Question about Panasonic Televison & Video
Do I need a converter box to receive digital signal on my Panasonic ct32sx12f tv
SOURCE: Sansui TVS273
This tv is not digital.
Posted on May 12, 2008
  • 520 Answers
SOURCE: trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Posted on Jun 28, 2008
tvguy171
  • 106 Answers
SOURCE: my ge tv digital ready?
Your TV is NOT digital ready. IF you do not have cable or satellite, you will need a converter box. If you do have cable or satellite you have nothing to do or worry about as the cable or satellite box will automatically do the conversion for you. Hope this helps
Posted on Dec 20, 2008
SOURCE: Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Posted on Jan 08, 2009
  • 9 Answers
SOURCE: Does the JVC AV27230 require a digital to analog converter?
if you are going to continue using the rooftop antenna, then you will nee to purchase a digital converter box. Those television sets are only analog. You do have an option to get Directv or Dish network and you will not need a converter box at all. Directv and Dish network are 100% Digital and the receivers work as converter boxes for that product only.
Posted on Jun 16, 2009
Have Panasonic The;37pw5 plasma tv . How do I get broadcast tv?
You will need some sort of digital (ATSC) to analog (NTSC) OTA signal converter (set-top box) with an antenna. The Panasonic TH-37PW5 only has NTSC (in the US) or PAL (UK) tuners. There may be a few low power NTSC stations still broadcasting in the U.S. However, you need to be close to their transmitter to receive the signal. You can use one of the original converter that were available with the government coupon. There are some newer models available. Look at your choices carefully. You will need a converter with RF, composite video or component video output. Any model with only HDMI out will require an additional converter connected between the set-top box and the TV.
The specifications for the TH-37PW5 are available on page 38 of the manual. This is available from Panasonic here: ftp://ftp.panasonic.com/television/om/th-42pw5_en_om.pdf .
I hope this helps.
Dec 14, 2016 | Panasonic Televison & Video
Do my panasonic hdtv 1080i need a converter box in order to work?
None of the newer style TV's need a converter box because all the tv channel tuners use a digital signal. The tv signal in the air is now digital when using a tv antenna.
Sep 13, 2015 | Panasonic Televison & Video
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Mar 09, 2011 | Sharp LC-20SH4U 20 in. EDTV-Ready LCD...
All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
http://www.consumerreports.org/cro/electronics-computers/tvs-services/non-digital-tvs/digital-converter-boxes/digital-tv-converter-boxes-first-look-3-08/overview/digital-tv-converter-boxes-first-look.htm
Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
Is the PT50LC13 a digital TV? I didn't buy a converter box thinking that the TV didn't need one, but over time and unable to see any channel even with one, I wonder if the TV is indeed digital or not. I...
This tv only has an analog tuner (NTSC). That is why it works with cable and dvds. You will need a converter box to view OTA signals. (In addition, digital signals have a firm cut-off of signal strength; if the tuner doesn't get enough signal the channel will not be available.) So check with antennaweb.org or tvfool.com for details on the antenna direction for your area channels. antennaweb is very conservative in the channel listing it provides (even with the assumption of an external antenna). tvfool gives the color specifications of the antenna that should receive a given set of channels in your area.
The converter boxes are still available from select vendors but the government coupons program is not. Here's one that is listed as in stock: http://www.radioshack.com/product/index.jsp?productId=3150939&CAWELAID=198809366 . This is one of the standard definition output boxes. High Definition digital to analog converters also exist but are more expensive.
A cheap alternative may be to use a PC TV tuner (either USB or internal card) attached to the antenna and then output to the TV. This TV has a VGA port. (If you want to use component video in on the TV, you will need to check if your video card will support the non-RGB signal or a converter box for that.)
I wish that I could be of more help.
(many shows are available online either from the networks or from hulu.com)
Oct 11, 2010 | Panasonic PT-50LC13 50" Rear Projection...
2005 Conversion Van has TV What do I need to do to receive Signal
If the audiovox does not have digital capability you will need a converter. The converter "converts" the digital signal back to the old signal so that your tv will recognize and play it. Thanks for using fixya.
Mar 03, 2010 | Audiovox AVT1498 TV
Can the Panasonic DMR-EH55 be made to receive digital channels? e.g. via a digital capable TV or a set top box? If not, I suspect it will be obsolete when analogue channels cease this year (in Australia)
If you receive your channels through your local cable company, nothing will change. The DMR-EH55 will continue to work normally.
If you receive your channels with your rooftop antenna you'll need a Digital to Analog TV Converter Box. The unit itself will not receive digital signals directly.
Jan 16, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
Hi, when in June there will be thr passage to digital I'll can countinue to use this tv or I need a converter? Thanks Maria
According to Panasonic this set is not capable of receiving digital signals, therefore will require a converter box.
You can get a coupon from the government for $40.00 towards the purchase of this box at the following address.
https://www.dtv2009.gov/
You will need an antenna that is capable of receiving UHF signals. Not rabbit ears, but the loop type of antenna that sometimes comes with rabbit ears.
I always encourage everyone to get the coupons from the government, because they are free and you can request two per household. (That’s $80.00)
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
May 29, 2009 | Panasonic PV-C2541 25 in. TV/VCR Combo
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Nov 07, 2008 | Televison & Video
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
