Question about Pyle PLTS78DUB Car Video Player
Wiring power radio
I need to know the wiring diagram for this radio to 2008 chevy colorado
  • Pyle Master
  • 15,941 Answers
Get a converter cable, dont cut wires.
Posted on Feb 09, 2014
Wiring Pioneer DEH-X1810UB CD Receiver in 2012 Chevy Colorado
Are you referring to the trucks wiring harness? I hope you purchased an integration harness. Your truck has a databus system and an integration harness is needed to maintain certain functions including door chimes, warning chimes, on star (if equupped) etc.
also the factory radio does not have a switched power lead to turn the radio power on with the key. That is also handled via databus.
Aug 26, 2016 | Cars & Trucks
2008 Chevy Impala radio wire digram
you are going to have make and model ## of the car stereo, if GM
still go to have model ## off the back of stereo and what would be better is a part number would be very good.
www.freeproductmanual.com
www.infolink.com
www.wikipedia.org
schematics
www.eserviceinfo.com/equipment_type/schematics
www.free-schematic.blog.spot.com/
www.electronicshelponline.com/radio_wire_diagrams
other sites for help
www.manualsonline.com/radio_wiring_diagram
www.wikipedia.org/wiring diagram radio
www.alltheinternet.com/radio_wiring_diagrams
Feb 25, 2015 | 2008 Chevrolet Impala
No fuel pump voltage 2008 chevy colorado pickup
WHAT DOES WORK ? WHEN YOU WASH DOWN ENGINE YOU NEED TO COVER/WRAP/ ENCLOSE ELECTRICAL ITEMS !!! COIL, ALTERNATOR, DISTRIBUTOR, CONTROL MODULES, ETC., OTHERWISE, YOU'VE GROUNDED OUT YOUR ELECTRICAL SYSTEM !!! USE COMPRESSED AIR TO BLOW OUT ALL MOISTURE FROM THESE ITEMS MENTIONED. POWER FOR FUEL PUMP SYSTEM COMES FROM BATTERY, TO A JUNCTION BLOCK TERMINAL, WHICH HAS FUSIBLE LINKS WHICH ACT LIKE FUSES,, TO PROTECT EACH SYSTEM . DON'T KNOW IF THATS YOUR PROBLEM , BUT STRANGER THINGS HAVE HAPPENED ! FUSIBLE LINK LOOKS LIKE A HEAVY GAGE WIRE, BUT COULD BE A SINGLE STRAND OF WIRE INSIDE INSULATION ! NEED TO BE REPLACED IN LIKENESS !!! YOUR VEHICLE NEEDS TO DRY OUT ! MAYBE I'M ALL WET ? BUT CHANCES FAVOR THE PREPARED MIND !!! YOU NEED TO UNDO WHAT YOU DID , MAKES SENCE, YES ? ITS WHEN YOUR PROBLEM CAME TO BE ! OTHERWISE, INSPECT EVERY WIRE IN THE FUEL PUMP CIRCUIT, ESPECIALLY THE GROUND WIRES !!! THEY ARE JUST AS IMPORTANT AS THE POWER WIRES, WITH OUT QUESTION ! YOUR RELAY GOT BACKSPLASHED LOOK HOW MANY WIRES GO THERE ! IT ALSO HAS ITS OWN FUSE. THINK I COVERED IT, GOOD LUCK , YOU JUST MIGHT FIX THE PROBLEM AND NOT REALIZE IT TILL IT STARTS !
Apr 02, 2013 | 2008 Chevrolet Colorado 2WD
2005 Chevy Colorado. When I turn the key to the on position it immediately blows ignition 15amp fuse. What could be the problem?
You will need the wiring diagrams to track down what wiring the fuse powers and where it is routed, only the factory diagrams have this detailed info. You can access the factory repair manuals here for a small yearly subscription charge. www.alldatadiy.com
Aug 08, 2012 | 2005 Chevrolet Colorado
Chevy cobalt headlight wiring diagram
WHY did everyone give RADIO wire diagrams when he CLEARLY asked for Headlight wiring ****
Feb 09, 2012 | 2008 Chevrolet Cobalt LT1
I need the factory audio color code diagram for a Chevrolet 2006 Colorado
2006 Chevrolet Colorado Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. The accessory turn-on is controlled by the lan serial network. Run a wire to the fuse box or ignition switch harness.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
pls rate
Apr 05, 2010 | 1998 Chevrolet Cavalier
Need a wiring diagram for 1997 chevy s-10 tryin to install radio
bulldogsecurity.com is the place to go for all free wiring diagrams.
Dec 04, 2008 | Pioneer DEH-P2900MP CD Receiver...
Installing a CD player in '08 Aveo in plac eof stock AM/FM radio
You should check with Car Toys or Best Buy but you will probably need an adaptor and a wiring harness. If your doing it yourself your going to need to know how to get the stock radio out and the wiring diagram for the Aveo. Sometimes you can find the wiring diagram on Google by searching for it but usually finding diagrams for 2008 vehicles takes a year or two before it becomes available.
If your CD player has a tuner in it already you shouldn't need one. If it doesn't have one, that presents some other options.
Jun 22, 2008 | Sony CDX-CA400 CD Player
2004 Chevy Colorado
i have a 2005 colorado it was in a accident the radio comes on but it does not pick up any chanel and thegas gauge does not work
Jun 02, 2008 | 2004 Chevrolet Colorado
Pyle PLTS78DUB Car Video Player Logo
145 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
