Question about Us Stove Company Bay Front Pellet Stove - 5660
Pellets building up in burn pot - Us Stove Company Bay Front Pellet Stove - 5660
What is causing the ready light to flash red twice when I try to light my pellet stove
[PDF]INSTALLATION AND OPERATION MANUAL - Wood Pellet...
woodpelletheat.com/WinslowManual.pdf
by P Stoves - ‎Related articles
Please read this entire manual before installation and use of this pellet fuel-burning room .... FLY ASH BUILD-UP: For all wood pellet fuel-burning heaters, the combustion ......Ready Light - lights up when stove is ready to operate. Igniting Light ..
Sep 27, 2015 | Pool & Spa
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
We have a heilsa pellet stove model#QCPS-28000 ,its dropping pellets to fast ,how do I adjust the feed.
  1. SET THE AIR INLET DAMPERS
It is not possible for the manufacture to factory set your stove to work properly without some adjustments. The dampers help control the amount of airflow supplied for combustion.
A damper PUSHED IN all the way, maximizes concentrated air flow to the burn pot. This will maintain a robust fire.
The Auger timing is designed to be run, in most conditions, with the dampers closed.
In some areas/conditions, it mybe necessary to adjust the damper open slighty in order to slow down the flame and allow the pellets to keep pace with the rate of burn. This should be monitored closely to ensure you have the propoer feed rate established. If dampers are opened too much, the rate of burn will be very slow and the pellets will build up.
This setting needs to be fine tuned to according to your location and elevation. It is recommended that you start with the dampers pushed in to start.
Feb 20, 2013 | Northern Tool and Equipment Pellet Stove -...
Quadra Fire Pellet stove-will not ignite
I own a Quadrafire pellet stove. I have had this thing for 10 yrs. It seems every year at the start of the season I have some kind of problem. I clean it at the end of the season completely. First couple of burns are fine then get a good cold day and it doesn't work. All the gaskets, the exhaust blower, ignitor, glass front, and exhaust piping have had to be replaced. Now I have a blinking red light in the control box and cannot find anything on line to help. Does anyone know why this red light blinks 3 times every 10 seconds inside the control box? It's not the call for heat light. Think I may change to a wood burning stove to many headaches.
Oct 20, 2011 | Napoleon Auburn Pellet Stove Heater
The auger is not turning to fill the burn pot with pellets. Can hear the motor run but it will not turn it.
Have you recently changed the brand of pellets form what you have used in the past? If so, please understand that no two wood pellet manufacturers make their pellets the same way. If this is the case, you will have to retweak your stove to that brand of pellets you're now using. Also, check the auger to make sure it's not jammed and that auger shaft is properly fitted into the auger drive motor coupling..
Hope this helps solve your problem.
Feb 15, 2011 | Heating & Cooling
How to charge an auger on traeger grill
Turn the control on high and wait about three minutes. Shut contol off and restart in about 1 minute, This should have enough pellets in the auger to start before the hot rod shuts off. You can also put a hand full of pellets in the burn pot and usually bu the time these pellets are burned out the others are there. A couple of cycles usually will start them.
Apr 16, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Ash build up in burn pot
You are burning wood pellets. When you burn wood you produce ash. Some of the ash is extremely hard and hard to remove. What I do is remove the burn pot, take it into my shop and with a screwdriver and hammer, LIGHTLY tap on the hardened ash until the pot is clean. Should only take a few minutes. At the same time you can clean the glass. Even though it may burn very clean, nothing burns wood fuel without by-products...Good luck...Lee
Jan 04, 2010 | Napoleon Auburn Pellet Stove Heater
Pelpro pellet stove will not start. Press the start button, igniter button lights up but nothing happens.
Is the auger light coming on to and dropping pellets into the burn pot? If the auger light is not coming on, you probably have an issue with the board controlling it. If the auger light is coming on, and pellets are dropping into the burn pot and it is still not lighting, then you have only a few other possible problems.
1. The air damper is not allowing enough air in, so pull the damper rod out 1/8" increments until it lights.
2. Your ignitor is faulty and not producing enough heat to light the stove. You can either contact a local dealer and get a replacement ignitor, or you can manually light the stove with a special firestarting gel made for pellete stoves. When you press the start button look into the burn pot. If the ignitor isn't bright orange, you aren't getting enough heat from it.
Hope this helps...good luck.
Oct 11, 2009 | Coleman Dryers
Us Stove Company Bay Front Pellet Stove - 5660 Logo
Top Us Stove Company Home Experts
Donni Steen
Tom Chichester
Are you an Us Stove Company Home Expert? Answer questions, earn points and help others
