Question about Whirlpool GW395 Gas Kitchen Range
Oven and broiler will not light but burners will light
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool Super Capacity 465 the oven/broiler does not come on.
More than likely a bad ignitor
Here is how to tell If the ignitor is glowing it should be VERY bright, if it is dim orange it is weak and bad.
Posted on Jan 08, 2009
  • 160 Answers
SOURCE: oven won't
if you can hear gas when turned on then its likely to be a faulty/dirty burner. No gas flow then its the thermostat or dependant on model a faulty gas relay/valve
Posted on Dec 22, 2009
heatman101
  • 43501 Answers
SOURCE: My whirlpool model # sf360bee oven won't light.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Jul 24, 2010
Whirlpool WFG361LVS2 oven. Broiler and burners ignite but oven will not. I can hear gas and the igniter sparks but will never light the oven.
get someone to hold a long gas match near the main burner when you try the oven . If it lights then I would suspect the igniter. even tho you can hear it snapping .
Jan 10, 2015 | Whirlpool Kitchen Ranges
Indesit oven keeps heating
Tappan gas range, TGF334BCWB. I can NOT stop the broiler burner from lighting. I have unplugged the 110 power and I light top burner with a striker. However when stove is plugged in to the power the broiler burner lights and continues to burn. The oven knob is turned OFF. The only way to stop the broiler is to unplug the power.
Mar 11, 2014 | Whirlpool Accubake SF362LXTS Kitchen Range
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
heatman101
Mar 30, 2010 | Ovens
Neither the oven nor the broiler burners will light. In both cases, the igniter glows, but no gas to the burner.
UNLESS DOUBLE OVEN THE BROILER BURNER HEATS THE OVEN. AND THERE WOULD ONLY BE ONE IGNITER. WHICH IS PROBABLY DEFECTIVE AS THAT IS A COMMON PROBLEM WHEN USING IGNITER.
Mar 10, 2010 | Maytag MGR5750 Gas Kitchen Range
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
Broiler doesn't lite, no gas going to pilot
Most cases Broiler ignitor is out, after you turn on the Broiler, check the voltage on Broiler ignitor 2 wires, if you have approx. 110v, then change the ignitor, but you don't have 110v, then check Broiler safety valve and oven thermostat, but 90% of the time is the Broiler ignitor. Have fun.
Jun 29, 2009 | Dynasty DGRSC 48-6G Gas Kitchen Range
Whirlpool GW395 Gas Kitchen Range Logo
24 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
