Question about Microwave Ovens
Have 1992 panasonic 1200 watt microwave with error code f51 what does it mean
2 Suggested Answers
fathitkf
  • 1871 Answers
SOURCE: 1200 watt panasonic, power on but will not perform
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
best regards .
please don't forget to rate !
Posted on Apr 04, 2010
Testimonial: "Thnaks; If this is my problem, how is this switch replaced, is it a proffesional job , or simple? Thank you kind sir.T.K. tkeytanner@gmail.com"
What does H97 mean?
It is an error code that means ether the magnetron or the inverter is bad.
Oct 16, 2014 | Panasonic NN-SD372S 0.8 cuft 950-Watt...
MY EMERSON MW1119B STOPPED HEATING
Sounds like it's broken. Go for Panasonic next time, they make better microwaves. Here's one I was looking at http://bestmicrowavereview.com/panasonic-nn-sn651b-genius-1-2-cuft-1200-watt-sensor-microwave-review/
Jan 04, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
NN-SD297S The exhast fan still works but the oven
Due to the technology used in this model, there are no user serviceable parts inside. Call a Panasonic appliance engineer.
Mar 07, 2011 | Panasonic NNSD297SR 1200 Watts Microwave...
Panasonic 1200 watt microwave shuts down in 10-15 seconds
Check the door switches to make sure they are not faulty, otherwise it may be the inverter.
IS the microwave in a cavity? If so, you need to have at least 15cm (6in) space above the microwave, 10cm (4in) behind the microwave, and 5cm (2in) on either side, as the latest Inverter microwaves run very hot and need a lot of ventilation.
May 26, 2010 | Panasonic Microwave Ovens
1200 watt panasonic genius shuts down
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Hello :
best regards .
Apr 04, 2010 | Panasonic NN-S262SF Microwave Oven
Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
Nov 19, 2008 | Panasonic NN-S443WF / NN-S443BF 1200 Watts...
Panasonic microwave
You mean it's dead, or won't heat? What is the exact symptom?
Please post that, then we can suggest the solution. Thank you.
Dec 05, 2007 | Panasonic NN-T774SF Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
