Question about APC Back-UPS CS 500VA UPS System
Orange LED keeps on blinking. 2. - APC Back-UPS CS 500VA UPS System
How do i reset my pixma 1990 printer the ink receptacle is full message keeps on appearing?
To reset the printer follow these steps : 1. Turn off the printer and hold the "RESUME" button located on top of the MP220. While holding the "RESUME" button, press the "POWER" button and wait for the machine's green LED to illuminate.
2. Release the "RESUME" button while holding the "POWER" button. Press the "RESUME" button twice and release the "POWER" button.
3. Press the "RESUME" button four times followed by the "POWER" button. Turn the printer off and then on to complete the reset process.
As per your error follow the below mentioned steps :
1. Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2. While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3. While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4. When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5. Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6. Power off then check it.
In case if the problem persists please revert back.
May 22, 2011 | Office Equipment & Supplies
Error code 5100 check printer
This is probably a Canon printer and code. If so, it is the "ink waste pad is full" warning. There are work arounds to keep from having to clean the pad. Here are two methods to eliminate the message. The only other ways are to take it to a repair shop or dismantle the printer and clean the pad yourself. Not advised, This is messy.
This works on many different printers.
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
6) Power off then back on and test.
mp150 and simular printers:
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
Jan 22, 2011 | Office Equipment & Supplies
What is error code 6500?
This is an error indicating a problem with the Logic Board Assembly. It's probably not worth fixing, with printer prices being fairly low.\
According to the MP800 Service Manual:
2-2. Service Call Errors (by Cyclic Blinking in Orange (Alarm LED) and Green (COPY button), or
Alarm LED Lit in Orange)
Service call errors are indicated by the number of cycles the Alarm LED and COPY button blink, and the corresponding error
code is displayed on the LCD.
*Cycles of blinking in orange (Alarm LED) and green (COPY button) - 20 times
*Other hardware error - Error
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
Aug 21, 2010 | Canon MP830 All-In-One Printer
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
LED light keeps blinking
That is a service error code, but you need to count how many blinks between the longer green blink, and that tells the error code...
Oct 13, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
My Acer netbook will only keep an internet connect when plugged in.
This netbook has a little orange led that blinks to let you know that the wireless is turned on. Then you know you can connect to wireless networks. Take a look at the photo here:
www.geekzone.co.nz/images/news/AcerAspireOne.jpg
To the right of the touchpad, at the front edge of the palmrest (closest to you) you will see a small silvery stripe. This is where the wireless led is.
First, look and see that the little orange led is blinking. If not, slide the little switch right beside it to turn on the wireless (you should see 'wireless lan enabled' in large green print) If you can't seem to get the orange led to blink by doing this, check device manager and check that the wireless card is enabled. If it has a red X on it, right-click on it and left click enable.
If the led is blinking, but you still can't connect to wireless, see if you can connect to another wireless access point other than your own.
Let me know if this helps or not :)
Aug 17, 2009 | Acer AOA150-1690 Aspire Notebook
APC Back-UPS CS 500VA UPS System Logo
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
