Question about Minolta Office Equipment & Supplies
WHATS THE C-0500 ERROR CODE MEAN - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,161 Answers
The code means that the fuser unit the hot part which fuses the toner to the paper is not getting the 117VAC or120VAC power to the heating lamps inside the upper fusing roller and or bottom. Fusing unit uses heat and pressure to fuse the toner to the paper.
Posted on Jan 04, 2015
5 Suggested Answers
  • 990 Answers
SOURCE: Minolta Di550 error code C-0500
Dear sir; the error code you post out,I check the manual it said "low fuser temp" my suggestion go to check the fuser lamp inside the fuser roller of the heating unit, you may try to reset before you go for it; the easy way just open and close the lower front door,just try it and let me know the resolve. HAVE A HAPPY HOLIDAY !!!
Posted on Dec 17, 2008
  • 1294 Answers
SOURCE: Dialta di450 Error Code C-0500
Fuser unit problems.Check fuser lamp in the upper and lower fuser roller,check the termofuse & termistors.
Posted on Jul 30, 2009
  • 4 Answers
SOURCE: I was given a minolta photocopier and it has the
That is a "low fuser heat" code. You can try to reset the code by using a paper clip and pressing the small "reset" button on the right side of the control panel. Hopefully it will get rid of that code for good... if not, You will need to have your fuser looked at (heat lamps, thermisters, etc.) Hope this helps.
Posted on Sep 17, 2009
  • 149 Answers
SOURCE: IRC5185i Stopped working. Shows Error code
i looked to see if there was a user fix for this problem but there isn't. It sounds like the driver pcb board could be blown and or the fixing assembly needs replace.
Posted on Jun 10, 2010
What are the symptoms of a bad psu for vizio m550nv
Vizio 0500-0612-0030 Power Supply / LED Board for M550NV
www.shopjimmy.com/vizio-0500-0612-0030-power-supply-...
ShopJimmy
$77.42 - ‎Out of stock
This Vizio 0500-0612-0030 Power Supply / LED Board for M550NV (0500-0612-0030) works for these ... The odds we'll get it soon: Bad (What does this mean?).
Vizio 55" M550NV 0500-0612-0030 LCD Power Supply ...
electropartsonline.com/vizio-55-m550nv-0500-0612-0030-lcd-power-su...
Vizio 55" M550NV 0500-0612-0030 LCD Power Supply Board Unit Motherboard. ... Any tears or bad connections between boards must be replaced FIRST. 2.
EASY HOW TO FIX LED Vizio TV- no power - YouTube
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no power service repair ... I can not get it to power on so I ...
Jan 17, 2016 | Vizio M550NV 55 in LCD HDTV
Why am i still getting error code 0500 i bought a new fuser unit.
You need to reset the machine, the new fuser does not reset the machine.
May 03, 2014 | Konica Minolta magicolor 1690MF All-In-One...
0500 error dialta cf 2002
open front door lay on your back look for the small hole on the right side touch the small switch with a screwdriver to reset the machine must be on
Jan 16, 2014 | Minolta DiALTA Di520 Laser Printer
Vauxhall fault codes 1405 and 0400 and 0500 and 0105 what does it mean
0105 - MAP/BP Circuit Malfunction
0400 - EGR Flow Malfunction
0500 - Vehicle Speed Sensor Malfunction
1405 - DPFE Sensor Upstream Hose Off Or Plugged
Sep 18, 2013 | Cars & Trucks
Trouble shoot konica minolta error code 0500
need to know model number
most konica minolta 0500 codes is fuser related and a tech has to reset it
Aug 22, 2013 | Konica Minolta bizhub Office Equipment &...
CALL SERVICE (0500) what does it mean ? how to solve it ?
The users manual says when you get this error to reboot machine and if the error doesn't go away the problem can only be fixed by an authorized service provider.
Dec 28, 2012 | NEC Oki Mc160N A4 Colour Multifunction...
Jun 05, 2010 | Canon imageRUNNER 5000 Copier
Jul 29, 2009 | Minolta Office Equipment & Supplies
Minolta dialta di 250 error code 0500
Hello
E0500 means :"Fuser problem. Warm-up incomplete"
Feb 08, 2009 | Minolta Office Equipment & Supplies
Dec 17, 2008 | Minolta EP1030/1030F CS/PRO Copier
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
