Question about Miele DA 249-4 Kitchen Hood
Miele da1180 Having to install where hidden under cabinet light was removed so screws are too short. Can I use metric 5mm x 90mm. From top of shelf to bottom edge is 3 inch drop
5 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Miele leak when switched on for wash, from filter unit front LHS bottom of machince
You can replace the Bellows as it is called but to fix it before you replace it clean it with Bleach to kill the mold and then dry it ALSO after any load you do leave the door open a bit this allows the mach to air dry out and prevents the build up of mold ..Good Luck plz rate this post for me
Posted on Feb 17, 2008
bd8078
  • 12 Answers
SOURCE: miele incognito not draining
at the bottom left corner their is a manual draining system maybe you need to use that with a bucket.
thats all i can think of unless it still has warranty just trade it in.
Posted on Oct 03, 2008
  • 177 Answers
SOURCE: My miele g886 dishwasher intake/drain light keeps
the inlet/drain light is a standard fault light and can mean anything without connecting the Miele dianostic software to the unit. This is only available to Miele service techs or service agents. If the light comes on in the first minute then it is probably a drain fault. Try checking the drain spigot at the sink end where the drain hose connects as these are usually the cause of most dishwasher faults.Hope this helps
Posted on Jan 21, 2010
kdrake84
  • 262 Answers
SOURCE: I need to replace the
Here is a video that will show you how....never mind the make and or model they are all the same.
Click on the link http://www.youtube.com/watch?v=noB2W06hcUs
Posted on Mar 06, 2011
How to remove built-in Whirlpool oven and microwave unit?
most built-ins are only secured with a few hidden screws. sometimes behind trim mounding Be sure to turn off the gas or electric before doing this..
Jul 27, 2017 | Whirlpool Refrigerators
What I mean is that how can I open the game plastic box or the cabinet to be able to go in the electronic repair on the board. To repair anything I have to open the cabinet or the plastic covers.
Depending on the model, it can have one screw for top cover which when removed allows you to slide it towards where the screw came out. Then there are about 7 screws (one hidden under the VOID Label).
Nov 19, 2014 | Sony Playstation 3 (PS3) Console
What is a t 45 sockett
The T stands for TORX
The 45 is the size
Torx are a type of fastner
Something like a Phillips Head Screw, but a different shape
To work on todays vehicles, you need T 15 thru T 50 Torx
socket drivers & also screw driver handle type torx
Also you need 5mm thru 10mm Metric Hex Drivers also
The torx are for removing lamp housings etc to change the
tail lights,and pretty much anything, not have a metric bolt with a hex head
Jun 03, 2012 | Cars & Trucks
Having difficulty getting old spacemaker oven out in order to install new.
There are two screws coming into the top front accessed inside the cabinet it is mounted to. the rear of the unit is hung on clips on the bracket screwed to the wall behind it. Take out the two screws ( sometimes hidden under paint or shelf liner) and have someone hold the front up. Then push up on the whole oven and pull it out towards you. ( get help it is kind of heavy). dont forget to unplug it, and feed the cord down as you pull the microwave out. sometimes you have to pull hard, as the pins on the bracket get bent during installation.
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Lid switch is broken on model 11025852400 sears kenmore washer 80 series. how do you replace it
Good day,
1. There are 2 screws. one on each bottom corner of the control console. The may be hidden by plastic end caps that have to be uncliped. Remove screws, and lift slightly on the console and rotate away from you.
2. Underneath you will see 2 bronze colored spring clips, and a three wire plug. Unplug the three wire connector, and with a decent size screw driver, place in the well of the clips and pop them off.
3. You will be removing the whole cabinet. Top, front, and both sides as one piece.
4. Slide the cabinet forward a few inches, then tilt it over until the front is laying on the floor.
5. There are 3 distinctly different switch arrangements. 2 have a pin on the side of the lid, which depresses the switch. Purchase and replace everything, including the depressing pin.
6. The third type is totally hidden with no depressing pin. It explains itself.
7. Reinstalling the cabinet, is a lot harder than pulling apart, due to alignment problems. Having 2 people helps. The bronze clips take a lot of pressure to re-install as well.
Dec 06, 2009 | Kenmore Washing Machines
How do i disassemble (i.e. which screws do i pull and which hidden tabs are there) the cord retractor/switch assembly? there is only one screw that appears to hold the piece but it does not come out,...
There are 7 torx head screws to remove in the top plastic housing. 5 are in the perimeter and two are "hidden". One is under the power/cord winder panel which pops off in an upward diredtion. and one is under the cloth filter on top of the motor, inside the bag compartment. Take out those 7 and lift the plastic top panel off !
Sep 26, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Nothing happens when plugged into wall.....no lights no hint of any life at all .it worked one day then it didnt........has it a fuse?.....if so where is it
Fuse may be in the back of the cabinet. If the cabinet is removable, and you probably will find screws under a label or two, if you take all you can see out, and the cabinet still won't come apart, feel across any labels and see if you find a hole, which will contain a "hidden" screw, but, probably the fuse will be near the entrance to the power cord. Make sure you unplug the appliance FIRST and then remove the case screws and look for a glass fuse in a holder somewhere near or around the power cord area. If you have a multimeter, you can check to see if power is indeed coming to the system where the power cord is connected to the lugs, if so, you could possibly have a defective power switch. A little investigation (CAREFUL INVESTIGATION) will more than likely result in your finding the fuse, and or the problem.
Sep 26, 2009 | Philips FW-D5 CD Shelf System
Need to Know how to remove top and cabinet
first, do you have phillips screws on back of console at bottom goin down or in front bottom? one or the other remove these then slide console forward and fold back on hinge on top. if no screws then clips are hidden on front edge on end plates. use putty knife from front to push and release lifting console at same time. fold back.
use screw driver to pry and release brass clips holding top to rear panel. unplug lid sw connector and pull cabinet body away from machine. top and cabinet is screwed together and removed as one piece. cabinet hinges under base on front and sits on top of sides.
May 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
No Spin No Drain
Lid switch is most likely the problem, if lid switch is visible under lid on right side then this is older design and common problem switch.
if you have console frame covers on front sides, snap off from top, a screw is at bottom front corners of console, remove and pull console forward and fold back. If lid swich is hidden then you will see it at left on top of cabinet with console folded back. a 5/16 screw holds a green ground wire to cab. remove and switch will unclip with lid up. If lid switch was visible under lid then you need to remove 2 brass clips holding cabinet on top of base to back, pry with screwdriver to unclip. undo harness connection on cabinet top, this is your lid switch connection. sw body is held by 2 phillips screws, harness tube held by clips on underside of cabinet top. ground wire with 5/16 screw present at sw body. New versions of this switch have metel shield attached.
Apr 25, 2009 | Kenmore 22642 Top Load Washer
Miele DA 249-4 Kitchen Hood Logo
59 people viewed this question
Top Miele Kitchen Ranges Experts
Jim Thurston
Are you a Miele Kitchen Range Expert? Answer questions, earn points and help others
