Question about Ocean Master Famous Brand by Taiwan 3D Dry Snorkel is Back! Crystal Blue SC
Ocean master 3d snorkel - Ocean Master Famous Brand by Taiwan 3D Dry Snorkel is Back! Crystal Blue SC
We purchased an adult snorkel set at Sams club and my snorkel leaks at the joint at the end of the mouth piece. How do we fix this?
is it the rubber mouthpiece bit that connects to the snorkel tube itself??
if so, mine has a plastice tie wrap holding it firmly in place,
Feb 28, 2010 | Body Glove Snorkel Mask Fin Snorkeling Set...
Replacement part for snorkel attachment
its a plastic clip if i am correct. i have in the past used a rubber band, but you could go to a local dive shop, they normally have the rubber replacements for snorkels.
Nov 26, 2009 | Aqua Leisure Dolfino Tri-view Dive Mask...
I bought this snorkel used and put it in my bathtub last night and it filled with water. The lower chamber is filling to the point I can't even blow it out. Is there something I don't know?
From what you've described, you have a self-draining snorkel (at least it would be if working correctly). There will be a simple diaphragm valve at the lowest point of the snorkel, it's usually made of a silicone rubber disc and in use is held closed by external water pressure. It can also be held open if there is any grit or sand in it, if it is damaged or if it's simply hardened with age.
All you can do is clean it and make sure it seats correctly. If it has failed in any way or if the diaphragm is simply missing then buy a new snorkel as they don't need to be expensive.
There's a good reason that many divers still prefer a simple j-tube snorkel and it's because there is nothing to go wrong. I personally do use a self-draining snorkel but I'm careful to inspect and clean the valve before and after every use and always have a spare snorkel in my dive bag.
On an unrelated matter, if the snorkel has any kind of device on the open end to prevent water from entering then I strongly recommend that you remove it. They're restrictive to airflow and are potentially dangerous. There is no substitute for simplicity and for learning to use a snorkel correctly.
Jul 09, 2009 | Tabata Usa Tusa Snorkeling Two Window...
Dirty snorkel tube
If the mold is much you can leave the snorkel soaked in lemon juice or 50% isopropyl alcohol solution.
See also the suggestions below:
Caring for Your Mask, Snorkel, and Fins
What's the best way to clean new snorkel
Feb 14, 2009 | Integra Dacor Ii Dry Snorkel Lowest Price...
Clearing the Snorkel of Water
Step1 Make sure you are gripping the mouthpiece of the snorkel securely with your teeth. Step2 Exhale forcefully through your mouth. The majority of the water should be expelled from the tube. This method is commonly called "blasting" or "popping." Step3 Inhale gently at first in case there is any residual water. Blast a second time if needed. Step4 Continue blasting whenever water enters the snorkel.
Dec 01, 2008 | Aeris Snorkeling Bag
The right snorkel for me
"A snorkel must fit comfortably in your mouth, allow you to purge water out of the mouthpiece and hose quickly and help you to swim efficiently. But, the most important characteristics to remember when choosing a snorkel are its length and the diameter of its barrel. Snorkels must not be too long or too short. If a snorkel is too long it will be difficult to breathe because the barrel will fill up with carbon dioxide. Every time you breathe out carbon dioxide through your snorkel your breath must travel up and out of the barrel of your snorkel to allow you to draw oxygen back down the barrel and into your lungs. If your snorkel is too long you will only push a percentage of the carbon dioxide up and out of the barrel during your exhale. You will need to inhale oxygen before all the carbon dioxide has been pushed out; leaving the percentage of carbon dioxide entering your bloodstream higher each time you take a breath. This cycle could lead to suffocation. If a snorkel is too short it will constantly fill with water, requiring you to constantly force the water out of your snorkel which can be very exhausting. The inside diameter of your snorkel must be approximately three quarters of an inch or 1.9 cm. If the snorkel is thinner than .75 inches it will be difficult to breathe because there will not be enough room in the barrel for you to draw enough air into your lungs. This will cause you to breathe harder and rapidly, which could cause hyperventilation. If the barrel is thicker than .75 inches it will be too large and will be uncomfortable to use and attach to your mask. Learning to attach your snorkel to your scuba mask to make sure it is easy to grab and use is an important part of safe scuba diving practices. Snorkels are attached to the left side of your mask with a snorkel keeper. Snorkel keepers are either plastic or rubber and most use a post-hole closure. Each snorkel keeper is different and attaching your snorkel to your mask with a snorkel keeper requires practice. If you will detach your snorkel from your mask after each dive you should practice attaching your snorkel, as it can be a little tricky. Alternately, you can leave your snorkel attached to your mask if you are diving more than once in a day. "
Snorkel need issue
Every scuba diver spends time on the surface while preparing to descend for a dive. A snorkel allows you to conserve energy by letting you keep your head in the water while swimming and enjoying the pre-dive sights without ever having to remove your head from the water.
Water got into my friends Olmypus Stylus 720 camera
The pictures should be on the memory card, and not the hard drive. If you get a replacement camera (the same model) you could put the memory card into it, and your pictures should be there. Otherwise, you could get a memory card reader.
Aug 16, 2008 | Olympus Stylus 720 SW Digital Camera
Ocean Master Famous Brand by  Taiwan 3D Dry Snorkel is Back! Crystal Blue SC Logo
81 people viewed this question
Top Ocean Master Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Ocean Master Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
