Question about American Dynamics ADTTE Touch Tracker Matrix Switcher Keyboard
American dynamic Need to clean the tracker ball in the touch tracker
Have a Navman 5600 tracker and need to clean the internal screen
Most of the odd ball screws are what is called a torx bit. You can find these sets in any hardware or home improvement store.
Dec 14, 2015 | Navman Tracker 5600 GPS Receiver
How to factory restore touch dynamic breeze?
You need to contact Tech support at Torch Dynamic, via this web page.
Touch Dynamic Contact Us
Jun 16, 2014 | Touch Dynamic Breeze AllinOne with...
How should I clean the babble ball?
You should use a clean damp cloth with and gently wash the dirt and saliva off the ball's surface. Don't submerse the ball as it will damage the electronic components of the ball.
Sep 02, 2012 | American Plastic Toys Dogs
Cant get my ball to work
usually all blackberry phones with ball trackers experience this type of problem due to overuse
if you can fix it on your own,do it with care cause some parts are to sensitive.
* need a T6 screw driver
* open and unscrew all sides where the screws are located
* locate the track ball and dismantle it
* clean and align the board interface which the ball tracker is attach..
* assemble it with care....DONE
good luck....
Jun 09, 2011 | RIM BlackBerry Curve 8310 Smartphone
Admca1lcd20w american dynamics monitor/camera unit will not power on after power failure in the building
hi please check your power cable and data cable.if he does not work check his cable jack.thanks
Mar 01, 2011 | American Dynamics ADMCA1LCD20W Monitor
I will press the button "a" and it types "ou", my buttons are just all mixed up also my send button types out "jk"
This problem is caused by contamination UNDER the trackball. Its picked up from sticky/oily fingers operating the tracker ball. Fix:- 1. Checkout web for videos on dismantling the case (easy, but you WLL need a T4 (or is it T5?) multi-point screwdriver (ebay))
2. After accessing the PCB, unclip the tracker ball (magnifying glass and small screw driver). This lifts out as a single assembly.
3 .The area of the PCB reviled under TB now needs cleaning with a cotton wool swab, soaked in a de-greasing solution. DONT use water (even soapy), as this is slow to dry. Use - IPA (Isopropyl alcohol) - safeclens - surgical spirit etc. These will not harm circuit board or components, but MAY affect some plastics. Test small area if unsure The underside of TB assy and ball should also be cleaned. A clean swab damped in mild soap solution can be used to do general cleanup of dirt on white keyboard membrane, case edge grooves etc. allow to evaporate
DONT touch degreased areas with fingers as this will re-contaminate
4. Allow solution to evaporate (around 1 Min.)
5. Re-assemble tracker ball (clicks into position) Re-assemble case using on-line video (step 1)
Apr 06, 2010 | RIM BlackBerry Bold 9000 Smartphone
96 geo tracker setting base ignition timing is there a connector to unplug or what
gee , try my ign page.
you need to place a jumper to freeze the Ignition timing.
1 static timiing.
2; dynamic timing (running ) needs a jumper
http://www.kick-fix.com/IGN_timing/index.html
Sep 28, 2009 | 1996 Geo Tracker 2 Door
Blackberry Pearl Tracker ball not working well
pearls have been know to have the track ball go out on them best bet is to take it to store to have them clean it if you try to clean it and you break the silver ring you void the warranty and will have to pay for whole new phone, in the end they will replace the phone for you
Aug 13, 2009 | RIM BlackBerry Pearl 8100
Blackberry tracker ball won't go up!
its happens to me too so dont worry,,
its probably somthing stuck in there.
you just have to like boof in with ur mouth..lol
like ur cleaning dust..it'll work if u do it couple of times
May 15, 2009 | RIM BlackBerry Curve 8310 Smartphone
American Dynamics ADTTE Touch Tracker Matrix Switcher Keyboard Logo
22 people viewed this question
Top American Dynamics Cameras Experts
Are you an American Dynamics Camera Expert? Answer questions, earn points and help others
