the fan, still got a check # 1 fan error message. I was able to download a free service schematic that covers the HL-S5086 Tv. After studying the signal flow i pulled out the DMB board and use a cheap multimeter from Radio Shack that had an audible continuity check position. Just to clarify a few points, on the DMD board the top female connector is from the Lamp ballast/Driver, the middle female connector labeled #cn805 on the board says fan # 3, when it is actually fan # 2 for error messages, and the bottom female connector on the board is labeled fan # 2 , when it is actually fan # 1 for error messages. With the DMD board in my hand and checking the continuity between all three pins of the connector, i discovered that i didn't get continuity between the top most pin where the color code is yellow for the the negative signal that the DMD board is looking for when all is working with these tube axial fans. Sure enough i realize that in my disconnecting the # fan connector i must have cause the solder joint to come loose or it must be a manufactory flaw in the process. The other two connections soldered on the board were solid.After shaking the female connector with receiving pins i decided to resolder the whole connector. This could be very delicate. For some reason the point where the # 1 fan signal gets to the DMD processor would not solder right. Not wanting to destroy the delicate $ 269.00 board , i just soldered a piece of earphone insulated fine wire from the connector point on top to the underside of the printed circuit board just before the signal goes to it's first component.I then cut out a 1/4 inch section of the trim metal that snaps on to the DMD board to insure that it won't tear loose my work. I then Check the continuity between the connector pin where the signal comes from the fan and the underside and i got an audible continuity sound. I put everything back together and my problems are solved. I only need to re-adjust the 4 tension screws that surround the heat sink to place the picture dead center. Be careful when you pull on all connectors, ensure that you bend the tabs the tug gently. Hope this helps someone out there. Incidently i have working and troubleshooting this problem for two weeks, in the meantime due to the basketball and the Super Bowl coming i panicked and went out and purchased my first Samsung 59 inch Plasma Tv package deal with a Blue Ray DVD player an glasses. The 2006 DLP Tv is workin great and the picture is much brighter than before. I have an extra new fan now in case the old # 1 lamp fan fails.
Posted on Jan 30, 2012
Samsung tv series sq01 has check fan 2 on screen then will shut off where is fan 2 located and what does this mean
you will need the complete model/serial number for proper part#. To locate which fan is problem try watching to see which one is not coming on at start-up.
Dec 09, 2014 | Samsung Televison & Video
My Samsung 50'' DLP msg "Check Fan No. 3"
You can attempt to remove the back cover, but there is a very delicate mirror in the back. I'd just move it away from the wall, used compressed air to clean out the fans, and put everything back together. Just make sure you don't damage the color wheel or light engine.
Feb 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung dlp hls6186w, picture has darkened, could it be the lamp or is it the colour wheel??... tv is making sounds...I thought it was the fan, the fan looks okay??? It also shuts down once and a while...
The lamp is the only thing that will cause the picture to go darker. According to the model you have the lamp part number is BP96-01472A. The noise you hear could possibly be the color wheel itself. The way to tell is when you turn off the TV the lamp stays on for about 10 seconds longer. Once the lamp shuts off if that noise goes away then it is a bad color wheel. Any noises past that would be a fan. Please take a moment to rate my answer. Thanks...
Dec 02, 2009 | Samsung HLS6186W 61 in. Plasma HDTV
Samsung Dlp completely shuts off and then all three lights flash
Sounds more like the TV is overheating. The lamp cooling fan may be seized or not spinning fast enough. If the TV gets hot enough to trip the thermal, it could rupture the lamp.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R6768W started making squeal noise from rear of TV. At same time lost picture and will not come back on. Sound is ok and you can hear light trying to turn on. Can fan motor not working correctly...
Look at the fan and verify its comming from the fan and not the power supply unit, you can clean the fan or replace it, but yes the fan would be likly the problem. Make sure you double check the power supply unit and clean if its needed,
Rulds2008
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
Tv shuts itself off
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp hl-r5667w
This Tv make a lot problems with the color wheel and fan thermostat, lamp cool. Need be check the color wheel first. I am suggested dont have nothing on the back cover ( make hot or not ventilation). More information parts at tritronicsinc.com Thank you
Aug 12, 2008 | Samsung DLP HL-P5663W 56" TV
The tv says 'check fan #2. samsung dlp model # hln437w/xaa
Jul 06, 2008 | Televison & Video
Samsung 50" DLP TV
Since the lamp generates a lot of heat, the fans are continuously monitored for correct function. The owner's manual should show you the location of the fans. Make sure that the grills covering the fans are clear of dust and that the fans are clean. Sometimes dirt can cause the fan blades to slow down enough to trigger the safety alert.
Keep us posted.
Dan
Jun 27, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung dlp hdtv turns itself off
Have a 46 inch behaving the same way. I have the extended service contract, so they are getting a calll tomorrow. I ll post what they say
Dec 27, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
Top Televison & Video Experts
