Question about Sentry Office Equipment & Supplies
I have a Sentry Electronic Calculator - CA 340. I can not set the tax at 14%. Please help
I can not set the tax for 14%. I lost my manual
SOURCE: Changing the % tax setting on my Casio calculator
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 17­.5 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 17.5 should be displayed
Posted on Apr 12, 2007
SOURCE: CHANGE TAX %+ & TAX- ON MY CASIO JF-100TE CALCULATOR
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Posted on Jan 26, 2008
  • 22 Answers
SOURCE: Resetting sales tax rate on Casio HR8TE calculator?
Here ya go:
1. Press [AC]
3. Press [TAX+]
5. Press [SET/%]
That should do it!
Posted on Apr 10, 2008
SOURCE: how to set the tax rate
Its easy just type in the tax rate that you want, then hit the rate button. Afterwards leave tax+ pressed and you should see the tax % sign appear above the number you punched in, and THATS IT!!! Easy!!!
Posted on Jul 23, 2008
SOURCE: Set Tax Rate
First clear all w/ ON/AC.
Enter the tax rate desired eg. 7 for 7% (can you tell I'm in PA)
Press RATE then TAX+
Press C/CE.
The next time you use TAX+ it will calculate and add the value that you set.
Do the same for TAX-, you can use a different value for each as they are separate memories.
Posted on Jan 27, 2009
I need to change the sales tax rate for my cash register.
Please find below the solution:
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
3. Press [TAX+]
5. Press [SET/%]
Printing models (except HR-8TE):
1. Have calculator in "print" mode
2. Press [CA]
3. Hold [SET/%] key for about 3 seconds
5. Press [TAX+]
6. Press [SET/%]
Mar 18, 2009 | Casio Parts Cash Register PC Desktop
Trying to change the tax buttons on my CASIO HR-150TER
I solved this problem..
1. press and hold your % Key the zero on your display will disappear While the % is pressed, press and hold your CA key. After a short delay the calculator will print a line #--------------- when this happens release the keys.
2. Enter your tax rate for me this was 7.75 then press your Tax+ key.
now your rate is set.
You can then use this key as normal. :)
Hope this helps.
Jan 26, 2009 | Casio HR-150TER Calculator
Sharp EL-1750 V how to set the TAX % using the TAX button
You can download the manual from the manufacturer's web site at
http://www.sharpusa.com/~/media/A1F3B95F580E4F65B539635120DAC9BB.ashx?cal_man_EL1750PIII.pdf
Nov 13, 2008 | Sharp EL-1750PIII Calculator
TAX SET
Press +TAX
press the number you need to set it at
Press +TAX again then CA
worked for me!!
Hope this helps
Oct 21, 2008 | Sharp EL-1801P Calculator
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
May 01, 2008 | Sharp EL-330AB Calculator
Programming Tax+ button
Programming Tax Rate
1. Press [AC]
3. Press [TAX+]
5. Press [SET/%]
The one below is the one you require.
1. Have calculator in “print” mode
2. Press [CA]
5. Press [TAX+]
6. Press [SET/%]
Feb 04, 2008 | Casio HR-150TER Calculator
Change Tax Rate
I found this on the Casio site. I think yours is a printing model. If it is use the 2nd set of instrucitons. Hope it works...
1. Press [AC]
3. Press [TAX+]
5. Press [SET/%]
2. Press [CA]
5. Press [TAX+]
6. Press [SET/%]
Nov 27, 2007 | Casio HR-150TMPlus Calculator
How do you set a tax rate?!?!?
1. Switch off the calculator
2. Switch it on again
3. Press and hold the tax button (set %) until the display changes
4. Enter the new tax rate
5. Press the tax button (tax +)
Any problems contact dave@techsoft.uk.com - he emailed the solution to me and it has worked.
Pam
Oct 10, 2007 | Casio HR-100TMPlus Calculator
Programming the Casio HR-100TE
Printing models (except HR-8TE): 1. Have calculator in ?print? mode 2. Press [CA] 3. Hold [SET/%] key for about 3 seconds 4. Input the tax rate 5. Press [TAX+] 6. Press [SET/%]
May 21, 2007 | Casio HR-100TEPlus Calculator
57 people viewed this question
Top Sentry Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
Are you a Sentry Office Equipment and Supply Expert? Answer questions, earn points and help others
