Dp n023nvr connection instructions - Computers & Internet
I have placed photos from my pc to Photoviewer 2.3 but when I try to download photos to Coby DP-152 I just get a download failed message. Why? What am I doing wrong?
uninstall photo viewer,then reboot your computer,install the cd with photoviewer on it,(for windows,not mac),next reboot your computer,now,connect your coby to the computer,wait until it is recognized,double click on the photoviewer icon on the desktop screen,let it load,
Coby DP 152 Instruction Manual
May 30, 2015 | Photography
I have a Panasonic Digital Imaging Machine DP 3030 & i want to connect with my PC through USB connector, i n my pc i have win7 Operating system when i connect the usb cable to my pc its automatically...
Panasonic DP-3030 can be used with Windows 7 System. You need to download and install Windows 7 Drivers. Also, User's Manual & Driver's and installation can be download from the official support site. Windows 7 Drivers and all instructions are available here
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 17, 2011 | Panasonic Workio DP-3030 Printer
HOW TO CONNECT IT TO WINDOW 7
Hello
Connect the printer with your computer using USB cable, and install drivers to windows 7 from the CD comes with printer, if you dont have CD download drivers from HERE and install
http://panasonic.net/pcc/support/mfp/dp-8020/index.html
feel free for more assistance
Good Luck
Dec 14, 2010 | Panasonic WORKiO DP-8016 Printer
Is it possible to get a DP-311P print server to work with an Epson AL-C900 laser printer?
It should if your printer has parallel port in the back. Follow the instructions manual, connect print server to the parallel port and then to the network. Get the manual here:
http://www.dlink.com/products/default.aspx?pid=DP-311P&tab=3
Click on support resources and choose our country. Go from there
Aug 01, 2010 | D-Link Air DP-311P Print Server
Firmware upgarde
Why?
If you really need the upgrade, download the instructions and the updated firmware from DLINK's web-site, and follow the instructions.
Oct 29, 2009 | D-Link DP 301U (DP-301U) Print Server
D-Link DP-311P Wireless print server reseting
Hi Luis,
Sorry, it had been my mistake, did not realise your model does not have ethernet port at the back.
On D-Link printer servers that do not have cable connections it requires a couple more operations, you must do the following to connect safely to the server and open configuration:
  • On the rear panel of the DP-311P you fiind a switch to set server to Config mode. Set the switch to
  • Now go to the computer that is connecting wirelessly to the D-Link, go to wireless adapter properties, for example using control panel, and set the adapter to Ad-Hoc mode.
  • Change manually the wireless adapter IP Address so that it is in the same IP Address range
  • as the DP-311P, set the wireless adapter to a static IP address comprised within 192.168.0.2 and 192.168.0.255 excluding 192.160.0.10.
  • Always in wireless adapter settings >> IP configuration, set subnet mask to 255.255.255.0.
  • Ensure you click OK, or Apply in network settings Window, and restart the computer to apply new network settings.
  • Open Internet Explorer and type the IP Address of your wireless print server in the address bar. The default IP Address is 192.168.0.10.
You also find procedure explained at page 7 of the user manual here : D-Link DP-311P
Then follow instructions at page 15 to reset the server.
After you have finished configuring the DP-311P, to save the changes, you must toggle the mode switch on the rear panel of the print server back to “Normal” mode.
Oct 25, 2008 | Office Equipment & Supplies
How can I reset the print server configuration????
Connect a computer to the DLink using a cable. Put 192.168.0.10 in the web browser (internet explorer) and follow instructions at page 15 of the user manual here ( http://ftp.dlink.ru/pub/Printserver/DP-311P/Description/DP311P_manual_100.pdf )
Oct 22, 2008 | D-Link Air DP-311P Print Server
Configuring a Mac Book Pro laptop with a DP 300U Print Server
I connected my HP5MP to the DP-300U LPT1 port.
I configured my port on the DLink Configuration tab, giving it a name "hp5"
...The default login is at http://192.168.0.10/ user:admin pass:(there is no pass by default)
On my Mac, I go to System Preferences > Print & Fax
Click the + to add a new printer
Select the IP option
Choose the Protocol: Line Printer Daemon - LPD
Type in the Address: 192.168.0.10
Type in the Queue: hp5
Print Using: Generic PostScript Printer or better yet, 'Select a driver to use...'
and find the driver for your HP LaserJet 5MP.
Save it. Works like magic. ;-)
If you change the IP address or password on the DLink, just CYA and write it all down on a sticky note then tape the note under the DLink chassis. There's no reset button on the thing, and if you're o a Mac, you won't necessarily have access to the Windows utility to jack with the DP-300U. So, write it down, kidd-o!
Sep 07, 2008 | D-Link DP 300U (DP-300U) Print Server
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
