Question about Frigidaire Dryers
Frigidaire dryer FEFB9200ES0
Replaced heating element...now dryer won't start. It beeps when the start button is pushed
  • 9 Answers
SOURCE: dryer heats up but won't turn
Perhaps you have a broken drum belt
Posted on Jun 24, 2008
SOURCE: Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Posted on Sep 15, 2008
barkencoa
  • 3463 Answers
Depending on the make of dryer,there are several possibile reasons for this.
First and foremost, could be a faulty motor- faulty start capacitor, Faulty start relay.
Without more information I cannot be more specific.
Hope this helps.
Please leave feedback.
Thanks.
Posted on Nov 30, 2008
  • 409 Answers
SOURCE: Maytag Epic dryer won't start
hi there,
if it beeps it means that the keypad is sending a signal to the control board to start it but it doesn't. since the control board sends a signal to the motor to start the dryer to spin. does the dryer hum?
Posted on Dec 17, 2008
  • 11 Answers
SOURCE: Kenmore Dryer 110.64632300 won't heat up!
vent pipe kinked not letting heat away from dryer, check vent , or the thermostt stuck and not cycling heating element cycle off
Posted on Aug 12, 2009
It is flashing an E68 lights start to flash and beep
Hello Wanda Leach - Typically error code E68 can indicate one or two issues. First problem could be that one of the keys (buttons) is stuck closed (active). Enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again. If button is free but the error code still exist, the electronic control will need to be replaced. Second issue could possibly be a current leakage to ground on heater or fuse opened. However, I would strongly suggest contacting a professional to the check the resistance of the heating element (should be approximately 14ohms) or the resistance between the ground and both heater terminals. It should be open when heater terminals are disconnected. If the readings are incorrect, replace the heating element.
Sep 30, 2012 | Frigidaire Electric Dryer
DRYER WON'T START
you need a new heating element just had mine fixed did the same thing
Sep 28, 2012 | Frigidaire Electric Dryer
Dryer runs but won't heat
You will need a professional to diagnose the thermal limiter, small version of a fuse, heating element and the dryer/blower assembly.
Aug 17, 2012 | Frigidaire Electric Dryer
Hi my dryer is not heating, when I pressed the start button it sparked around the control knob and tripped the breaker and now it won't heat. could it be a fuse or the heating element themodel # is ...
Look at the start button first it might have burn out in the back or look at the capasitor on the motor, other wise it will more than likely be the timer or the motor.
Jun 07, 2011 | Frigidaire Dryers
My dryer starts to warm up, when I set the drying time dial, even "before" I push the start button. What causes this?
Most likely it is a shorted heating element. Part number is 131553900. It can also be caused by a bad motor switch but the shorted element is much more likely.
Mar 07, 2011 | Frigidaire GLER341A Electric Dryer
Frigidaire fefb9200es0 does not heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 06, 2010 | Frigidaire Dryers
heatman101
Sep 06, 2010 | Frigidaire FEQ1442ES Electric Dryer
Heat but no tumbling
burnt out motor scrapped the dryer and bought a new one
Apr 18, 2009 | Frigidaire GLER642A Electric Dryer
Dryers Logo
20 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
