Question about DeLonghi EN670.B Nespresso Espresso Maker
Power on button just flashers red
Once the machine is switched on the power button just flashers red and doesn't do anything else, if I press it whilst it's flashing it then just stays red, without the while lights coming on, on the drink selection
4 Suggested Answers
SOURCE: Blinking light
SCALE REMOVAL
The scale contained in the water, over time, will
cause plugging up of some elements in the appliance
and will thereby compromise its correct functioning.
The result will be that more time is
required to make coffee. The formation of scale
depends on the hardness of the water and on how
much the coffee maker has been used. To achieve
the best performance, descaling must be carried
out every so often. The coffee maker has a built-in
system that counts the number of cups of coffee
that have been made. The ON DRIP pilot light will
begin to blink when it is time to carry out descaling.
To do so, proceed as follows:
• remove the anti-chlorine filter (if present) and the
permanent filter from the coffee maker (so as not
to bathe them with vinegar)
• Dissolve 2 dessert spoons (about 30 grams) of
citric acid (available in pharmacies) in the
water;
• Place the container on the heating plate;
• Press the DRIP/AUTO button twice, allow
the equivalent of two cups to percolate and then
turn off the appliance;
• Allow the solution to sit for an hour;
• Turn the appliance back on and allow the rest of
the solution to percolate;
• Rinse by allowing the coffee maker to operate
with only water at least three times (1 full container
each time).
• Press the PROG and DRIP/AUTO buttons
simultaneously to reset the counter to zero.
IMPORTANT: if the machine is left unconnected to
the electrical mains for over two months, before
using it again it is necessary to carry out the
process of scale removal as described in the preceding
section.
10
Posted on Jan 14, 2008
SOURCE: Flashing Light
Drives you nuts doesn't it? I was about to throw mine out...could never tell if it was on or off, let alone program anything....but Here is The Solution!
Hold the hour and minutes buttons down simultaneously for about 10 seconds till light stops blinking and it will reset.  I was so happy to find this info on:
http://kitchen-stuff.info/gear/Coffee_Tea_and_Espresso/Coffee_Machines/Drip_Coffee_Machines/DeLonghi_America_Inc_DeLonghi_DCR902T_Retro_Drip_Coffee_Maker_with_Timer.html
Posted on Dec 08, 2008
espressonist
  • 1711 Answers
SOURCE: I have a delonghi esam 3000. When I plug in the
Try to turn the steam knob to off postion and the switch off and on again. If the light insist that means that the steam micro-switch which is activated by turning the knom is either stuck in on position or is faulty and need to be replaced.
Posted on Sep 08, 2010
Washer dryer door open and key sign and clicking noise when I try to start up washing machine Amber light flashing
Is the door fully closed or has some debris got into the mechanism.is the child lick on?try resetting the machine by switching off power at socket, then whilst holding the start button for five seconds whilst you switch it back on at socket.door solenoid should cluck once and the key sign should disappear.hope this is of help.
Jan 18, 2015 | Hotpoint Aquarius WD640 Front Load...
How to set ink level on canon mx-320 after refill?
Apparently the problem is that you are choosing to install (according to Canon), cheap, aftermarket ink cartridges rather than Canon ones. Therefore the machine is not recognizing them. Try this procedure, found on another forum, that was supplied by one of the cheapo ink companies. Who better to know how to fool the machines than them. If they want to sell these ink carts, they better know who to make them work!
U051 Error Correction procedure.
1- Switch off the Canon MX300 and disconnect the power cable.
2- While press and hold the power button, Connect the power cable to electric socket.
3- While pressing the power button, press the "Cancel/Stop" button (red button). (press TWICE che "stop\cancel" button)
4- Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says "idle".
5- Press ">" (next button) once "Shipping Mode 3? then Press the "OK" button. Press "OK" again for "without cleaning". A test page will print.
6- Open the cover, like you are about to change the cartridges.
7- Disconnect the power cable again without switch off the printer.
8- Take out the both cartridges.
9- Close the cover.
10- Connect the power cable and turn on the printer.
11- Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Jan 14, 2015 | Canon Black Pixma Mx 320 High Quality...
Lg wd-1438rd wont turn on
It sounds like when you moved the machine it pulled a plug off inside the machine, the only way to find out is to disconnect the power and remove the top of the machine, You will be able to see if anything is not connected as it should be.
May 14, 2017 | LG WM2077CW Laundry XL Front Load...
Where is the turn signal relay located on 1999 300M. Turn signals and flashers will not work. They will flash once mabey twice but thats it.
There is a combination flasher unit located somewhere near the turn signal/hazard warning switch.The unit has RED and DK BLU/PNK wires connected to it as well as PNK and BLK/YEL power connections
Oct 23, 2012 | 1999 Chrysler 300M
Programming the remote for the emerson curva sky 44
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search. For more details click here/
Sep 28, 2012 | Emerson 44 Curva Sky Ceiling Fan In...
Brush doesnt turn
Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
this link is for the manual..
http://media.dyson.com/downloads/UK/floorcare/Manuals/DC24_allfloors_uk.pdf
Sep 23, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Delonghi Magnifica Rapid Capucinno Power button not working. Hi all, We have a delonghi coffee maker that stops working few weeks ago. The machine doesn't power up. When you plugin into the outlet...
It's quite likely your unit had a blown thermal fuse caused by a bad thermostat. Test them by disconnecting one end and a meter should show continuity if the part is good. The pro's test them in circuit while the unit is plugged in, power showing across the part means it is bad. REPLACE BOTH PARTS TOGETHER.
Jul 02, 2017 | DeLonghi Esclusivo Magnifica ESAM3300...
Need code for toshiba flat screen tv
Hello
Three digit universal remote code for Toshiba are:-
013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Four digit universal remote codes for Toshiba are:-
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
NB: Switch OFF and switch ON your TV, with its front panel power control switch each time before trying an other code.
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Mar 13, 2011 | Toshiba Televison & Video
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
Mar 10, 2011 | Nintendo Wii Console
Child lock is stuck on and machine won't start
Does this help?
If you wish to prevent small children or pets
from climbing into the machine, you can
deactivate the automatic door opening
function.
1. Turn off the machine using the main power
switch.
2. Press the Door Open button while
simultaneously pressing the main power
switch. Release the buttons.
3. Press the Key button and the red field goes
out. Automatic door opening is now
deactivated.
4. Press the Start/Stop button to save the
setting.
If you want to reactivate the function, follow
the instructions above, but when you press
the Key button (point 3) the red fields light up.
Store the setting by pressing the Start/Stop
button.
Do let us know if it does
regards
Feb 01, 2011 | Asko W640
DeLonghi EN670.B Nespresso Espresso Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
