Why does the drive belt keep coming off the indesit iwme 126
I put the belt back on with difficulty but after spinning a few times, it came off again.
SOURCE: I have a GE front
I have a different suggestion based on my washer's similar problem. If the black stuff is powdery and localized at the back of the unit, more than likely the culprit is the drum pulley itself is warped, causing the belt to chafe against the drum. The black powder is rubber residue from the scraping of belt on plastic. No need to replace unit. New belt and new pulley run about $70 each.
Posted on Jan 13, 2009
aborcass
  • 2651 Answers
SOURCE: Kenmore 970-C41062-00 Spin cycle, belt keeps coming off
sounds as if yo umay have a bad rear bearing, and the off balance of it is "throwing " the belt. magor repair, and would ck with manufacture, for possible part warr
Posted on Mar 19, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a indesit WIB 101 (uk) washing machine.
Remove the belt, and from the front, spin the drum by hand.
If it is noisy or rumbling or feels rough, then the main drum bearings have failed which would explain why the belt was off.
Also check the drum pulley for a brokem or cracked spoke, again this will give you the same symptons.
Please rate my solution.
Thankyou.
Posted on Jan 13, 2010
  • 159 Answers
SOURCE: washing machine drive belt keeps coming off
Try putting some locktite on the thread of the bolt. Loctite is a liquid you can buy to lock bolts into there threads.Alternativley the pulley that the belt runs on may be worn & sloppy in the centre where it goes on the metal shaft.you may need a new pulley as well as Loctite..but try the Loctite first.
Posted on Jun 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: Washing machine not working
The lid switch/latch has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 10, 2010
Indesit WIB 101(UK). Why does drive belt keep sliding off the drum pulley?
things like tensioners and idlers wear out 8 years seems about normal .some do better some do worse .
Apr 15, 2016 | Washing Machines
Indestit washing machine model iwme 126 is stuck on 4h does my one know how to restet the machine or fix this?
Try pressing and holding the power button until it flashes then turn off and turn on again the light will flash again and then reset the machine.
Not sure if this will work on this model but has worked on two Indesit machines I have had (both different models)
Apr 18, 2015 | Washing Machines
Indesit widxl 126 washing machine fabric conditioner compartment blocked
Indesit widxl 126 washing machine fabric conditioner compartment blocked.
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2011 | Washing Machines
Hi My Indesit washing machine is not spinning it sounds like the function of spinning but without the movement.
hi if the motor is running then sounds like belt has come off if you replace the belt and it happens again then it could be the bearings or pully wheel
Jan 09, 2011 | Indesit Washing Machines
Thankyou.
Jan 13, 2010 | Washing Machines
Indesit washer not spinning
I had exactly the same problem. All seemed ok, except no spin. I followed Shaun's advice and replaced the module board. Cost of about f£23 from ebay, but similar price on espares.co.uk. Fixed it. Thank you.
Aug 04, 2009 | Indesit W 123 Front Load Washer
Jul 10, 2009 | Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
