Question about Lionel Cw 80 Transformer
Lionel polar express transformer lights flash when giving power
SOURCE: My new Lionel CW-80 trans former stopped working
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
Posted on Dec 08, 2008
SOURCE: Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Posted on Dec 23, 2009
SOURCE: New Lionel Polar Express train set-up issue. The
My son just got this train and we are having the same problem. Taking the last car off solved the problem for us. I think it has something to do with accessories and the transformer voltage output (See page 14 and 15 of the instructions).
I have still not determined why it won't run with the final car but am assuming it has something to do with the lights on the cars pulling too many amps and not enough left to run the train. I will let you know if I find a solution. If anyone else knows how to solve the issue, any assistance would be greatly appreciated.
Thanks
Posted on Dec 25, 2010
residentoccu
  • 161 Answers
SOURCE: lionel polar express train is stopping on the track, then becomes disabled
Replace all the batteries, then keep the remote close to the
train. if it's too far away, it will shut down.
Posted on Mar 02, 2013
residentoccu
  • 161 Answers
SOURCE: my transformer on my new polar express does not work what am i doing wrong
No power to the transformer or to the track?
If not to the track, make sure you have the correct wire connections made from the transformer to track.
If no power to the transformer from the wall plug,
sounds like the cord needs replacement.
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
New polar express motor wont engage
It sounds like the gears have worn out or come adrift somehow. You will be able to get replacement gears from any of the Lionel authorised dealers Lionel Authorized Dealers or their replacement parts service Replacement Parts
Dec 28, 2013 | Lionel The Polar Express Train Set
My transformer on my new polar express does not work what am i doing wrong
Dec 19, 2012 | Lionel The Polar Express Train Set
What guage wire should I use to connect a train transformer to the O gauge lockons on the train track? thank, E.S
I have used 18ga lamp wire but you can use wire as thin as telephone wire. My rule of thumb is to use thicker wire (lower gauge number) the more motors on the train you are running. 20 or 22ga is generally used by most.
Jul 05, 2012 | Lionel The Polar Express Train Set
Take wheels off polar express
You will have to solder them using a pencil soldering iron.
Feb 13, 2012 | Lionel The Polar Express Train Set
How the power is transfered to the train?
the power from the wall outlet is ( transformed) to 17voilts AC and comes out on posts on the transformer that red and black wires then are connected to the track The rails on the track are entergized and the wheels and the center pickup ride on the track and transfer the power ot the locomotive. the center rail is common and the outside rail is motor power or whisle power.
Dec 25, 2010 | Lionel Trains The Polar Express O Gauge...
good luck
Dec 08, 2009 | Lionel The Polar Express Train Set
Lionel Cw 80 Transformer Logo
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
