Question about Kenmore 700 6972 Dryer
Kenmore 700 series dryer
Won't start
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: my 700 series Kenmore Dryer wont heat completely.
If the dryer has been cleared of lint. the lint filter area is clear and the vent is fine then the timer is probably bad. Why? because a lot of current goes through the timer and most of the time the contacts in it get burred or burnt. Unless you have a bad breaker I would advise replacing the timer.
Posted on May 20, 2009
  • 1015 Answers
SOURCE: kenmore 700 series gas dryer .runs but no heat
There are several things that can cause this problem. It could be a defective hot surface igniter, inop thermostat, bad gas solenoid valves ect. You will first need to check and see if the hot surface igniter is coming on. You can verify this by turning on the dryer and then watching for the hot surface igniter to start glowing from the burner inspection hole at the bottom of the dryer(or remove the front/back panel if no window). It should glow very bright. Then after it is glowing to it's brightest point you should then hear a click(the sound of the gas valve solenoid opening) and the burner should come on. There are two gas valves in the system as a safety so you could have one valve that is bad. When the gas valves are charged they should be magnetized on the top of the valves. You can also give these valves a light tap to see if they are sticking. The gas valve solenoids and bad igniter are the most common cause of inop gas dryers. It could also be a bad thermostat or high limit cut off switch is open. Take a look at the dryer and let me know what you find. Also be careful doing any work on your dryer without the proper tools and knowledge. You could hurt yourself from electrical shock or explosion if you are not careful.
Posted on Feb 19, 2010
heatman101
  • 43501 Answers
SOURCE: Gas dryer won't heat up
Here is a tip that will help you with your problem..
believe it or not it is not an electrical problem, but an ignitor problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Posted on Mar 28, 2010
hunter19_46m
  • 7482 Answers
SOURCE: My Kenmore 700 Series dryer will no longer heat.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 10, 2010
My series 80 Kenmore dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Kenmore 800 6983 Electric Dryer
Kenmore 700 series dryer; quit operating during cycle; will not restart; has power to terminal block; any suggestions?
the belt may have broken:
http://www.ehow.com/how_4814455_change-kenmore-dryer-belt.html
here is another website, Hope this helps Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
May 23, 2011 | Kenmore Dryers
Have a Kenmore 70 Series, Heavy Duty Dryer. Push the on button to start, nothing happens.
heatman101
Sep 19, 2010 | Kenmore 700 6972 Dryer
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Our Kenmore Series 700 Electric Dryer works but won't heat up. What can be wrong?
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 10, 2010 | Kenmore 62602 Electric Dryer
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Kenmore 700 6972 Dryer Logo
65 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
