Question about Winter Sports
I have a 1985 yamaha phazer that always bogs when im doing under 60km/h but after that its fine would it be the jetting because i do have a psi race pipe on it
When i ride under -15C the engine seems to bog more than it usually does. also the piston beside the clutch has less compression than the other one.
2 Suggested Answers
  • 796 Answers
SOURCE: 1989 yamaha phazer
Do you know that the choke is there to be used until the engine has warmed up?, not just to start it?
Posted on Dec 15, 2013
Where find The codes for yamaha phazer 2007 ?
http://www.hardcoresledder.com/forums/364-phazer/503962-yamaha-phazer-error-codes.html
Mar 05, 2015 | Yamaha 2007 Phazer GT
I had a problem with a 1992 phazer on low speeds mine picked up fine at first but then bogged when I slowed down again a new clutch kit fixed the problem
Feb 08, 2014 | Winter Sports
1989 yamaha phazer
Dec 15, 2013 | Winter Sports
Starts fine when push throttle it bogs down have to turn choke on to keep running but runs great wide open 1989 yamaha phazer
you probley have a weak coil it has enough power to start and run at low speeds but at high speeds the coil does not put out enough spark
2003 yz 250 starts and idles but runs rich and bogs as soon as the throttle is applied
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent or overflow.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
11. The enrichner valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2002 yz250 idles fine but bogs and tries to die when twisting the throttle...
Bike dies when you give it throttle
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 19, 2012 | 2003 Yamaha YZ 250
How do i set the timing on a 1990 yamaha FZR600 . the bike idles fine but when i start to move in first gear it feels like its ggetting too much gas. pleas help
Hi, Www_jimmystr and the usual suspects are:
3. Inlet system air leak.
6. Plugged bowl vent.
12. The enricher valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
SOHC 4 Owners Club Forums
Bogs down at throttle and backfires like war The FZR Forum
https://www.tradebit.com/filedetail.php/2864660-yamaha-fzr-600-service-repair-manual-pdf
1985 Yamaha IT200N Parts
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Jun 02, 2010 | 1990 Yamaha FZR 600
Yamaha 2001 ttr 250. Bogs above half speed, under load
I have the same problems with my 1999 TTR 250, were you able to find out anything?
Walt
goalhawk@hotmail.com
May 04, 2010 | 2002 Yamaha TT-R 250
I amtrying to hook up a moter from a 1993 yamaha
ditch the oiler on the sled cause they will fail. premix your fuel at 40:1 and never worry about it
Nov 21, 2009 | 1985 Yamaha XJ 700 X Maxim
1985 yamaha moto 4 200 power surges
Check the carbs if all jets are well placed, needles all at same height, float levels equal, collars between carbs and cil head all tight, rubbers not punctured or broken...
Aug 21, 2009 | 1985 Yamaha FJ 1100
Winter Sports Logo
15 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
