Question about Motorola Televison & Video
Surewest tv signal breaking up - Motorola Televison & Video
Why does the screen turn blue and indicate "no signal"?
Hi Jocelyn,
The TV will show no signal when either there is a break in the input signal or the TV is not receiving or processing it properly. Please check the input cables and connections and the signal box. If that is ok please call the local TV tech.
May 29, 2015 | RCA Televison & Video
THIS PROBLEM IS NOT LOGICAL-SIGNAL STRENGHTS HAVE BEEN CHECKED AND WAS OK BUT THE PICTUE KEEPS BREAKING DIFFERENT ON 3 DIFERENT TVS IN THE HOUSE BUT WHEN I REMOVE ANY ONE OF THEM AND CONNECR IT INTO O
In fringe areas; where signal strength is too weak, this should happen. It sounds that, you're using an Ariel booster along with a splitter. Just connect one TV at a time, without using the splitter. If picture break occurs even this time, adjust the the signal strength of the booster [either low or high], and check whether it can help you. Keep in mind, iv the signal strength is too low, or set to too high, this fault will happen, as AGC [automatic Gain Control] circuit inside the set won't function properly. Gopakumar Gopalan Google
Dec 15, 2014 | Toshiba Televison & Video
My picture and keep on breaking up on some channel
If you have a good picture on some channels and the picture breaks up on others , it could be the input signal. What is the source of the input signal; i.e. cable, satellite, antenna???? Do you have a cable box? The problem may be with the box or with the provider's signal.
Mar 30, 2014 | Sony KDL-46S4100 46 in. LCD TV
My son brought me a T.V for Christmas i am constantly having problems the Picture is constantly breaking up and losing the signal can someone advice me please
What kind of tv programming do you have? Antenna, Cable, Dish? Most of the time if the picture is breaking up it will be the signal from the source, not the tv.
Mar 12, 2014 | Televison & Video
Surewest cable uses motorola cable box MXv3 my tv brand is sanyo
download you code www. fitness.manualsonline. com and reset the codes.
2) and download the instruc. manual for to proceed how to do it.
3) change the batteries by new ones with alkalines
4) clean contacts batteries
5) Retigh the springs contacts with pliers very well
6) Try again...
7) If there the problem remain, you must open the remote for clean the keypads from dust, and oxide. or go to the repair shop.
God bless you
May 20, 2012 | Televison & Video
Intermittent picture break up
What is your model number? Also when you say picture is breaking up do you mean the signal breaks up? Does it happen when you have the menu up also? Are you using cable or regular TV?
Feb 29, 2012 | Toshiba REGZA 32AV615 32 in. LCD TV
UR5L-9000L-SW manuel
The manual for the SureWest Phazr-5 (UR5L-9000L) remote control is available here: http://www.surewest.com/assets/pdf/kc-support/OCE-0081A_UR5U-9000L-and-UR5U-9020L_Rev10_120216.pdf .
I hope this helps.
Jan 09, 2012 | Audio Players & Recorders
I need to reprogram my remote and i need to codes. please help
Well, I am glad to help! Since I dont know what/ how many different things you will be programing, I will just link you to a very information site i found, Which includes the remotes 4 digit code- 0476 along with step by step instructions and codes for the devices you will be trying to program too.
http://support.surewest.com/surewest/ccil/selfservice/docdisplay.jsp?DocId=73695&SecMode=1&SearchTerms=motorola+remote
Hope this helps! Best Wishes and Good luck!!
Apr 10, 2011 | Televison & Video
I have a samsung digital ready HD tv with built in freeview and cannot get all stations as they break up into small blocks and lines. please help
When the picture pixelates (breaks up into blocks and lines) it means that there is not a strong enough signal getting to the tv. The signal may be improved with a taller, higher-gain antenna. You could search google for "antennas" and find what you need. Good luck! Der Strom
Apr 12, 2010 | Televison & Video
I have had a 32" sony LCD Digital TV with built in free view tuner. I am experiencing a problem where on certain channels the TV keeps switching itself off to standby. Is this a TV fault or a signal one,...
if it says no signal or video not available then signal if its just turning itself off then tv i would go to the shop and get it checked out or replaced.
Dec 04, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
Televison & Video Logo
Top Motorola Televison & Video Experts
Jaime Hernandez
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
