Question about GMC Denali 700C Road Bike
Can i get a tubeless rear wheel for my denali 6061?
Which tyre best for honda cb shine 80/100-18 tubeless or 3.00-18 tubetype
Hi Nagraj, it all depends on what type of wheel you are running. If your wheel has spokes you must use a tube, if your wheel is cast you can run tubeless. Good luck
Apr 06, 2015 | Honda Motorcycles
Why hero Impulse bike don't have tubeless tyres?
Can't run tubeless tyres with spoked wheels.
Mar 27, 2015 | Hero Motorcycles
Restricted code for nokia 6061 imei 011146002505657
Hi, You can get the restriction code for a Nokia 6061 from www.simpleunlocking.com/nokia-6061/rs16wp9/ at low cost.
UNLOCKING STEPS FOR NOKIA 6061
1 - Switch on your Nokia 6061 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6061.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6061 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6061 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6061
Nov 19, 2012 | Nokia 6061 Cellular Phone
Sir i have harley davidson sportster 2011 . The air from rear wheel spokes started leaking of sudden . can u suggest what could be the problem .
Since I specialize in working on the older bikes that the dealerships will no longer service, I'm afraid that I am at a lose as to what type of wheels H-D is putting on their newer machines. With that said, I will say that I have never seen a "wire spoked wheel" that was capable of being run with a "tubeless tire" with any degree of reliability. Wire spoked wheels by their very design do not lend themselves to being run with a tubeless tire simply because it's too difficult to "seal" the wheel with all the spoke nipples in it. Even those that do advertise to be capable of "tubeless tire applications" have problems. The spokes move making sealing them a problem. I'd NEVER run a wire spoked wheel tubeless. If you're talking about a cast wheel, this is a different story. If the cast wheel is leaking and the bike is a 2011 model, I'd take it back to the dealer and talk with them about it. It should not do this.
Good Luck
Steve
Aug 14, 2011 | Harley Davidson XL 1200 C Sportster Custom...
IHave a kawasaki el 250 1995 air leaking from the rear tyre but its coming from the wheel spokes, any idea how to solve this Thanks mark
Yes if it is leaking from the spokes that means that you need a new inner tube. Wheels with spokes are only supposed to use tubed tires. If you want to go tubeless there is a place in California that will seal the wheels for you. Look it up on Google, do a search for sealing rims with spokes.
Feb 18, 2011 | 1998 kawasaki EL 250 Eliminator V
What are the wheel and tire sizes front and rear for my 99 883 sposter?
Tire sizes. Front 100/90-19
Rear 130/90-16
Wheel sizes front laced - 19 in.
rim width and contour - T19 X 2.5 TLA
Tube size - MJ90-19
Wheel size rear laced - 16 in.
rim width and contour - T16 X 3.00 D
Tube size - MJ90-16
Wheel diameter tubless rim front - 19 in
rim width and contour - T19 X 2.5 MT
Wheel diameter tubeless rim rear - 16 in.
May 26, 2010 | 1993 Harley Davidson XLH Sportster 883
Rear wheel bearing is out, how easy to repair
not easy,you will probably need a hydraulic press to remove and reset the bearings
Apr 20, 2010 | 2002 GMC Yukon Denali
Nx 650 dominator rims and tubeless tyres
If the hubs and sprocket locations are the same, then you could change it no problem.I personally found that there is little or no advantage having one or the other, except that if the wheel combination of tyre and rim is lighter, then your handling will benefit marginally for obvious reasons.
If you go bigger on the rim, you lose out slightly on acceleration, but improve your MPG or you could simply compensate by going up a tooth or two on your back sprocket.
As far as your long outback trek, I would recommend using a tube as if you have a problem with the tyre or rim, you can get stuck with no way to pump it up.Whatever you decide, I recommend taking a spare tube , puncture repair kit.
Hope this helps, and good luck on your trip.
Sep 20, 2009 | 2001 Honda XR 650 L
Tube or tubeless??
If the rims are with spokes they use tube.If it has aluminum rims (like a street bike) then you can install tubeless tires
Jun 09, 2009 | 1991 Suzuki DR 650 RS-E
GMC Denali 700C Road Bike Logo
42 people viewed this question
Top GMC Cycling Experts
Mike
Arnie Burke
Arnie Burke
Donald Ayers-Marsh
Are you a GMC Cycling Expert? Answer questions, earn points and help others
