Question about Steamist SM-15 1503-IM
I own a SM-15 model. Power doesnt come on.
Serial #5507933. No power
I accidentally deleted my system ui my model No is sm t110
  1. Press Power button, until your tablet is off.
  2. Now press and hold together: Volume Up + Home button + Power button, until you see Recovery mode.
  3. Then select "wipe data / factory reset" using Volume buttons to navigate and Power button to confirm operation.
  4. Next choose option "Yes -- delete all user data".
Samsung Galaxy Tab 3 Lite SM T110 Hard Reset
Jul 10, 2017 | Computers & Internet
Tip
Jvc repair manuals
JVC_FL2_LT-26DS6BJ_LCD_TV_[SM].pdf PDF (View) 60 25 17.1 MB
JVC_FL2_LT-26S60BU_LCD_TV_[SM].pdf PDF (View) 28 8 17 MB
JVC_FL2_LT-37DM6ZJ_LCD_TV_[SM].pdf PDF (View) 34 7 27 MB
JVC_FL2_LT-37DS6BJ_LCD_TV_[SM].pdf PDF (View) 28 14 1.4 MB
JVC_FL2_LT-37DS6FJ_LCD_TV_[SM].pdf PDF (View) 29 5 23.2 MB
JVC_FL2_LT-37M60BU_LCD_TV_[SM].pdf PDF (View) 25 4 25.3 MB
JVC_FL2_LT-37S60BU_LCD_TV_[SM].pdf PDF (View) 17 4 22.4 MB
JVC_FL2_LT-40X776_LCD_TV_[SM].pdf PDF (View) 57 17 23.5 MB
JVC_FL2_LT-Z26SX5_LCD_TV_[SM].pdf PDF (View) 19 4 20.2 MB
JVC_FL3_LT-40FH96_LCD_TV_[SM].pdf PDF (View) 25 9 21.2 MB
JVC_FL_LT-26C50BU_LCD_TV_[SM].pdf PDF (View) 13 3 17.1 MB
JVC_FL_LT-26D50BJ_LCD_TV_[SM].pdf PDF (View) 14 3 22 MB
JVC_FL_LT-26X575-KA_LCD_TV_[SM].pdf PDF (View) 14 3 3.8 MB
JVC_FL_LT-26X575-T_LCD_TV_[SM].pdf PDF (View) 15 4 16.7 MB
JVC_FL_LT-32C50BU_LCD_TV_[SM].pdf PDF (View) 26 5 17 MB
JVC_FL_LT-32D50BJ_LCD_TV_[SM].pdf PDF (View) 30 6 22.3 MB
JVC_FL_LT-32X575-KA_LCD_TV_[SM].pdf PDF (View) 27 5 3.7 MB
JVC_FL_LT-32X575-T_LCD_TV_[SM].pdf PDF (View) 23 12 16.7 MB
JVC_FL_LT-Z26SX4B_LCD_TV_[SM].pdf PDF (View) 12 4 20 MB
JVC_FL_LT-Z32SX4B_LCD_TV_[SM].pdf PDF (View) 18 4 19.3 MB
JVC_FL_LT-Z32SXB4_LCD_TV_[SM].pdf PDF (View) 15 3 19 MB
JVC_FT_LT-26A60BU_LCD_TV_[SM].pdf PDF (View) 20 4 10.5 MB
JVC_FT_LT-26AX5_LCD_TV_[SM].pdf PDF (View) 17 6 8.7 MB
JVC_FT_LT-32A60BU_LCD_TV_[SM].pdf PDF (View) 48 5 10.6 MB
JVC_FU_LT-26X506_LCD_TV_[SM].pdf
JVC_FU_LT-26X506_LCD_TV_[SM].pdf PDF (View) 18 6 8.3 MB
JVC_LM-15G_LCD_TV_[SM].pdf PDF (View) 11 3 1.7 MB
JVC_LM-17G_LCD_TV_[SM].pdf PDF (View) 10 5 2.3 MB
JVC_LT-15B60SJ_LCD_TV_[SM].pdf PDF (View) 11 3 6 MB
JVC_LT-17AX5_LCD_TV_[SM].pdf PDF (View) 12 4 8.8 MB
JVC_LT-17B60SU_LCD_TV_[SM].pdf PDF (View)
JVC_LT-17C50BU_LCD_TV_[SM].pdf PDF (View)
JVC_LT-17D50BK_LCD_TV_[SM].pdf PDF (View)
JVC_LT-17S2_LCD_TV_[SM].pdf PDF (View) 10 2 12.2 MB
JVC_LT-17X475_LCD_TV_[SM].pdf PDF (View) 12 5 14.9 MB
JVC_LT-20A5_LCD_TV_[SM].pdf PDF (View) 11 4 11.6 MB
JVC_LT-20A60SJ_LCD_TV_[SM].pdf PDF (View) 11 3 5.4 MB
JVC_LT-20B60SU_LCD_TV_[SM].pdf PDF (View) 12 3 4.6 MB
JVC_LT-20DA66SK_LCD_TV_[SM].pdf PDF (View) 9 2 9.7 MB
JVC_LT-20E50SU_LCD_TV_[SM].pdf PDF (View) 8 3 1.6 MB
JVC_LT-23B60SU_LCD_TV_[SM].pdf PDF (View) 9 4 5.7 MB
JVC_LT-23C50BJ_LCD_TV_[SM].pdf PDF (View) 8 1 7.5 MB
JVC_LT-23C50BU_LCD_TV_[SM].pdf PDF (View) 10 2 2.1 MB
JVC_LT-23D50BK_LCD_TV_[SM].pdf PDF (View) 8 4 6.6 MB
JVC_LT-23E31_LCD_TV_[SM].pdf PDF (View) 9 7 12.8 MB
