Question about Refrigerators
Kitchen aid frig not cold
Refrigerator suddenly not getting cold. Pull out Freezer on bottom works fine.
We had a issue a couple of times in the past where it would stop working for a day, I would turn the switch on top off and on and then it would start working again. This time the switch is not helping. It has not been cleaned since we bought it in 2004. I hear the fan uptop working. Any ideas?
  • 1 more comment
  • trjohnson Oct 31, 2007
    Model # KBLC36MHS01
    Problem is Frig is warm and Freezer is fine. Not a lot of ice and just a nice coating of frost on coils. Turns out the evaporator fan not working so I replaced this first. New Evaporator fan also not working. I turned it back on for four hrs and still nothing.
    Any ideas what the next step would be? There was not alot a defrosting after I turned it off the first time.
    It seems to be getting plenty cold in freezer though not backed up with ice. The evap fan is not working so I replaced that and still not working. Would gassing cause the fan not to work? All lights etc are on.
  • trjohnson Nov 15, 2007
    No I don't think that is the problem the evap fan is not coming on. Here is update. Update to this issue. I was told that the evap fan in this model did not run through the defrost thermostat but instead directly to the cicuit board in the control panel. Since we had a lightning strike about the same time this thing conked out thought this seemed like a likely suspect. So I waited a week to get the part and installed new board and still no evap fan movement. I really need to figure this out asap please help!!
  • 4,102 Answers
Sound like it could need re gassing has the unit been nocked or pushed up against a wall this might be the case as sometimes it just needs regassing you should be able to get someone locall to come out and regass it for you hope this is some help
Posted on Oct 31, 2007
  • paul proctor Nov 15, 2007
    does the circuit board with the evap fan conector on it also have the conectors for the lights or is this a seperate board as you have replaced the board then it should work but as it still not work it then must be a power problem where does the board get its power from can you see the conectors for the power also have a look to see if their are any internal fuses also look on the board you have taken out to see if you can see a heat problem or a short prob look see if anything has melted or swelled up if you have replaced fan and board then it is deffinately a power problem getting to the board follow the power wires to the board and check wher they go post back when you have had a look at this i will try help you some more
Maytag side by side msd264rheb freezer works frig isn't cold. We found ice on bottom freezer side and did melt it with a hair dryer. Frig vent is letting in, now a little cool air, but not a lot.
If you found ice in the freezer then there is usually a lot more behind the back plate. If you let it defrost completely it should work good for a couple days until the ice builds up again. you more than likely have a deefrost issue. There are usually nthree components in a typical defrost circiut. The heater, defrost thermostat and a defrost timer or control. one or those is bad.
Jul 28, 2014 | Maytag Refrigerators
Frig on top freezer below.....freezer working.... frig not...condensor seems fine and fan is on?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 20, 2011 | Amana ABB2227DE Bottom Freezer...
Freezer works fine but the frig is not getting cold any longer. item is 14 months old.
heatman101
Apr 24, 2011 | Maytag 24.8 Cu. Ft. Side-by-Side...
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
Amana refrigerator not cold
The fan that should circulate air between the two compartments has failed. These usually have 'sleeve' bearings which can become sticky and fail to start up without help. Go to the Sears/parts website and enter your Amana model number; if you are lucky, they will have a line drawing of your model which can aid in finding how to access the fan:
Sears Parts Dept.
They have info for thousands of non-Sears items and most can be ordered via that website as well.
Feb 25, 2010 | Amana ABB1927DE Bottom Freezer...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
My kitchen aid frig is not working. the freezer side does work is it worth fixing model kitchenaid ksrp25fnss00. i bought ot 4 years ago
I would suggest you may have an airflow problem. As the frig compartment receives the cold air from the freezer compartment and you say the freezer is working,then you must have an airflow problem .Check the airflow dail next to the thermostat that has numbers. Normal setting is the middle setting on both airflow dail and therm.Allow temp to stabilize and recheck.hope this helps.
Sep 26, 2009 | Kenmore 72912 / 72914 / 72919 Bottom...
Frost on bottom of freezer inside refrigerator section, leaking
Hi!!! You have a plugged drain line in your evaporator..For a quick fix just turn off your frig for 24 hours and set your temp control at the factory setting listed on the frig and you will be finw trust me..Good luck..
Jan 03, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator not getting cold
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
Refrigerators Logo
322 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
