Fisher dvd player s1500 - plays some dvds fine. For others including a cleaning disc, it says No Play. Any ideas?
fairlane
  • 50 Answers
SOURCE: Freezing?
Hi This is a common fault, and unfortunately, there is only a slim chance it can be economically repaired. I've seen it caused by an over-heating video processor I.C., but also a weak laser, where basically the laser looses it's place and the video processor "hangs" on the last frame of proper video. The good news about that, is that a dirty lense can cause the same symptom as a week laser due to trying to read through dust, so a cleaning could possibly clear up your problem. Now, it's a long shot, but there is also another scenario we often see. If you have an older tv, without A/V inputs, most people connect their DVD to the A/V inputs on their VCR, and change the source on the VCR to AUX. This works fine on some DVD discs that are not big budget films, so it will play some discs perfectly. As soon as you put in your favourite "Terminator" DVD, what you get is a perfect picture for a while then blue screen, then normal picture etc.This is due to copy protection built into the DVD. If you are indeed connected through a VCR, and your tv only has RF input, then you can buy an RF modulator from your local electronics store, and connect through it instead of the VCR. Good Luck!
Posted on Jul 21, 2006
snakehead
  • 1074 Answers
SOURCE: DVD player won't play certain movies
it could be the disc that is causing the problem try some other disc and see what it does.good luck.
Posted on Mar 23, 2007
SOURCE: DVD player recorder won't read or play any disc
This just worked for me. Don't know how long it will last though. I found it on this webpage
http://forum.ecoustics.com/bbs/messages/15118/130292.html
To do a reset:
On the remote control press the SETUP button,
Press the right key on the remote 3 times,
The Preference page will show up,
Press the down arrow five time to highlight
"default", hit right arrow to highlight "reset"
Press enter to reset. Turn off/on machine, etc.
Posted on Feb 14, 2008
SOURCE: recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Posted on Sep 03, 2008
welcomejee
  • 10594 Answers
SOURCE: My DVD player will only play background sound not voices
Go to sound menu of dvd player and select Stereo sound and if surround is enabled, disable it.
You can get help from user manual of dvd player.
Posted on Nov 09, 2008
DVD player will play some DVDs and not others. I checked the regions on the discs with the player and they should play. On the back of the player it says it will play region 1 & no region discs. ...
Unless you have a second DVD player (or a PC with a DVD drive or similar) on hand, to cross-reference the discs with, you won't be able to tell if it is the discs or the Daewoo player that has the issue. It could just be a bad batch of discs, but without the second player available to confirm this, there is little you can do.
On the other hand, some of the discs may not be NTSC, they may be PAL, and unless your player supports PAL compatible playback, it won't play it. Rare, but not uncommon (some PAL DVD players won't play NTSC discs regardless of the region code), and it is not your player that is necessarily at fault here.
Mar 31, 2011 | Daewoo DV6T844B DVD Player/VCR
When i put a dvdin the unit it comes up disc error please eject the disc playback feature maynot be available on this disc
What kind of DVD player is it? Does it do this with all DVDs?
Have you tried a cleaning disk?
Jul 05, 2008 | Emerson Televison & Video
My DVD Player will not play my movies
Try cleaning the lens with a DVD cleaning kit.
Jun 30, 2010 | Philips DVP5990 DVD Player
MY BOSS BV7970 DO NOT PLAY ANY BURN CDRW OR DVDS
Some players are picky with certain cdrw/dvdrw discs. You might have to experiment with different brands/types for your discs. I used to have a cd player (teac) which would just refuse certain brands cd-r discs but play others just fine. I know it sounds odd, but once I noticed which ones work and which ones don't I never looked back.
Also, have the "problematic" discs been recorded on just one recorder? Have you tried playing discs recorded on a different recorder?
Also - I'm sure you've already tried it-it's always a good idea to clean the laser just in case.
Hope this helps+
Good luck,
Raf
Nov 13, 2009 | Boss BV7970 CD Player
Player won't read the DVDs
some players won't play burnt discs. If you are using a factory made disc and you still get this, then you can try and clean laser lens with rubbing alcohol and cotton swab.
If the cleaning doesn't work, then the laser lens circuit will need to be replaced.
Aug 05, 2009 | Televison & Video
My daughter's disney dvd player wont play disney dvd's any ideas?
I would suspect dirt, either on the disc itself or in the player. The discs and laser head need to be clean to do their job properly. If they are too dirty to operate correctly the machine simply gives up trying as though there were no disc loaded at all.
Feb 26, 2009 | Disney Princess DVD Player
Mar 23, 2007 | Memorex MVD2022 DVD Player
I have a Sony RDR HX510, can you help me?
Have you finalised the dvd disc in the machine ? you must finalise all dvds before playing them in other machines.
Mar 18, 2007 | Sony DVD-NS530 DVD Player
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
