Question about Peavey PV6 Mixer
PV6 driver Can't find drivers online and don't have disk
What is the power supply number for peavey pv 6
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Mar 26, 2014 | Peavey PV6 Mixer
How ti install in chain to amp input
the instrument should be plugged into the LINE jack, and the amp should get it's signal from either the MAIN L or R jacks
Feb 17, 2014 | Peavey PV6 Mixer
High pitch feedback
you are sending the signal back on itself, hit the usb to main switch to off.
Nov 12, 2013 | Peavey PV6 Mixer
Problems
This may be an issue with your power supply regulation, check opamp's ic's for +15V at pin-8 and -15V at pin-4, this may help to troubleshoot the issue.
Jul 03, 2013 | Peavey PV6 Mixer
Clip is on as soon as I turn power on.
Sometimes this may be a result of a subsonic or supersonic signal, if it still does it with nothing at all plugged in and the FX turned right down there is a fault with your mixer.
Apr 16, 2013 | Peavey PV6 Mixer
Manual for Peavey PV6 6 channel mixer
Aug 05, 2012 | Peavey Electronics Peavey Pv6 6-channel...
I have purchased a peavey pv 6 (not the usb) and I have a squeal problem when I activate the tape to mix button and rising the master fader to 0 and my headphone volume. I am using a creative soundblaster...
You MUST turn off the echo from the computer OR remove the sound card to line in connections. The tape out goes through the sound card and immediately back out to the tape in and around it goes for feedback.
Jun 28, 2011 | Peavey PV6 Mixer
All the channels shows the Clip red light on the Peavey PV6 6 channel mixer and I´m unable to use the device ...Whats is the solution??
It is likely there is a failure of one of the power supply voltages. The solution requires troubleshooting that is NOT DIY unless you are electronically skilled.
Oct 26, 2010 | Peavey 32fx USB 32 Channel Mixer
I have 2 peavey 2600 amps with 1 pv6 mixer wanting to run subs off 1 amp and sp2s off other amp but only have 1 main output on the pv6 mixer whats my solution
you can run one amp from the main out puts and the second amp from the CTRL Room out puts. The CTRL ROOM are outputs that are linked to the same bus as the master fader. This will work fine...
Best of luck
Sep 02, 2010 | Peavey Pv 2600 Power Amplifier
PV6 clip lights stay on
You've lost one of the power supply rails. It needs to be repaired or replaced.
Jan 15, 2009 | Peavey 32fx USB 32 Channel Mixer
Peavey PV6 Mixer Logo
18 people viewed this question
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