JVC_LT-23S2_LCD_TV_[SM].pdf PDF (View) 8 2 12.4 MB
JVC_LT-23X475_LCD_TV_[SM].pdf PDF (View) 17 7 3.5 MB
JVC_LT-26B60BJ_LCD_TV_[SM].pdf PDF (View) 13 2 9.2 MB
JVC_LT-26X575-KA_LCD_TV_[SM].pdf PDF (View) 13 3 23.3 MB
JVC_LT-32X575-KA_LCD_TV_[SM].pdf PDF (View) 28 10 23.3 MB
JVC_MK_LT-26C31BC_LCD_TV_[SM].pdf
JVC_MK_LT-26C31BC_LCD_TV_[SM].pdf PDF (View) 13 7 15.4 MB
JVC_MK_LT-26C31BJE_LCD_TV_[SM].pdf PDF (View) 9 2 1.3 MB
JVC_MK_LT-32C31BJE_LCD_TV_[SM].pdf PDF (View) 16 10 15.2 MB
JVC_MK_LT-Z26S2_LCD_TV_[SM].pdf PDF (View) 8 1 15.9 MB
JVC_MK_LT-Z32S2_LCD_TV_[SM].pdf PDF (View) 15 10 14.8 MB
JVC_MX-DVB10_[SM].pdf PDF (View) 15 8 11.9 MB
JVC_SB5_LT-26WX84-K_LCD_TV_[SM].pdf PDF (View) 9 2 5.7 MB
JVC_SB5_LT-26WX84-SJ_LCD_TV_[SM].pdf PDF (View) 12 1 3.5 MB
JVC_SB5_LT-26WX84_LCD_TV_[SM].pdf PDF (View) 10 3 5 MB
JVC_SB5_LT-32WX84-HA_LCD_TV_[SM].pdf PDF (View) 11 1 4 MB
JVC_SB5_LT-32WX84-K_LCD_TV_[SM].pdf PDF JVC Televison & Video
I replaced the mainboard on my proscan TV, but the picture still won't show, what's wrong?
Hello Anonymous,
By putting your number (plded4079-sm) on eBay... immediately produced no "USA" power boards...
Likewise an AMAZON search failed.
Which means most FIXYA volunteers are going to
have some difficulty ... The number of your PROSCAN are the only thing that DIFFERENTIATES your set from our similar USA (domestic) models...
We just call them "power boards"... and they are popular
because the new industry standard for capacitors is
"cheap & cheesy"...
The bright-side = there is a bounty of "SPARES" on eBay...
and their reliability (& reputation) is NOT much worse...
(I'm just saying) Shop around...!!
Cautionary statements:
You MUST VERIFY your own circuit pack numbers
(stare & compare)...
Get and use ESD (electro-static Discharge) wrist straps while handling EVERY CIRCUIT BOARD you care about.
(see below)
Take lots of pictures going in... Put EVERY wire
EXACTLY back from whence it came...
and... FORCE NOTHING.
PS50B450B1WXXU = UK
PN50C450B1DXZA = USA (wrong)
Failed searches
http://www.shopjimmy.com/proscan/plded4079-sm
http://www.searspartsdirect.com/model/search.html?q=plded4079-sm
ESD wrist strap
Amazon com Rosewill ESD Anti Static Wrist Strap Components RTK 002 Black...
Carnac the Magnificent
May 02, 2017 | Proscan Televison & Video
Will not power up
Have you tried resetting your Nuvi.Press and hold the RESET Button on the bottom of the GPS for several seconds.( reset button is behind the serial number paper).If this doesnt solve the problem,try rebooting by holding the Power Switch for about 15 seconds.Good luck.
Sep 29, 2009 | Garmin nuvi 255W GPS Receiver
Re jensen desck
what model are you working with and what is the serial number, ill get you your code... but i need both the model and serial number...
Aug 10, 2008 | Car Audio & Video
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Steamist SM-15 1503-IM Logo
Top Steamist Electrical Supplies Experts
Craig Butler
Craig Butler
ray gallant
Are you a Steamist Electrical Supply Expert? Answer questions, earn points and help others
