Question about Arris SBG6782-AC Surfboard eXtreme Cable Modem
How do I rename the ethernet connection name - Arris SBG6782-AC Surfboard eXtreme Cable Modem
Manual configuration of my "MY
Manual Configuration for Globe Subscriber:
GPRS Settings
GPRS Data Account 3 Account Name: myGlobe MMS Access Point Name (APN): mms.globe.com.ph GPRS Data Account 4 Account Name: myGlobe GPRS Access Point Name (APN): www.globe.com.ph WAP Network Settings
Rename Profile: myGlobe WAP Homepage: http://www.globe.com.ph/globe.asp Data Account: myGlobe GPRS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
MMS Network Settings
Rename Profile: myGlobe MMS Homepage: http://192.40.100.22:10021/mmsc Data Account: myGlobe MMS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
Manual Configuration For SMART subscribers:
GPRS Settings
GPRS Data Account 1 Account Name: Access Point Name(APN): GPRS Data Account 2 Account Name: SMART GPRS Access Point Name(APN): Internet Exit and save settings WAP Network Settings
Rename Profile: Smart WAP Homepage: http://wap.smart.com.ph Data Account: Smart GPRS Connection Type: HTTP Proxy AddressL: 010.102.061.046 Proxy Port: 8080
Rename Profile: Smart MMS Homepage: http://10.102.61.238:8002 Data Account: Smart GPRS Connection Type: HTTP Proxy Address: 010.102.061.046
Jun 27, 2011 | Cell Phones
I am connected to internet but get error 651
I am assuming you have purchased a new pc with Windows7 and have a DSL internet connection. If so the following tutorial should prove useful. This is a common problem and known bug within the Windows7 framework that they are working to correct. Keep in mind that this fix is only applicable for the Windows7 operating system.
"The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can work around the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system click here to download raspppoe.sys file (unzip)."
http://www.windowsreference.com/windows-7/error-651-with-pppoe-connections-in-windows-7/
Once downloaded and unzipped you may rename the old rasppoe file as mentioned above by right clicking the icon and choosing 'rename'. Then copy the new rasppoe file you downloaded into the applicable folder. You will find this file in the following directory C:\WINDOWS\system32\drivers. Bear in mind, when searching for the file inside the drivers folder, the .sys file extension may or may not be included in the actual name. If the original file is named 'rasppoe' without the .sys file extension in the name, leave this file extension off when renaming and copying as well.
Dec 10, 2010 | E-Machines eMachines Desktop PC
How do I rename the netgear connection and make it security enabled? I have WG602v2 router
Please follow steps to fix your issue
1. Connect the computer to 1ST Accesspoint using a Ethernet cable.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the Accesspoint (usually http://192.168.0.227).
4. Login to the Accesspoint (Username = admin Password = Password unless you have changed it).
5. click on Wireless Settings in the left hand side menu under Setup.
6. Change the network name SSID to (any name) and click apply.
7. Click on Security Settings in the left hand side menu under Setup and select Security Type as WEP.
8. Select Authentication Type as Open System.
9. Select Encryption Strength as 64 bits.
10. Under Security Encryption (WEP) Key in the Key 1 box enter the same 10 digit key that was used on the router before.
11. Click Apply.
Hope this will help
Thanks for using Fixya
Jun 12, 2010 | Computers & Internet
Please follow steps to make your network secure and change network name.
11. Click Apply.
Hope this will resolved your issue
Jun 12, 2010 | NetGear WG602 54Mbps Wireless G Access...
KU990 .pxo file problem
hay there ..it will help you...i just made that same mistake but i overcome from it..connect ur mobile to usb..and open it through efs media..then.select the port if it shows..if not try refresing and reconnecting...after connect u will see a new lg app create by system..rename it to toto again and disconnect ..then reconect and rename..toto to lgapp..this return back my viewty..and am so glad..
Nov 26, 2009 | LG KU990 Viewty
Its a geforce6100sm-m reformatted and now its telling me info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN info Network connection:...
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Sep 21, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
How to rename recycle bin
I'm am sorry I am a little confused, you want to rename the recycle bin Registry key, but not rename the actual recycle bin? I need a more detailed explanation of the problem that is very specific. Also, just out of curiosity, why do you wish to rename the recycle bin? I am just curious.
Ryan Frame
Creative Energy Associates Technical Center
Aug 22, 2009 | Nolo How to Change Your Name in California...
Rename a folder in c drive using java code
import java.io.*;
public class RenameFileOrDir{
public static void main(String[] args) throws IOException{
BufferedReader in = new BufferedReader(new InputStreamReader(System.in));
System.out.print("Please enter the file or directory
name which has to be Renamed : ");
String old_name = in.readLine();
File oldfile = new File(old_name);
if(!oldfile.exists())
System.out.println("File or directory does not exist.");
System.exit(0);
System.out.print("please enter the new file or directory name : ");
String new_name = in.readLine();
File newfile = new File(new_name);
System.out.println("Old File or directory name : "+ oldfile);
System.out.println("New File or directory name : "+ newfile);
boolean Rename = oldfile.renameTo(newfile);
if(!Rename)
System.out.println("File or directory does not rename successfully.");
System.exit(0);
else {
System.out.println("File or directory rename is successfully.");
Mar 30, 2009 | Sun Java Programming Language (cdj-275)
Rename a file by providing input and out file name
ren current.name new.name
this would rename a file called current.name to the name new.name
Jan 26, 2009 | Computers & Internet
Rename user folder
You cannot rename the user folder because it is a system folder.
You can go to user accounts in control panel and rename the user account from the 'old name' to new name'. Unfortunately this will be purely cosmetic, the account will still be seen by the system with 'old name'.
The only efficient solution is going into control panel/accounts and creating an new account with 'new name'. Then you transfer all data to 'new name' account and delete the old account.
Jul 15, 2008 | Microsoft Windows Vista Ultimate Edition
Arris SBG6782-AC Surfboard eXtreme Cable Modem Logo
64 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
