Question about GE GTUP270EMWW Washer
Leaking main seal - GE GTUP270EMWW Washer
Oil leak front engine timing chan
1995 Tracker would have a timing BELT. Normal oil leak points (in order) on a Suzuki G16 engine are the distributor base (rear of motor), valve cover (top of motor), front main seal (behind lower timing belt cog) cam seal (behind the upper timing belt cog) and rear main seal. (behind the flywheel). I'd suspect the front main seal or cam seal. I use foot power to help find oil leaks.
Dec 24, 2012 | 1995 Geo Tracker
Oil leaking from toyota camry 1992, 1994 model
You don't say what engine it has. The 4-cyl was a better than the V6 for oil leaks.
The V6 had oil leaks from
-rear bank cam cover gasket
-distributor o-ring seal
-oil filter bracket o-ring seal
-crankshaft nose oil seal (less common)
-rear main bearing oil seal (expensive, just leave it)
The 4 cyl leaked oil from
-camshaft cover gasket
-rear main bearing seal (expensive, leave it)
May 21, 2012 | 1991 Toyota Camry
I have had my rear main seal replaced 3 times and it is still leaking. Could this leak be coming from somewhere else? The first mechanic assumed it was the rear main seal, and the others I informed them...
First off i would hope that there was some waranty coverage for this repair.
Is the fluid leak indeed oil (black/brown)? If so that would be the rear main. Problem could be the surface around the seal on the engine has a defect or space.
If the fluid leak is a reddish color this is transmission fluid and would be the torque convertor leaking not the rear main.
Good Luck!
Zeppelinx12
Mar 05, 2011 | 1999 Lexus RX 300
Replaced rear main seal on 5.7 but still seems to be leaking. Any suggestions?
Be sure it is the rear main seal,there is a cam plug that could be leaking,but if it is the rear main oil seal leaking,then I suggest removing it,and installing a rear main repair sleeve,this will give it a new surface to ride on,the crankshaft may have a groove cut into it from the oil seal,this will remedy the problem.If this was at all helpful,please rate,thank you.
Jul 10, 2010 | 1994 GMC Sierra
Oil leak
that motor known as a leak motor f22,check this front cam seal,cranks seal,balancer seal,rear main seal and distributor seal those are the main common problem
Dec 16, 2009 | 1995 Honda Odyssey
My Chevy 2002 Tahoe is leaking oil. They told me
this truck is equipped with an aluminum oil pan you could have 1 or several things going on... a stripped drain plug which is causing it to leak or it may be a leaking front seal or a rear main seal. If it is a front seal it is not to labor intensive. But if it is a rear main seal leaking it will require the transmission to be removed since the seal is a 1 piece rear main
Sep 07, 2009 | 2002 Chevrolet Tahoe
2001 Silverado 1500 Z71 4x4 oil leak
i had the same problem and it turned out to be the gasket on the rear main seal housing not the rear main seal.
Jul 24, 2009 | 2001 Chevrolet Silverado 1500
Rear main seal is leaking on a Ford Mustang 2003 V-6
In order to replace the rear main seal u have to pull the transmission out to access it, u will need a special seal installer tool to install the new rear main "full circle seal", it u don't use the special ford tool the seal will leak again, also if there is a groove worn ion the crankshaft the crank must be repaired or replaced or the or the seal will leak again, so this is avery diff job, a 9 on the scale of 1-10 with 10 being the mos difficult.
May 10, 2009 | 2003 Ford Mustang
Rear main seal leaks..does this affect transmission??
A leaking rear main seal will not cause your transmission to leak.
The transmission has its own seal and should not leak because of the engine rear main seal.
Due to the labor involved in replacing the rear main seal on the engine, it is best if you replace the front transmission seal at the same time if possible.
Installation varies on different vehicles but the principles are the same.
Apr 15, 2009 | 1997 Oldsmobile Regency
GE GTUP270EMWW Washer Logo
67 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
