Question about Bausch and Lomb Legacy 12-1056 Binocular
Alignment off need a place to send for repair
Let me clarify - it is the dovetail rail that came off.
You can use Devcon two ton epoxy to repair it..clean the parts very well..sand it clean. clean it with acetone....mix it in equal parts.. and align and seat the dovetail carefully .. hold in place until it sets...
Devcon 0 85 oz 5 Minute Epoxy
Jul 06, 2017 | The Optics
Not sure if i need an alignment or just tie rod ends replaced..steering wheel shakes and goes off to one side, how do i know if i need an aligment as well when i take the car in for service?
You need to find an alignment shop, that
does nothing else
No chain store or mall repair place or franchise
They will replace all worn parts FIRST & fix ALL
you issues THEN Align the vehicle
Your not going in for any service
You go for a ride at the alignment shop
They will explain things if you don't leave yourself open
to seeming uneducated
Take a note pad & pretend to take notes & ask questions
Take a tour of the inside of the shop & get a feel for the place
& the owner,take charge & use Google & You Tube Video
to prepare yourself & brush up on the problems
Feb 13, 2013 | 2005 Ford Freestar
Hello i have no standard regarding Alignment out so please help me .
You only go to an alignment only shop
Not a chain store repair place
You only have a 4 wheel alignment done
They need to check all suspension for
wear,etc and check ride height first.
Your car only wants to go where your back wheels are pointed
So you need to reference all four & the latest equipment
is alway nice if you get lucky where you go
Apr 27, 2011 | Suzuki Esteem Cars & Trucks
I have an HP 6110 all in one printer. I get a continuous error message saying to align printer cartridge although the cartridges seem to be loaded correctly. I have replaced the cartridges even though they...
you need to align your printer cartridge, to align the cartridge go to start button on your computer desktop then click the setting and choose the printer and faxes then right click your installed printer HP 6110 then choose the properties of your printer then you click the maintenance menu then you see an option to align your printer cartridge...just click it and wait until finish aligning your cartridge..
Mar 02, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Pll broken
If the PLL is dead, it's almost not worth saving. Even if you get a replacement PLL and change it, the radio will not work right without an alignment. To align the radio you will need the factory alignment guide, watt meter, volt meter and an oscilloscope and a basic knowledge of electronics.
Oct 20, 2010 | Uniden BCD396T 6000-Channels Handheld CB...
Cannot send fax lid open cannon jx200
The lid sensor is damaged or out of alignment. You can sometimes wedge the push arm back into place or else permanently wedge the sensor into the on position.
Jun 04, 2010 | Office Equipment & Supplies
Not keying up after chanel34 when if it is on high tone and neddel is not going to 30db on usb or lsb it is cobra 148gtl dx
It sounds like the radio may need to be fully aligned. Sounds like its not adjusted to transmit properly in the correct frequency range.
has any one attempted to broadband this radio? if so it could have been done wrong.
I could tell you the alignment procedure but you would need a watt meter, oscilloscope, and a volt meter.
As well its an in depth procedure. So some electronic experience is necessary.
Please let me know if you have the equipment to do the alignment and I will get you the info. If not you best bet is to take it to a radio shop, or send it to a repair shop. If you are going to send it I recommend http://www.sparkyscbshack.com/Home.html
Feb 23, 2010 | Radio Communications
My Symbol MC50 won't pass the align screen..many reboots without success. Any suggestions?
if it doesnt pass the align screen its the digitizer unfortunately reboots wont help it will need to be sent in for repair, you can contact me if you would like to send it in
kim ganoe
kganoe@datexcorp.com
Feb 15, 2010 | Symbol MC70
My front suspension make loud noises
Not good, you may need at least tie rod ends. Best take it to an alignment place. If you have some tools and can check the tie rod ends for excess play they can be changed with moderate effort. But you need to check struts and ball joints and will need special tools. Some autoparts lend the tools for this repair. But it still should be aligned afterwards. You will take longer doing this yourself than a repair shop.
May 11, 2009 | 1994 Ford Thunderbird
Bausch and Lomb Legacy 12-1056 Binocular Logo
Top Bausch and Lomb Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Piyal Perera
Piyal Perera
Andrew Taylor
Andrew Taylor
Are you a Bausch and Lomb Optic Expert? Answer questions, earn points and help others
